High Idle on start up - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 9 (permalink) Old 06-04-2019, 08:32 AM Thread Starter
biocide's Avatar
New Hellcat owner, on cold start up my idle goes up to 1750 rpm and then slowly drops back to approx. 750 rpm. Is this high rpm normal for the hellcats? My scatpack didn't rev this high on initial startups.
I couldn't find any information about this in my searches on this site.
Bone Stock......so far
biocide is offline
post #2 of 9 (permalink) Old 06-04-2019, 08:48 AM
Appears to be normal. According to this 2016 stock HC tune startup idle should be around 1700rpm for coolant temps below 104F. See attached image of elevated idle table.
biocide (06-04-2019)
post #3 of 9 (permalink) Old 06-04-2019, 08:59 AM
Different engine but my scat revs high on cold start also.
2019 wide body Scat
Foot print gas pedal ( just kidding)
Decay is offline
post #4 of 9 (permalink) Old 06-04-2019, 10:59 AM
Scats don't rev as high on start up as the HCs do.
post #5 of 9 (permalink) Old 06-04-2019, 08:14 PM
Is that top number seconds?
I will look at it closely tomorrow morning but that looks right.
Decay is offline
post #6 of 9 (permalink) Old 06-05-2019, 07:42 AM
Basically idle is commanded from this table at first based on engine temp and how long the engine has been running. The PCM then refers to other tables to determine final idle once the car hits optimum temp. On my 2015 RT manual, the P/N or Manual w/AC (took a couple of tries to confirm this table controls the final idle).
BTW I bumped up my elevated idle in the 0 and 3.2 s engine run time columns to give the can a nice startup rumble which tapers down abruptly. It's like starting the car with a little bit of pedal that you release quickly.
biocide (06-12-2019)
post #7 of 9 (permalink) Old 06-12-2019, 09:41 AM
redcat15's Avatar
I have a ‘15 Hellcat...same startup rev sequence from day one...all is well.
redcat15 is offline
post #8 of 9 (permalink) Old 06-12-2019, 10:15 AM
Yes, that has been established as the HC calibration is programmed for high idle at start-up:
Hell Cat elevated idle map
Scat Pack elevated idle map
post #9 of 9 (permalink) Old 06-12-2019, 12:07 PM
What ChallyTatum said. I had thought my Hellcat idle dropped rather quickly like my cars before it, but paying more/closer attention I find it does take longer to for the Hellcat engine RPMs to drop.
But the RPMs do drop. Might note where I live and drive ambient temperatures are mild (at least at night; last couple of days we've had triple digit heat but the Hellcat has remained parked under a carport and I have used my other car) so in the AM the car/engine is not that cold and coolant temperature starts out pretty "high" and comes up pretty quick. I have not experienced the Hellcat in real cold temperatures and I don't know what the idle speed would do in colder temperatures.
Rockster is offline
