400 hp? - Dodge Challenger Forum: Challenger & SRT8 Forums
2015 to Current R/T & RT Plus Specific This area is for vehicle specific information about the 2015 and beyond R/T and the R/T Plus
post #1 of 13 (permalink) Old 04-16-2019, 08:38 PM Thread Starter
RTguy_1961's Avatar
400 hp?
I am considering some mods on my 2016 RT A8. If I add a Legmaker CAI, a 85mm TB, short headers and a tune can I get 400 HP at the crank? Thanks for any advice
RTguy_1961 is offline
post #2 of 13 (permalink) Old 04-16-2019, 09:19 PM
Newoldchallenger's Avatar
400 hp?
Possibly. It would be easier done with a mild cam swap or longtube headers.
2013 Challenger R/T Automatic
Newoldchallenger is offline
post #3 of 13 (permalink) Old 04-17-2019, 06:37 AM
Clevetown's Avatar
Well your already at 375 hp stock - and that probably would dyno a little higher so lets say - 385 stock. Your only 15 hp away from your goal. I would think you should hit it. But as "newoldchallenger" said, LT headers for sure will get you there with a cam swap. You'll be producing quite a bit more than just 400.
2015 Scatpack 392 M6
Black/black
Stainless Works LT Headers
High flow cats
Resonator delete
274 Comp Cam with vvt limiter
Arrington 84 mm throttle body
Barton short throw shifter
Unlocked PCM
Diablo Sport Tuner
HHP Tune
Mopar CAI
Mopar front/rear strut tower braces
Speedlogix SS eliminator
Black lug nuts with Hellcat center caps
Mopar Performance Lowering Springs
Hellcat ram air intake
Hellcat red start button
275 Nittos
Heated/Ventilated seats
Clevetown is offline
post #4 of 13 (permalink) Old 04-17-2019, 02:51 PM
MEKrunner's Avatar
I'm thinking, buy a tuner and get that car married to higher octane gas... Goal accomplished.
MEKrunner is offline
post #5 of 13 (permalink) Old 04-17-2019, 02:57 PM
On a stock 5.7, long tube headers should net ~20HP.
https://www.hotrod.com/articles/bam-...emi-tti-pipes/
FYI the dyno sheets show RWHP not crank HP.
BTW cost will be about $250 for PCM unlock, ~$300-650 for tuner, ~$1200 for headers and ~$250 for tune. Got to pay to play.
ChallyTatum is online now
post #6 of 13 (permalink) Old 04-17-2019, 04:03 PM Thread Starter
RTguy_1961's Avatar
I realize LT will gain more HP, but I don’t want to have to worry about CEL issues or clearance issues. I don’t need a cam as I won’t race it..... just curious about what a few minor mods will do. Thanks all.
post #7 of 13 (permalink) Old 04-17-2019, 04:21 PM
If you run high flow cats and O2 sims you should not have any CEL issue.
O2 Simulators
RTguy_1961 (04-17-2019)
post #8 of 13 (permalink) Old 04-17-2019, 04:50 PM
trippytro's Avatar
Been running high flow cats for almost a year now on my 2016 R/T with stock 02’s and 392 shorties, never once through a code. Maybe im lucky?
trippytro is online now
post #9 of 13 (permalink) Old 04-17-2019, 05:15 PM
Depends on how the tune was setup. Most have the rear O2s deactivated by raising the ECT. This will prevent CEL or DTCs from showing up but it also prevents the emissions O2 monitor from completing. I personally am running with all DTCs enabled, rear O2s enabled and I added O2 sims (just for added measures) and so far all the emissions monitors but the O2s (need to perform the drive cycle) cleared. BTW I went to the IL emissions facility and they told me to come back when my scheduled emissions check is due (end of the year). I was like, why do I have to wait that long and the worker told me it is tied to plate registration renewal dates now. Really?
post #10 of 13 (permalink) Old 04-17-2019, 06:51 PM
trippytro's Avatar
400 hp?
Go figure
I just recently tuned my vehicle i was running the high flows (solo 3” actually made for srt8’s) without a tune and no light
Although i will say, low end felt a little lack luster without the tune
  Dodge Challenger Forum: Challenger & SRT8 Forums > Model Specific Discussion > Dodge Challenger R/T Specific > 2015 to Current R/T & RT Plus Specific
A new heart 392 vs 400 NYRTHEMI Builds 0 12-29-2015 09:15 PM
400 more miles before we head to Topeka!!! drforster General Challenger Discussion 5 06-07-2014 04:48 AM
2010 Furious Fushcia SRT Owners Build Thread 6SPD4ME General Challenger Discussion 67 06-27-2013 12:55 AM
Product Showcase: Menzerna Fast Gloss 400 DetailersDomain Detailing / Car Care 3 11-24-2012 07:45 AM
