Unlocking the stock ECU - Dodge Challenger Forum: Challenger & SRT8 Forums
LinkBack Thread Tools
Old 05-08-2018, 02:37 AM Thread Starter
gixxer160's Avatar
Has anyone heard anything about getting the stock ECU unlocked. A friend said that Diablo had done it and that the stock ECU then becomes programmable.
gixxer160 is offline
Old 05-08-2018, 05:14 AM
Rob446's Avatar
Diablo, HP Tuners and probably others can unlock the PCM for tuning with their software. Make sure you understand how tuning takes place and what other hardware/software is required before you move forward. Most folks opt to purchase an unlocked PCM and retain the stock one for back up, warranty, etc.
Rob446 is online now
The Following User Says Thank You to Rob446 For This Useful Post:
PaVaSteeler (05-08-2018)
Old 05-08-2018, 05:42 AM
Frank Julian's Avatar
I have a my stock PCM sitting on a shelf, I had a Scat pack 1 PCM installed in my 2015 R/T. I keep thinking about getting it done, but tuning for some reason makes me nervous, like afraid I will "brick" my car.
Frank Julian is online now
Old 05-08-2018, 06:40 AM Thread Starter
gixxer160's Avatar
Does unlocking your stock ECU or even getting a race ECU kill your warranty. I want to change the exhaust on my 2018 Hellcat and remove the Cats, that will require unlocking the ECU to override the o2 sensor. will Chrysler find out
Old 05-08-2018, 06:43 AM
Rob446's Avatar
I know exactly what you mean, that is why I went with Diablo and a remote tuner. I really wanted to go with a more hands on solution but after months of studying realized that I had neither the knowledge or skill to tune my own vehicle. Hope to get there someday. I have a lot of respect for board members that tune their own cars.
Old 05-08-2018, 06:45 AM
PaVaSteeler's Avatar
Have you heard the phrase "Penny wise, pound foolish?"
That applies to your PCM. You might "save" money having your OEM PCM unlocked, but you're setting yourself up for trouble and expenses down the road.
Why? Because many dealers flash the PCMs when the car is brought in for service. If you unlock your OEM PCM and have a tune installed, when the Dealer flashes that PCM (1) they'll over-write that tune and if you don't have it saved you've lost it and the money you spent on it, and (2) the dealer will read that your PCM has been unlocked; this could (will) lead to warranty issues down the road.
IF you are interested in getting a tune, you're far better off buying an already unlocked PCM from HP Tuners or Diablo Sports, and only swap it out with your OEM PCM when you take your car in for service (takes 20 minutes max).
Strange things can happen to a PCM that's flashed by the dealer; if they "brick" your unlocked OEM PCM, they'll most likely deny culpability because it was unlocked, and you'll be stuck at the dealer with a very expensive paper weight (your car) unless you pay the dealer to replace the PCM....IF they have one in stock.
Bite the bullet and buy a second PCM that is unlocked by the tuner of your choice...it's worth the piece of mind.
Mopar Stage 1 Springs
PaVaSteeler is offline
Old 05-08-2018, 06:52 AM Thread Starter
gixxer160's Avatar
All in all its best if I leave the car stock. Save a lot of hassle down the road.
Old 05-08-2018, 08:59 AM
Good Idea. I put catless on and used Bigdaddys mini-cats that screw in under the rear o2 sensors and it never coded. They are the answer to that problem. BUT, I tried all last summer to verify a gain from the catless and an LMI on a stocker and I ended up breaking about even with a 10.89 in around 1800-2000ft air. Went back to all stock and then went a couple 10.85's and a 10.84. I suspect on a stocker the catalytic back pressure may somehow work in conjunction with the camshaft overlap period preventing some boosted intake charge from escaping. Just speculation but it is the only thing I can come up with that makes any sense. The LMI sounded cool and looks great and may work on a big HP setup but again I gained 0 in quite a few runs with it on a stock setup. It is a nice piece tho with potential in other applications I would think.
2009 SRT 426 N/A Automatic, CA, headers, Corsa exhaust, 8.8 with a 3.08, 90mm TB, More.
11.64 @ 119 on the motor with drag radials.
windwalker438 is offline
Old 05-08-2018, 05:06 PM Thread Starter
gixxer160's Avatar
Getting rid of the cats isn't about HP gains as i know that the current cats flow very very well. It's about noise level. The cats remove a few Decibels for the exhaust note and I like my cars to sound loud. My Ideal setup would be like my other cars and truck, long tube headers no cats and twin AtAt 2.5 Aero Turbine mufflers straight out to 5" tips. However I feel this would kill my warranty, so i am gonna hold off for a while
Old 05-08-2018, 06:11 PM
If I did my stock PCM I would still have my unaltered Scat Pack 1 PCM and the dealer can NOT flash that...
Speedlogix Billet Tension Arms IN STOCK! Speedlogix-Sales Speedlogix 94 11-01-2017 11:24 AM
Pro Stock Dart Cuda340 The Garage: For OTHER car talk 2 01-06-2015 08:36 AM
Which COLD AIR INTAKE? mopartyson 6.4L / 392ci (2011 - ?) 89 10-25-2013 12:41 PM
Confirmed stock cai even with K&N drop in filter is a restriction even for the 3.6 ddeennis Dodge Challenger SE/SXT Specific 7 08-28-2013 06:49 AM
Chrysler's SEMA surprise: 392 HEMI Dodge Challenger Super Stock ekool Dodge Challenger News 44 06-04-2007 03:50 PM
