Fastest n/a 0-60 mph run v6 challengers - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 15 (permalink) Old 10-25-2015, 10:50 AM Thread Starter
ddeennis's Avatar
Today I just ran a 5.64 in my 2013 challenger, still naturally aspirated, just seeing how this compares to others.
I did run a 5.50 on a slight down hill- but that don't count. I also spun real bad once and my "best" reads 2.30 seconds on the dash.
2013 Challenger SXT 3.6, new 1/31/13, Sprintex S/C 60mm pulley,15lbs boost,BT catch can,180*stat,ported lower intake and TB,custom head tubes,mid pipes/stock cats,Corsa 2 3/4"catback,Htuner TCM,3.90 gear,[email protected] 1.7860ft 2980ft DA
ddeennis is offline
The Following User Says Thank You to ddeennis For This Useful Post:
jgraham70 (01-04-2019)
post #2 of 15 (permalink) Old 10-25-2015, 05:41 PM Thread Starter
ddeennis's Avatar
Out playing with the Intune and WOT spark adding a little more timing right now to try and fine tune the 91 can tune a little.
I ran a 5.60 in 63 degree air
timing was bumped 5 degrees from 1-3.8k and 3 degrees in the other two rpm ranges.
got just a tad ( 2 degrees) of retard at the recovery shift point around 4300 rpms
other then that pretty clean runs, car feels stronger.
ran the car probably about 30 times in simulated 1/4 mile runs to see what the short term knock does had timing as high as 5 more degrees across the board on the tuner.
ddeennis is offline
post #3 of 15 (permalink) Old 10-25-2015, 06:12 PM
eugene3524's Avatar
I got a 5.82 with heavy 20s and bald tires spinning off the line, ********* 93 tune
eugene3524 is offline
post #4 of 15 (permalink) Old 10-27-2015, 05:55 AM Thread Starter
ddeennis's Avatar
Playing with timing, pulled off a 5.57 0-60 mph run with some wheel spin, more then usual, was able to repeat several 5.60 runs.
ddeennis is offline
post #5 of 15 (permalink) Old 11-07-2015, 04:46 PM Thread Starter
ddeennis's Avatar
added a heavily ported lower intake manifold and my own custom TB and I just cut a 5.49 0-60 run in 61 degree air.
The ported lower intake did kill some low end torque, so it helped with traction I was able to launch from 2,000 rpms against the brake with minimal tire slippage.
Next step is to get a custom tune.
ddeennis is offline
djpiezo (11-07-2015)
post #6 of 15 (permalink) Old 11-14-2018, 08:17 PM
This is my best time k&n drop in, flow masters FX, mid muffler reso delete custom tune
smoffler83 is offline
The Following User Says Thank You to smoffler83 For This Useful Post:
mcm95403 (07-07-2019)
post #7 of 15 (permalink) Old 11-15-2018, 06:01 AM Thread Starter
ddeennis's Avatar
Old thread for sure, I got mine down to 5.0 naturally aspirated and then 4.0 with a supercharger.
I stopped after that and sold the car for a 15 SRT392 and the best 0-60 so far in the 392 is 4.3
with many of the runs between 4.3 to 4.8, SRT is so hard to hook. The V6 was just smash and go.
ddeennis is offline
post #8 of 15 (permalink) Old 11-15-2018, 08:33 AM
What else did you do to the v6 NA wise I’m trying to get lower before I throw the sc on lol
post #9 of 15 (permalink) Old 11-15-2018, 11:58 AM Thread Starter
ddeennis's Avatar
3.64 gears did a lot of good, adding 2 3/4" pipe off the cats to the 2 3/4" corsa extreme catback help with top end
power, raising shift points to 7k, elimination of the torque management, adding 220 treadwear rating tires help with
the smash and go. ( drag radials once supercharged to get smash and go hooking traction), ported intake manifold,
ported throttle body, custom cai intake drawing air from fender/front bumper area, messing with the tune- I just had
a 93 can tune and ran 91 octane fuel- played with timing and fuels. There might be other things but nothing special,
pretty much just tinkered my way there. doing things others say don't work, well they was ALL wrong. Got the car to 13.9 at over 100 mph in the 1/4 when I stopped and that wasn't even a hero run, that was like 2800 ft DA so just a normal day at the track, maybe a special day at the track with good weather might have been mid 13's like a 13.6 or so at 102 mph if I would have held out for that good DA
ddeennis is offline
post #10 of 15 (permalink) Old 01-04-2019, 07:12 PM
WazzSXT's Avatar
Did 5.66 with 91 tune, AFE CAI, straight through exhaust from after cats, ported Lower intake, think I can do better, just did one run. Will do a couple next time.
I'll be doing a 91 custom tune soon with HemiFever and ported throttle body coming soon too. New record is with 20" wheels.
2014 SXT - Overkill ported lower intake, AFE Momentum GT CAI, Straight thru pipes (after cats), Valvetronic mufflers with wireless remote, SRT hellcat wheels, Billet tech oil catch can, 91 tune diablosport Trinity T1000, BC Racing BR Type coilovers.
WazzSXT is offline
Why would anyone buy a V6 challenger? pietran30 Dodge Challenger SE/SXT Specific 570 07-02-2015 09:03 AM
Challengers Owners of Las Vegas TOY RUN & LAPS FOR CHARITY LETSJET General Challenger Discussion 0 12-05-2012 10:45 AM
MSH run car issues (Kinda long) Spin2Win West 1 08-13-2012 07:36 PM
