Rearend Swaying - Feels Loose! '17 HellCat - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 13 (permalink) Old 04-04-2019, 06:23 PM Thread Starter
FLYIN4D's Avatar
Arrow Rearend Swaying - Feels Loose! '17 HellCat
Hello. I have a question about my car. Its a '17 HellCat Challenger with 7700 miles. Car has new factory OEM size Pirelli's. I just came back from a drive and noticed the rear of the car was doing some crazy stuff. It almost feels like the car has a "locker" rearend in it. Depending on the speed, gear or left/right turn and slightly accelerate, then shift, the ass-end of the car has movement like its shifting from side to side at times or moves towards switching into another lane without notice! WTF! No way in hell is that normal, so I have something going on back there. I didn't notice it on the test drive or the drive home when I purchased it last week. Nothing on the car appears to show any signs of accident, damage history and the drive-train or rear-end doesn't make any noises, etc. Your thoughts?
"Honor The Dead & Fight Like Hell For The Living"
FLYIN4D is offline
post #2 of 13 (permalink) Old 04-05-2019, 03:06 AM
Fawls's Avatar
Rear tire(s) going flat/low air?
2016 SRT 392, A8, Granite Crystal.
Fawls is offline
post #3 of 13 (permalink) Old 04-05-2019, 07:42 AM
If it is not tire pressure, check the lug nuts then bushings at links/control arms/cradle. If you have access to a gopro, slap it under the car so you can video what happens...or have a friend follow you in another car and have them watch the rear wheels to see if they are doing anything funny. BTW do you have limited slip diff?
ChallyTatum is online now
post #4 of 13 (permalink) Old 04-05-2019, 08:10 AM
praiseV8's Avatar
Originally Posted by FLYIN4D View Post
Hello. I have a question about my car. Its a '17 HellCat Challenger with 7700 miles. Car has new Pirelli's. I just came back from a drive and noticed the rear of the car was doing some crazy stuff. It almost feels like the car has a "locker" rearend in it. Depending on the speed, gear or left/right turn and slightly accelerate, then shift, the ass-end of the car has movement like its shifting from side to side at times or moves towards switching into another lane without notice! WTF! No way in hell is that normal, so I have something going on back there. I didn't notice it on the test drive or the drive home when I purchased it last week. Nothing on the car appears to show any signs of accident, damage history and the drive-train or rear-end doesn't make any noises, etc. Your thoughts?
Was it raining?
2016 Dodge Challenger R/T 392
Bright White, A8+V6
praiseV8 is online now
post #5 of 13 (permalink) Old 04-05-2019, 08:48 AM
It is a Hellcat. 707hp. Maybe you need to calibrate your right foot?
The Hellcat requires one be very judicious with throttle input or the rear tires will break loose and more readily that lesser cars.
Check tire inflation pressures. Cold. I believe the proper inflation pressure is 32psi. Try to get the tires inflated to the same pressure as close to possible.
Check the tires. Be sure they are the "right" tires for the car. The right tires for high performance cars means more than just black, round and the right size. Tread wear rating, speed rating, load rating, etc., all play a role in ensuring the tire can withstand what the car subjects it too and that the tire delivers the desired road experience. Not only regarding just grip, but stability, resistance to uneven road surfaces, acceptable noise levels, ride harshness, etc.
If the tires are unidirectional be sure they are all mounted in the right direction.
Just to be safe/thorough check the lug nuts are properly torqued.
Rockster is online now
post #6 of 13 (permalink) Old 04-05-2019, 02:28 PM Thread Starter
FLYIN4D's Avatar
I know it’s a HellCat and my foot and hands have matted much much more HP in a street car than this car lays down. That isn’t the problem at all. And yes, I respect the HP/TQ this car puts down.
I did check tire pressures. They’re at 39 PSI all the way around in each corner.
Took it back to dealer this morning and met with the service advisor. Their Tech manager went with me in a test drive and it repeated multiple times on the test drive. He’s seen the problem before. Taking it back on Monday to get the situation looked at on a lift and leaving it there for a couple other things to be addressed I’ve since noticed. They’re providing me a rental car.
Since my return from the dealership I’ll let the tires get cold again, then drop the pressure to 32 PSI. That way I can see if that is the cause or at least eliminate it from the entire list. I’ll report back. I JUST WANT IT RIDING RIGHT!!
FLYIN4D is offline
post #7 of 13 (permalink) Old 04-05-2019, 02:34 PM
Ok. It ain't your lead foot.
39psi is too much air pressure based on what is called for with my 2018 Hellcat. But could that be what accounts for the behavior? Can't say.
You are doing the right thing: Having the car checked out to get to the bottom of what's going on, causing the behavior.
post #8 of 13 (permalink) Old 05-01-2019, 03:42 PM Thread Starter
FLYIN4D's Avatar
Got it straightened out. It was not the tires. It was the bushings in the cradle and lower control arms. Tech got it figured out, and also found a leaking half-shaft and replaced under warranty. Furthermore, whomever owned this car did not do such a great job at keeping the wheel and brake areas very clean. The brake dust was staining all 4 calipers - the dealership replaced them with 4 new calipers at no cost (warranty). Thanks for the help gents. I have a happy non-swerving rearend!
FLYIN4D is offline
The Following User Says Thank You to FLYIN4D For This Useful Post:
Fawls (05-01-2019)
post #9 of 13 (permalink) Old 05-01-2019, 06:22 PM
2015SXT's Avatar
That's a Great dealership.
2015SXT is offline
post #10 of 13 (permalink) Old 05-01-2019, 07:01 PM
F8Dragon's Avatar
Not to be an ahole here but 7700 miles, New tires, and all the other stuff that you listed tells me that someone abused that car badly.
I am glad to hear that the dealer took care of everything for you under warranty.
2018 Challenger F8 Scat Pack 392 M6
IG f8dragon
F8Dragon is online now
A Dodge?? Chevrolet guy buys a Hellcat Rob Steinberg General Challenger Discussion 25 02-09-2017 05:43 PM
2015 Dodge Challenger SRT Hellcat Review AG Jeff Dodge Challenger News 9 02-18-2016 06:08 AM
Hellcat is the best thing since sliced Bread, maybe 2nd Exclusive General Challenger Discussion 0 04-11-2015 06:35 AM
2015 Dodge Charger SRT Hellcat Test Drive IDMTfirefighter The Garage: For OTHER car talk 1 11-03-2014 01:54 PM
