Hellcat crank pinning - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 6 (permalink) Old 04-13-2019, 08:30 AM Thread Starter
RussDavis's Avatar
Is it possible to pin the crank on a Challenger Hellcat without taking the front bumper off.
2016 Hellcat
Plum Crazy
Windows tinted
RussDavis is offline
post #2 of 6 (permalink) Old 04-13-2019, 09:51 AM
YLWJKT's Avatar
Feedback Score: 9 reviews
It can be done but it's a large pain.
The front end comes off in less than 15 minutes and makes the job MUCH easier.
I use a furniture pad that I picked up from Harbor Freight to set it on.
Not my video but it has some good tips:
YLWJKT is offline
The Following User Says Thank You to YLWJKT For This Useful Post:
Bob Ricewasser (04-13-2019)
post #3 of 6 (permalink) Old 04-13-2019, 11:50 AM
When I pinned the crank on my 2015 5.7 all I had to remove was the radiator fan. Key is to get a compact right angle drill. I used a pneumatic one I bought from HF.
post #4 of 6 (permalink) Old 04-13-2019, 12:25 PM
YLWJKT's Avatar
The 5.7/6.4 are a little easier to do.
However the Hellcat has an hard intercooler line that runs across the bottom of the radiator, as well as an intercooler in front of the radiator, which gives you a lot less room to work.
Can it be done?
Yep, and I have done it.
However I've done multiple others subsequently by pulling the front end and it's much easier.
My 2 cents, YMMV.
YLWJKT is offline
ChallyTatum (04-13-2019)
post #5 of 6 (permalink) Old 04-14-2019, 06:20 AM Thread Starter
RussDavis's Avatar
Is all the work done from the top? Drilling? What is the actual advantage to taking the bumper off? Basically so your closer to the work?
post #6 of 6 (permalink) Old 04-14-2019, 08:48 AM
YLWJKT's Avatar
The fans have to come out of the bottom of the car.
The radiator needs to be unbolted and pushed towards the front of the car to gain clearance to do so.
On the Hellcat there’s a hard intercooler line that runs across the bottom of the radiator, as well as an intercooler in front of the radiator. Both make it more of a challenge to get in there with the bumper on.
Taking the bumper off gives you a lot more room to work/move the radiator without damaging the fins.
It’s literally a 15 minute operation the first time.
From the point of where you would already be at to drop the fans I can have the bumper off in 5 minutes.
The 2015 up are much easier than the previous gen. to pull off, but other than 2 extra pita nuts they weren’t that bad either.
If you’re changing the lower pulley it also gives you a lot more to to work when doing the clearancing on the front cover.
Like I said, it can be done without pulling it, but it’s much easier with it off.
I have done a few now, and I prefer pulling the bumper.
My 2 cents YMMV
YLWJKT is offline
Developing Mishimoto's Aluminum Hellcat Radiator Mishimoto Mishimoto 12 02-28-2017 09:08 AM
2017 Hellcat Steering Wheels Can Retrofit in These 2015-16 Models ncmountaineer General Challenger Discussion 1 10-10-2016 03:03 PM
Dodge Unleashes Most Powerful Challenger Ever 2doorrocket SRT Hellcat 6.2L Supercharged (2015 - ) 242 11-11-2014 02:33 PM
2015 Dodge Charger SRT Hellcat Test Drive IDMTfirefighter The Garage: For OTHER car talk 1 11-03-2014 01:54 PM
The REAL Scoop on the Challenger Hellcat Spy Photos !! beamg5 SRT Hellcat 6.2L Supercharged (2015 - ) 27 05-14-2014 09:58 PM
