Dash Coming Unglued - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 22 (permalink) Old 08-20-2018, 08:00 AM Thread Starter
Dash Coming Unglued
Good morning. I have a 2010 Dodge Challenger SE. The dash, right above the middle a/c vents is starting to detach. Is there a recommended adhesive that would be good to use to correct this? Any help would be greatly appreciated.
k3c3t3 is offline
post #2 of 22 (permalink) Old 08-20-2018, 08:11 AM
XLRRR8's Avatar
That's a common problem on the older cars. Here's a post relating to this issue...looks like contact cement is the answer.
"There goes the Challenger being chased by the blue, blue meanies on wheels." - Vanishing Point (1971)
XLRRR8 is offline
post #3 of 22 (permalink) Old 08-20-2018, 08:13 AM
When my Fiero dash started to lift, I used Gorilla glue and camps. Still have the car (not in driving condition) and the dash is still holding together.
Although some have suggested loctite glue for plastics (primer and glue system) as it bonds instantly but never tried it.
post #4 of 22 (permalink) Old 08-20-2018, 01:07 PM Thread Starter
Thanks for the help!
k3c3t3 is offline
post #5 of 22 (permalink) Old 08-20-2018, 01:08 PM Thread Starter
Although some have suggested loctite flue for plastics (primer and glue system) as it bonds instantly but never tried it.
Thanks!!!
k3c3t3 is offline
post #6 of 22 (permalink) Old 08-20-2018, 01:42 PM
Nuke's Avatar
I have used regular super glue in the past, and while it worked, I would stop short of recommending it due to its propensity to run off into places you didn't intend for it to go. A gel version of super glue, which I believe the previously referenced Gorilla Glue might be an example of, would be a great fix for this problem though. That is something I would recommend for sure.
-- The Bacon Hauler
Nuke is offline
post #7 of 22 (permalink) Old 08-20-2018, 01:57 PM
VenomX73's Avatar
Ah, the 80's... I remember in 88 I wanted a Fiero so bad.
2017 Challenger RT 5.7 N/A. 1/4 mile 12.37 at 107.93. No cam, headers or stall yet!
VenomX73 is offline
post #8 of 22 (permalink) Old 08-20-2018, 02:00 PM
I bought it in the early 90s for $400 (85 SE 4 speed). Blew the motor, bought a rebuilt motor, slapped a turbo on it and dropped it 1.5". If there was loose change on the road it would bottom out.
VenomX73 (08-20-2018)
post #9 of 22 (permalink) Old 08-20-2018, 02:26 PM
Nuke's Avatar
ATTN Aspiring Linguists: This is a perfect example of the difference between 'literally' and 'figuratively', 2 terms which I hear y'all misusing with frightening regularity.
When @ChallyTatum blew up the motor in his $400 Pontiac Fiero, he figuratively bottomed out. But the resulting Frankenstein of an automobile, with its extreme lowered stance, was prone to literally bottoming out.
Both involve hitting bottom, but only one actually has a bottom and hits it (aka, literally). The other describes reaching the lowest point of the context possible and is more esoteric in nature (aka, figuratively).
Know the difference, learn the difference, use the terms correctly. Your readers will thank you for it!
Nuke, OUT!
(oh yeah, and special thanks to @ChallyTatum for providing this exquisite example for us to use in our lesson!)
Nuke is offline
post #10 of 22 (permalink) Old 08-20-2018, 02:38 PM
Remember this lessen kids...otherwise you won't make the grade.
Tags
dashboard , recommended adhesive , unglued
