24 hours in Rental 5.7/A8 Challenger - Dodge Challenger Forum: Challenger & SRT8 Forums
2015 to Current R/T & RT Plus Specific This area is for vehicle specific information about the 2015 and beyond R/T and the R/T Plus
post #1 of 41 (permalink) Old 11-02-2018, 03:06 PM Thread Starter
I’ve been considering the purchase of a 5.7/A8 Challenger. Needed to confirm that it would fit in our garage with my Harley and my wife’s Ford Edge. This past Wednesday, I rented a Challenger from Enterprise at O’Hare airport.
The car I rented:
- 2017 5.7/A8 Challenger R/T
- No backup camera or blind-spot monitor
- Front tires: Nankang Sport NS-25 all-season
- Rear tires: Milestar MS932XP+ M&S-rated
- Beginning mileage: 30316
- Ending mileage: 30497
- Total rental miles: 181
Per the VIN, the window sticker for the car I rented:
Sport Mode is Standard!
- In Sport mode, noticeably sportier upshift and downshift points with much crisper shifts
- Steering felt stiffer in Sport Mode
- The active exhaust sounded great!
0-60 Timer is Standard!
- In Sport mode, my best 0-60 times were 5.2-5.3 seconds
- In Non-Sport mode, my best 0-60 times were 5.4-5.7 seconds
MPG per the dash computer:
- Cruise control @75 for 10 miles: 25 MPG
- Cruise control @70 for 10 miles: 27 MPG
- Cruise control @65 for 45 miles: 29.8 MPG
- Overall for the 181 miles I had the car including lots of 0-60 tests: 21.5 MPG
Additional Observations:
- After too many years of driving 4-cyl cars, V8 low-RPM torque!
- Liked that the dash displayed what gear the car was in even when the shifter was in the normal “D” position
- My wife’s golf bag easily fits in the trunk with lots of room to spare
- Imperceptible transitions between 8-cyl & 4-cyl mode
- When needed, the transition to 8-cyl mode is instantaneous
- For how I drive, limited-slip differential and paddle shifters are nice-to-haves but not need-to-haves
- It fits in the garage with the Harley and the Edge!
- The active exhaust sounds great!
Questions:
- No digital tach readout?
- Air Catcher gets yellow-LED halo running lights?
- Does selecting “Sport Mode”, even if the transmission stays in the same gear, yield a louder exhaust?
- Did I mention that the active-exhaust sounds great?
jzink0883
jzink0883 is online now
post #2 of 41 (permalink) Old 11-02-2018, 04:29 PM
Cuda340's Avatar
You should also test drive a 6.4 Scat Pack before you make a purchase decision.
Also, you may want to consider a previously owned SRT with low mileage. You can probably get a good deal on one. Check out cars.com.
Cuda340 is offline
jzink0883 (11-03-2018)
post #3 of 41 (permalink) Old 11-02-2018, 11:41 PM
TA 392 YJ's Avatar
I agree. It's s very little more money and you get low 4s for that 0-60. The difference is pretty dramatic between the 5.7 and 6.4 if low end grunt is what you like. If that's not enough you'll have to dig a little deeper for the Hellcat.
I drove all 3. The 5.7, 6.4 and a Hellcat. Only you know what you're looking for and what is enough or potentially more than you need. I found the 6.4 (392) was truly in the "sweet spot".
I found the Hellcat to be BLISTERING FAST but hard to actually take real advantage of on the street and then the 5.7 was good but not enough to make me want to trade a noticeably much faster 5.0 Mustang in for it.
The 6.4 was the engine in this car that seemed the perfect balance. I knew I wanted the Challenger for it's good looks and comfortable interior but I wasn't willing to give up performance to get it. The Hellcats are very fast but it's hard to find one that doesn't make me ask why I wouldn't just buy another Corvette for just a little more cash. These are my priorities and thoughts only though.
In the end:
You can't really go wrong. Any Challenger is a good looking car and they all can be optioned up to be as comfortable to drive as you want and need them to be. You really do only have to pick your performance level required to make you happy with your purchase.
TA 392 YJ is offline
The Following User Says Thank You to TA 392 YJ For This Useful Post:
post #4 of 41 (permalink) Old 11-03-2018, 09:52 AM
According to the window sticker the car you drove had a conventional rear axle not limited slip. I'm thinking that all R/T Challenger's with the automatic 8 speed get paddle shifter because they're no listed as an option on the Window Sticker. Either way good luck with your purchase and I'll second driving a Scat Pack with the 6.4 cause there's no replacement for displacement.
2019 TorRed Scat Pack Wide Body M6
Ed1774 is offline
The Following User Says Thank You to Ed1774 For This Useful Post:
post #5 of 41 (permalink) Old 11-03-2018, 10:02 AM
Nope, at least not on the '17 models. I have a '17 R/T A8 with no paddles.
NMRT is offline
post #6 of 41 (permalink) Old 11-03-2018, 06:02 PM Thread Starter
Ed1774,
The ‘17 5.7/A8 that I rented did not have paddle shifters.
Per my research on ‘17-newer (active exhaust!) 5.7/A8 Challengers:
Paddle Shifters:
- ‘17-‘18:
— — To get paddle shifters, the Super Track Pak package had to be ordered
- ‘19:
— — Paddle shifters are standard on all automatic-trans Challengers except the base-model SXT
Limited-Slip
- ‘17:
— — I have not been able to locate a ‘17 5.7/A8 model with limited-slip
- ‘18:
— — The ‘18 Challenger brochure lists a 3.09 limited-slip as an option on 5.7/A8 models
— — At dodge.com, limited-slip is not listed as an option on ‘18 5.7/A8 models
— — I have not been able to locate an ‘18 5.7/A8 model with limited-slip
— — Per email corespondence with the factory, I confirmed that limited-slip was not available on ‘18 5.7/A8 models
- ‘19:
— — Per the ‘19 Challenger brochure and dodge.com, ‘19 5.7/A8 models with the optional Performance Handling Group package have a 3.09 limited-slip
— — I have located ‘19 5.7/A8 models with window stickers that list a 3.09 limited slip
I welome corrections and clarifications.
post #7 of 41 (permalink) Old 11-05-2018, 09:47 AM Thread Starter
You should also test drive a 6.4 Scat Pack before you make a purchase decision. Also, you may want to consider a previously owned SRT with low mileage.
Originally Posted by TA 392 YJ View Post
I agree.
Cuda340, TA 392 YJ, Ed1774,
Thank you for replying to my post about my rental R/T. I understand and appreciate your urging me to consider a 6.4. I realize that, all things considered, the 6.4 is a bargain.
My context:
- I’m 69
- My wife and I are both recently retired
- When I was younger my family had dual Roadrunners
- — ‘68, 383/A3, 3.23 (0-60: 7 sec; 1/4: 15.0)
- — ‘70, 383/A3, 3.91 limited-slip (0-60: 6 sec; 1/4: 14.2)
- I want a car that puts a smile on my face like those Roadrunners did
- I need a car that I can afford to buyAND that I can afford to own
I have considered a 6.4; reasons why I’m leaning toward the 5.7:
- Lower price
- 5.7 likes mid-grade or regular; 6.4 requires premium
- 5.7, (0-60: 5.2 sec; 1/4: 13.7)
- Lower insurance?
- 5.7 can be covered by a Mopar lifetime extended warranty; 6.4 maximum is 8 years and 125k miles
EDIT: Mopar no longer offers a llifetime extended warranty for any vehicle.
post #8 of 41 (permalink) Old 11-05-2018, 12:58 PM
Don't drive a 392 car. It will ruin your impression of the 5.7. Seriously.
1968 Dodge Charger R/T
2015 Dodge Charger R/T Scat Pack
2017 Dodge Durango Citadel Hemi
ygbsm is offline
The Following 3 Users Say Thank You to ygbsm For This Useful Post:
Clevetown (06-09-2019), jzink0883 (11-05-2018), Klink (11-08-2018)
post #9 of 41 (permalink) Old 11-08-2018, 09:57 AM
"MPG per the dash computer:
- Overall for the 181 miles I had the car including lots of 0-60 tests: 21.5 MPG"
I applaud your quasi-scientific testing of the car's parameters. One of the great things about the RT with auto trans and MDS is the good gas mileage.
I have an R/T and unless you live in Montana, it's hard to find a place within 300 miles of Chicago area, where you live, where you can safely wind it up anyway. I find the R/T is totally adequate power wise for 85% of my driving, I think you will find the same, and don't need an SRT unless you go to track event.
If you order one, limited slip is a must. If you go used, I strongly recommend you find one with limited slip. It's a must on these flexey, wheel-hopping unibody cars.
2012 Dodge Challenger R/T Plus Customer Preferred Package 28J w/ Heated Leather Seats (awesome!) Automatic Transmission w/ MDS (24 mpg highway!) Super Track Pack (awesome!) Anti-spin Differential (only $100 bargain of the year!) HID Headlamps, Engine Block Heater (seemed like a good idea at the time...)
LT1 Iron is offline
The Following User Says Thank You to LT1 Iron For This Useful Post:
jzink0883 (11-09-2018)
post #10 of 41 (permalink) Old 11-08-2018, 10:51 AM
JavierA's Avatar
Having two previous R/T in the past (2010 Auto R/T and a 2013 R/T 6 speed) I would agree that it's probably the best option if you're not looking for more performance and a daily driver. I upgraded to the Scat Pack Shaker because of the new style (Shaker) and the 6.4L because I wanted more power but still be practical for a daily driver. As most said, if you test drive a 6.4L it's going to change your mind about the 5.7L unless like you stated, you're not looking for more performance. No matter what you choose you'll be happy with the Challenger. I always said if I needed a retirement car I would probably go with a V6 Charger because of the convenience of the 4 door and gas mileage with decent performance...
Good luck and welcome to the forum...
JavierA is online now
The Following User Says Thank You to JavierA For This Useful Post:
  Dodge Challenger Forum: Challenger & SRT8 Forums > Model Specific Discussion > Dodge Challenger R/T Specific > 2015 to Current R/T & RT Plus Specific
