Rear differential upgrade - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 5 (permalink) Old 04-04-2019, 12:57 PM Thread Starter
Gcc
So i have the basic 2017 SXT. Im interested in changing out my rear differential gears to the ones for an SXT Plus. I want that little extra kick from the line without doing a ton of upgrades that i cant afford right now. Going from the 2.62 to the 3.09. Is it just a simple swap of the gears or will i need to change out the entire case or get a special tune to make it compatible? Thanks for any advice!
Gcc is offline
post #2 of 5 (permalink) Old 04-04-2019, 01:42 PM
Nuke's Avatar
As long as the differential you are going to is also an open one (not LSD in other words), you can get away with just swapping out the pumpkins. All the axles and such will remain from previous (current) setup.
The 2015+ cars no longer need to adjust the tune to account for a rear-end change, the car will automatically detect it and be good to go.
-- The Bacon Hauler
Nuke is online now
post #3 of 5 (permalink) Old 06-02-2019, 05:18 PM
Also, as far as I can tell, nobody makes an install kit to just change the gear set. Even the dealers are swapping out the center section vice changing the gears. I ended up swapping my Mettingen one legger with 3.06 for a Getrag posi with 3.73's.
I calculated it up, and if somebody did make an install kit for the Mettingen, by the time you added up the cost of the gear set, install kit, and a posi unit (Wavetrac or Quaife ATB Helical) and everything else, the cost difference between building up the the 215 and swapping out to a Getrag was less than $550. Neither option is exactly cheap, but swapping the entire rear and axles not only gets you the gear set you want, but the Getrag is much stronger.
2012 Challenger SXT+, Tidal Wave Stage 3 Supercharger, 8 LBS Boost Tranzformer'd, Mishimoto catch can, 3:73 Getrag Posi. Best times to date: 0-60 4.20, 1/4 mile 12.96 @ 107 MPH
Demented is offline
post #4 of 5 (permalink) Old 06-02-2019, 07:52 PM
19johned53's Avatar
2015+ gearsets can't be changed. The pumpkins are welded after assembly, so the complete pumpkin has to be changed.
19johned53 is online now
The Following User Says Thank You to 19johned53 For This Useful Post:
Bob Ricewasser (06-02-2019)
post #5 of 5 (permalink) Old 06-02-2019, 11:32 PM
Nuke's Avatar
At the risk of sounding presumptive, I'm guessing you're an old school gear-head from way back (it takes one to know one, right?!?).
A rear-end gear swap is still a valid approach to increasing the low-end acceleration of an under-geared car, but it's no longer as involved as it used to be...which h is a good thing, trust me.
The old way:
You would crack open the rear diff and remove its guts to install some other guts that had a diff ratio. And you better know what you're doing and have all the right tools, or you will end up spilling those guts all over the road the next time you put the hammer down.
The new way:
Ascertain which year models have compatible third members, locate one at a local salvage yard in the desired ratio, block off a weekend to swap out the pumpkins. BLAMMO! You got yourself a lowered geared rear-end to help ease the hangover you got from two straight days of drinking and turning wrenches.
There are some caveats to the new approach, like doing the hubs and axles at the same time if you're going from open to LSD or vice-versa, but that's it in a nutshell. It really is a more straightforward way to do this mod IMHO.
Nuke is online now
Tags
performance upgrade , rear differential , sxt
Question RE: Changing Manual Trans and Rear Differential Fluid SnakeBT6 6.4L / 392ci (2011 - ?) 19 07-26-2016 08:20 AM
Energy Suspension Rear Differential Bushing fhurricane1000 Wheels, Tires, Brakes, and Suspension 0 06-09-2013 07:53 AM
