This question seems to come up quite frequently. What do I need to upgrade my 130 to a RER/RHB/RHR, is it (PNP) plug and play? So I thought I might write up some information to maybe ease the pain. This may be something the MODs might want to sticky because of how frequent this topic comes up.
Here we go.
1) When upgrading to MyGig, the first thing one should look for is a LOW BUS speed unit. These were used in many vehicles and are plentiful to be found used at a reasonable price. Far from many rumors, the BUS speed has not changed since the first Challenger up until 2014. This is a true PNP, radio wise. Just plug it in, and it works. No going to dealer to activate anything. If buying used from unreliable source, get the part number and do a Google search to see if it cross references to your application. If local, plug it into your car on the spot. It doesn't take but a little time. If your car doesn't start, don’t buy it. It’s a HIGH speed BUS unit.
2) In 2011, the RER changed to RHR and 430n became a NAV. With that, most import to note is that the antenna changed. They combined the NAV and Sirius into one. If putting RHB/RHR into 2010- might be best to purchase new antenna. RER into 2011+ is ok because you still need separate antenna for NAV.
3) Any unit 2012 and newer requires a 4 digit anti-theft pin code to activate (so they say, some have reported different). When purchasing one used, make sure you get it. If not, you will need the VIN from the donor car to retrieve the pin from dealer.
4) 2010- units will work in 2011+ vehicles and vice versa as well. See notes above about antenna changes.
5) 430n’s have external hands free modules. 730n’s have internal hands free modules.
6) The easiest way to convert from 130 with Uconnect is to use the RHB. No adapter harness is needed.
7) If you have Uconnect and want to upgrade to RER/RHR, you WILL need a conversion harness to get your mic to work. They make 2. The first is part number 82211666 ($119.00) and is intended for 2010- vehicles. This goes from back of radio to mic’d mirror. With this you will need part number 68068278AB ($25.00) as well to connect console USB. For 2011+ they came out with another harness. Part number 82212906 ($81.40). This harness goes directly from the back of radio to the OEM plug you unplugged from the HFM. With it comes the USB extension you will need to get the console USB to function again. Now, I can’t verify if 2010- owners can purchase the 82212906 and use this and save some cash. The part number for the hands free module changed for 2011 but the 22 way wire connector stayed the same.
That is about all I can think of now. If anyone knows of better or more info, please post. This can be an ongoing post for others to contribute to. The more the merrier.
LOW SPEED UNIT Part numbers NOTE: Some units came RSC(Sirius) and NON RSC. When purchasing, ask for confirmation (or a picture of unit) if this is an option you want. Also, as stated above, 2012+ units are security code locked. You need code from seller and/or may need receipt and vin from seller to get code from dealer.
This is most but probably not all. They are multi fit: meaning they are not only Challenger part numbers. Some are Compass, Avenger, Caliber,Patriot. All being LOW SPEED.
RER (730n) 2008-2010
05064401AK
05064737AD
05064816AD
REN (430) 2008-2010
05064756AC
05091167AD
05091306AC
05091307AC
05091168AD
05064758AC
RHR (730n) 2011-2014
05064821AE
05091656AE
68224879AA
68092001AE
RBZ (430) 2011-2014
05064676AH
05091167AD
05091306AE
05091307AE
05091168AD
05064677AH
RHB (430n) 2011-2014
05064840AH
05091183AD
05091335AF
05064836AH
05091184AD
05091336AF
Here we go.
05064401AK
05064737AD
05064816AD
REN (430) 2008-2010
05064756AC
05091167AD
05091306AC
05091307AC
05091168AD
05064758AC
05064821AE
05091656AE
68224879AA
68092001AE
RBZ (430) 2011-2014
05064676AH
05091167AD
05091306AE
05091307AE
05091168AD
05064677AH
05064840AH
05091183AD
05091335AF
05064836AH
05091184AD
05091336AF
