2010 RT ABS module removal?? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 17 (permalink) Old 02-05-2019, 05:14 AM Thread Starter
RTBill's Avatar
Has any removed the ABS module only? 4 screws holding it on, top 2 easy enough, bottom 2 not so easy. The washer fluid reservoir is blocking access to these screws. Just looking for anyone that has removed this that may have a tip. Thanks in advance...
RTBill is offline
post #2 of 17 (permalink) Old 02-05-2019, 07:05 AM
If the reservoir is blocking the screws, then you remove it.
The reservoir comes out from below, so you have to remove the belly pans and work from underneath.
I swapped out a friends reservoir when he had a custom painted one to install in place of the original one
Hal H is offline
post #3 of 17 (permalink) Old 02-05-2019, 07:35 AM Thread Starter
RTBill's Avatar
Was hoping to avoid that, may be just enough room to get an allen wrench in to loosing screws...
RTBill is offline
post #4 of 17 (permalink) Old 02-05-2019, 07:53 AM
If space is that tight, how about when the screws are backed out (bottoming against other items) and then trying to properly tighten them back?
Hal H is offline
post #5 of 17 (permalink) Old 02-05-2019, 08:04 AM Thread Starter
RTBill's Avatar
It's tight in the sense I cannot see the bottom screws, but I think I can get a wrench on them and have enough room to get them backed out, just awkward position trying to loosen something you cannot see. I even thought of cutting the neck off of the resevour and trying to reattach it in some way lol.
RTBill is offline
post #6 of 17 (permalink) Old 02-05-2019, 02:40 PM
FYI - if you don't have a manual here is a link posted by a member for free access to chilton.
https://roswell-nm.gov/1112/Chilton-Auto-Repair-Library
ChallyTatum is online now
post #7 of 17 (permalink) Old 02-05-2019, 07:53 PM Thread Starter
RTBill's Avatar
Thank you very much Challey Tatum, very helpful 👍👍
RTBill is offline
post #8 of 17 (permalink) Old 02-07-2019, 08:02 PM Thread Starter
RTBill's Avatar
The ABS module for the 2010 RT with the 6 speed manual transmission has been discontinued PN 68067398AB NOBODY has it available.
What is the difference between a 2010 and a 2011 or newer ABS module? Why would Chrysler discontinue the one from 2010 for the manual transmission vehicles only? There is a company that says they can rebuild it for $250 but I would rather buy new. Dodge dealer really does not have a reason why it is no longer available. Dealer will take the module off and reinstall it so I can send it out for repairs for $270, which I assume includes recalibrating module if needed. Any thoughts on this??
RTBill is offline
post #9 of 17 (permalink) Old 02-07-2019, 11:38 PM
Worth a look
https://www.amazon.com/Genuine-Chrys.../dp/B00ZR7ZYJ8
https://www.ebay.com/sch/i.html?_sop...rt=nc&_fosrp=1
A Guy is offline
post #10 of 17 (permalink) Old 02-08-2019, 10:35 AM Thread Starter
RTBill's Avatar
The one on Amazon is not in stock, and the one on e Bay is not the right part #. But thank you anyway for your help!! Anyone else have advise??
RTBill is offline
Srs Module removal? TKitterick1 New Member Introductions 8 12-16-2016 10:40 AM
Brake Problem This Cold Morning, Pedal Hard Moparfreaky Challenger Issues & Problems 11 02-28-2016 08:39 PM
ESP bypass modification infernort Performance Modifications 7 10-24-2015 09:49 AM
Dodge Challenger TSB's 2008-2014 Models ResumeSpeed Technical Service Bulletins & Recalls 81 05-06-2015 04:40 AM
