P3425 Error code - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 5 (permalink) Old 04-23-2019, 11:09 PM Thread Starter
Mubarak AlSanafi's Avatar
P3425 Error code
Hey guys I have a 2012 6.4 srt8 and I suddenly got a P3425 Error code, I took it to the dealer and they didn’t know what was wrong with it so I changed the solenoid sadly that did not solve the issue the dealer told me that I needed to change the camshaft and lifters because of the ticking, I honestly did not believe them, I don’t think I have clogged Oil passages because I change my oil and filter every 5 thousand KMs, could it be a wiring issue? Because my right fog light also stopped
working around the same time. Thanks guys
Mubarak AlSanafi is offline
post #2 of 5 (permalink) Old 04-24-2019, 08:10 AM
One way to deal with a dealer telling you it doesn't know what's wrong with the car is to point out one reason you bought the car was because of the dealer's claims of factory trained techs to properly service/repair the car.
To then take the car in with a OBD2 error code -- which should be documented by Dodge and the dealer should have this documentation -- and the dealer claim to not know what's wrong could be considered consumer fraud. It is not like you brought the car in to an appliance repair business.
Mention that you will be writing the factory headquarters to ask if it has any recommendation on where you can take the car to get it properly serviced as this dealer apparently is incapable of offering the service you were led to believe it would.
Also, mention you are going to get in touch with the county's division of consumer fraud and ask it if you have been a victim of consumer fraud, being led to believe you could get the car serviced at a Dodge dealer only to find out what the time came the dealer apparently just throws up its hands and claims to not know what's going on.
In the meantime, you might find the info at this link of some value:
https://www.obd-codes.com/p3425
Rockster is offline
sr71cbx (04-24-2019)
post #3 of 5 (permalink) Old 04-24-2019, 09:07 AM
sr71cbx's Avatar
Looking at the trouble code description, if you had low oil pressure, it would be clearly visible on the vehicle's gauge readouts. Scroll through and find the oil pressure function and see what it says. My 5.7 hemi usually runs 53 psi at highway speed hot, and may drop to 25-30 psi at idle. The 5W-20 oil used in these engines has less viscous friction than a thicker oil, and the MDS needs the thinner oil to operate correctly. The 6.4L engine does use a 0W-40 oil, however. Is ECM known to be good also?
Bottom line, if you have proper oil pressure, the MDS system should work just fine.......or maybe bad solenoid from dealer? Been known to happen. Rattle their cage about it, their reply of "we don't know what's wrong with it" would elicit a severe negative reactive response from me and that dealership would have my name on it after the civil court case was done. Also what rockster said above is good advice to start with.
If it were me, I'd do the work to change out the MDS lifters and block the passages to them(cylinder head removal required to remove lifters though), and reflash the ECM to shut off the MDS. Manual trans cars do not have the MDS BS in the engine, love my '12 5.& with M6 trans for that reason, one less thing to go wrong.
Keep us posted on results, and, no, it doesn't need a camshaft change!
2012 Challenger R/T w/5.7 6M trans, K&N CAI, Flowmaster American Thunder exhaust.
2014 Chrysler 300C w/5.7 hemi, bone stock(wife's hot rod)
1967 Plymouth Barracuda FB w/modded 340 & 727 TF trans, 3:55 posi axle
2002 beater Toyota pickup
1994 Chevy Suburban K2500 4WD tow rig w/1 ton chassis & 454 engine
2011 Ford Fiesta econobox w/5 spd manual trans
2004 Honda GL1800 Gold Wing, 92,000 trouble free miles
1979 Honda CBX 6 cylinder bike, turbocharged & insane
sr71cbx is offline
post #4 of 5 (permalink) Old 04-24-2019, 09:14 AM
There was a member here that had a bunch of DTC manifest when he replaced his coil packs. One happened to be P3425. It was suggested that a connector in the engine bay may have been the cause which the dealership confirmed there was a short in the connector. Might be worth a check, see post 8 in the thread below.
https://www.challengertalk.com/forum...5=#post8430721
BTW if you go to the online chilton's manual and search for P3425 it gives you the complete walk-thru on how to diagnose the error.
https://www.challengertalk.com/forum...access-666787/
post #5 of 5 (permalink) Old 04-24-2019, 09:19 AM
its a matter of trouble shooting - the code is for cyl #4 deactivation.
could be a wiring issue, the MDS solenoid, or the lifters for that cylinder.
Hal H is offline
