What about 275/45R20? - Dodge Challenger Forum: Challenger & SRT8 Forums
2015 to Current R/T & RT Plus Specific This area is for vehicle specific information about the 2015 and beyond R/T and the R/T Plus
post #1 of 21 (permalink) Old 10-01-2017, 10:48 PM Thread Starter
razteo's Avatar
I just bought a 2017 R/T with:
- Super Track Pack
- WRT black wheels 9"
The car came with the 245 tires (see below picture) and I want to go & get the 275's all around.
After searching a bunch of posts on this forum, I still have a couple of questions:
1. Will the 275's fit without rubbing at all 4 corners?
2. Why is everybody here getting the 275/40R20 and not the 275/45R20? The stock tires are just fine on 45, so is there any reason to not go with the 45 on the 275's? WIll they rub on the 45?
Thanks in advance for your answer.
razteo is offline
The Following User Says Thank You to razteo For This Useful Post:
Beachlovers2 (10-02-2017)
post #2 of 21 (permalink) Old 10-02-2017, 04:53 AM
Cuda340's Avatar
The diameter of a stock 245/45-20 tire is 28.68 inches and the revs per mile is 725.22.
When you are buying a larger width replacement tire, you want to try to match these numbers to keep your speedometer accurate.
A 275/45-20 tire will have a larger diameter of 29.74 inches and the revs will be 699.30. This will make your speedometer read slow by 3.71%. A better choice would be the 275/40-20 tire. Its diameter is nearly identical to the 245 tire, at 28.66 inches. Also, the revs are 725.71. In this case, the speedometer will read slightly fast by only 0.07%.
Check out this tire size calculator:
http://www.1010tires.com/Tools/Tire-...ismetric=False
Cuda340 is offline
The Following 4 Users Say Thank You to Cuda340 For This Useful Post:
Mopar Ernie (10-03-2017), razteo (10-02-2017), RWL11 (10-02-2017), TwistedT (10-02-2017)
post #3 of 21 (permalink) Old 10-02-2017, 09:01 AM
Fitment is not an issue. When I went the 270 route there were a lot more choices in the 40 then 45 series locally.
2012 SRT automatic, PB 12.0490 with MT drag radials and trinity 93 octane tune.
maguson supercharger 5.5psi, forged piston/rods, Hellcat injectors, 10/1 compression, tuned for 90 octane. [email protected]
John Matthews is offline
The Following User Says Thank You to John Matthews For This Useful Post:
razteo (10-02-2017)
post #4 of 21 (permalink) Old 10-02-2017, 10:18 AM
chris1992's Avatar
The 40 and 45 number you are referencing is the aspect ratio. This number should not be used alone to determine the height of a tire, the height of a tire is based off both the aspect ratio and tire width. This is why a 245/45 and a 275/40 are nearly identical in height.
(245 x 0.45 = 110.25mm ; 275 x 0.40 = 110mm)
2015 Dodge Viper SRT
Stock
2009 Dodge Challenger R/T A5
SRT8 Brembos, JBA shorties, JBA catless mids, 3" MBRP catback, k&n drop-in filter (with the stock box), 3200 FTI TC, MTCM, blue tops, 275/40/17 M&H Racemasters, and tuned by [email protected] - 1/4 mile PB [email protected]
chris1992 is offline
The Following User Says Thank You to chris1992 For This Useful Post:
razteo (10-02-2017)
post #5 of 21 (permalink) Old 10-02-2017, 10:53 AM Thread Starter
razteo's Avatar
Great info, thank you.
It looks like the 270/40-20 is the way to go then.
So again - no fitment issues with the 275s, no rubbing when turning, or in the rear over bumps, etc.?
razteo is offline
post #6 of 21 (permalink) Old 10-02-2017, 01:08 PM
Discounttiredirect has a feature that lists optional sizes that "fit". I clicked on 265/45-20 and those listed were $202/ea and UP. Ninety (94) options pop up on 275/40-20 starting at $95/ea.
245/45-20
235/45-20
255/45-20
265/45-20
255/35-20
235/40-20
245/40-20
255/40-20
Knukey is offline
The Following User Says Thank You to Knukey For This Useful Post:
razteo (10-03-2017)
post #7 of 21 (permalink) Old 10-03-2017, 01:28 PM Thread Starter
razteo's Avatar
Thank you.
The R/T is at the shop as we speak and 275 Falkens are been installed.
Can't wait!
razteo is offline
post #8 of 21 (permalink) Old 10-03-2017, 01:33 PM
Post a pic.
Knukey is offline
post #9 of 21 (permalink) Old 10-04-2017, 09:35 AM Thread Starter
razteo's Avatar
Here you go, 275 Falkens:
razteo is offline
post #10 of 21 (permalink) Old 10-04-2017, 11:02 AM
I like it.
Were the WRTs original to the car, or added later?
'15 R/T 6M, Billet Silver, STP and no other options.
'74 Duster 360 4 Speed, original E58/D21 car.
DionR is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > Model Specific Discussion > Dodge Challenger R/T Specific > 2015 to Current R/T & RT Plus Specific
