SXT + Brake Upgrades - Dodge Challenger Forum: Challenger & SRT8 Forums
2015 to Current SXT & SXT Plus This section is for discusions about the 2015 and beyond SXT & SXT Plus Challengers
post #1 of 6 (permalink) Old 04-03-2019, 10:58 AM Thread Starter
I have a 2016 SXT Plus with 65k miles on it. OE brakes are doing fine, but I imagine I'll need to replace the pads soon, and when I get that done, I'm thinking of also replacing the rotors with "upgraded" ones. Here's a few questions I have:
1. Was thinking about slotted and/or drilled rotors, but am also hearing of a lot of problems with the aftermarket ones, unless you spend big A$$ money on them and I don't see any need for that on an SXT.
2. Anyone have the new rotors that are all black?
3. What are good rotor companies: Centric, Powerstop, etc.?
TIA
RockanRoll is offline
post #2 of 6 (permalink) Old 04-03-2019, 02:17 PM
MEKrunner's Avatar
I'm watching this. I'm probably not far from a front brake pad replacement.
I have NO complaints about my brakes, but... If anyone knows of an improvement over stock, I'll listen.
MEKrunner is offline
post #3 of 6 (permalink) Old 04-03-2019, 02:45 PM
trippytro's Avatar
No rotor will stay all black as that is just a coating. The center hub will stay black, but as you use the brakes the coating on the rest of the disc will go back to metallic.
I recommend slotted brakes. Those are what give you the extra bite. Drilled not necessary
R1 concepts offers good rotors and a fair price. Tell them u are a forum member they gave me 10% off
trippytro is online now
The Following User Says Thank You to trippytro For This Useful Post:
RockanRoll (04-03-2019)
post #4 of 6 (permalink) Old 04-03-2019, 11:00 PM
Nuke's Avatar
I just replaced all four rotors (and brake pads) on the Bacon Hauler, and I had to do a bunch of research just to make sure I got the correct sized rotors for my particular application (cop brakes are a strange animal; bigger than most but not as big as some, blah, blah, blah). Anyway, I learned a couple things that may of use:
1) the majority of rotors for sale at local auto parts stores are made by just a few companies, despite what name they might be sold under locally.
2) there is a general consensus among self-proclaimed learned individuals on the internet that there is a definite difference between the various levels of rotors in each company's product line, i.e. you really do get what you pay for with brake rotors.
3) it is easier to increase brake system performance by going larger and keeping the fluid fresh than it is by spending more money on the same size and running old/dirty fluid.
The first one up there will come into play if you're shopping around to compare prices. There are a hundred different brands, but if you pay close attention to the part numbers, you'll see some repeating patterns that can be used to identify the equivalent rotor lines between each brand. They'll have nearly identical part numbers, differing by some prefix of 2 or 3 letters only usually.
The second one is a conclusion I reached after reading a heck of a lot of posts on the topic among several different forums. As a general rule, you can assign relative quality among rotors just like they are grouped on RockAuto's website - the Economy line is cheap and most likely to warp or have out of spec runout right out of the box. Daily Drivers are a little better, and so on.
The third is pretty self-explanatory. If you are after a true increase in braking system performance (shorter distance, longer to fade from heat, etc.), increasing the size of the rotors (and pads if necessary) and the number of pistons per caliper is the best way to do it. A more expensive and even higher quality rotor in the same size will not yield as much of an improved performance as going larger.
And no matter what, keeping the fluid changed at the recommended interval is absolutely imperative to an optimally operating braking system, there's no two ways about that one. It doesn't matter if you run DOT3 or DOT4, running fresh is what matters most.
And that's about it. I realize i didn't do much in the way of answering your specific questions, but i don't really have any answers for them. But i did have the info above and figured it could be useful enough to go ahead and post it.
Good luck with the brakes!
Nuke
-- The Bacon Hauler
Nuke is offline
post #5 of 6 (permalink) Old 04-10-2019, 04:48 PM
1FunCar's Avatar
Following out of general interest to the topic.
2018 Challenger R/T
White Knuckle Exterior
R/T Plus Package 28D
Sound Group II
Performance Handling Group
8-Speed Automatic
Power Sunroof
Uconnect 4C Nav
20"x9" Hyper Black Wheels
Red (Brembo) Brake Calipers
1FunCar is offline
post #6 of 6 (permalink) Unread 05-15-2019, 10:13 AM
12rallyeredline's Avatar
Been happy with my recent ebc brake kit don’t get drilled those are prone to cracking. But yes the black is just a coating to keep surface rust off instead of using oil coating. As you can see started black then after a drive it started to take the coating off where the pads rub
ID:	945713   Click image for larger version
12rallyeredline is online now
  Dodge Challenger Forum: Challenger & SRT8 Forums > Model Specific Discussion > Dodge Challenger SE/SXT Specific > 2015 to Current SXT & SXT Plus
Tags
brakes upgrade , drilled slotted , rotors , sxt
Does the GT have different brake setup than SXT? jtrosky Dodge Challenger AWD GT (2017+) 1 03-31-2019 09:56 AM
Hawk Brake Pads (HPS and Ceramic) at PFYC PFYC Vendor Deals 0 12-17-2018 11:25 AM
Racing Brake Carbon Ceramic Brake Kit 2015-2017 Challenger/Charger Hellcat Speedlogix-Sales Speedlogix 1 04-05-2018 11:36 AM
Availble Speaker Upgrades for 2011-2014 SXT Challengers highoutput Car Electronics- Lights, Fuses, Audio & Video 2 12-07-2015 03:21 PM
Premium drilled and slotted, hawks brake pads!!!!!! stevewhiteparts Steve White Motors 5 10-21-2014 07:40 AM
