Well Boys, I've rolled her! - Page 6 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #51 of 60 (permalink) Old 03-14-2016, 08:06 AM Thread Starter
Well boys, here's an update. Remember this though;
Rule #1 - This car has 215,417 miles on it, it's PAID for and it still looks GREAT.
Don't forget that.
That rocker arm clickety clack has been driving me mad for over 100,000 miles and it was getting LOUDER. Well, I had to take care of it so I went over to Amazon on line and bought the rocker arms for both sides and gaskets for the intake plenum and valve covers. About $550 for the whole shootin' match. I finally carved out some time to do it this past weekend and I figured several hours to do the job. I started at 10 AM. Got the plenum off and the drivers side valve cover off by Noon. OK, some sweating and cursing involved but no big deal. Rocker arms come complete. Just unbolt the old assembly and bolt on the new one. That simple. Went to replace the valve cover gasket and realized I'd ordered the WRONG one. 1998-2006 valve cover gasket is NOT the same as the 2007-2010. Silly me. Why I didn't catch that I don't know. Anyway, I had to search around and found a set so after two hours, $42 more and a new set of plugs (I had to do that while I had the thing apart), I got back on the job.
On the passenger side, everything came apart as expected, but then, my luck ran out. See pic. Can lobe on that side is pretty badly gauld from rocker arm free play. So I sat for a while sipping iced tea and nibbling on marshmallow Peeps (Sugar high). What to do? In a perfect world I'd halt the job, order a new set of cams and replace them. More money and more time. In MY world, Rule #1 applies and I've got to have this thing running before tommorow.
So, I installed the NEW rocker arm on the BAD cam and said a Hail Mary knowing this is not a good thing to do. I got everything buttoned up by 10 PM, crossed my fingers and fired her up. She fired right up! She clicked for a split second and settled down to run and quiet as you please. In fact, now she runs so quiet I can hear the "whirrrr" from the alternator. Road test the next day and she runs like a champ. No clicks, nothing.
For how long? Again, refer to Rule #1 . If I make 300K miles, I'll call it good. Oh, during my road test my 11 year old son did me the honor of tagging my car by throwing up in the back seat. Rule #1 ....
Note: When replacing the "Millenium Falcon" intake plenum, tip it back a bit and insert the EGR pipe BEFORE bolting it back onto the intake. Your life will be much easier if you do it that way.
Greg
Greg55_99 is offline
The Following 2 Users Say Thank You to Greg55_99 For This Useful Post:
Debo (12-01-2018), rghoskins (03-25-2016)
post #52 of 60 (permalink) Old 04-03-2016, 07:42 PM
djpiezo's Avatar
Great thread and I also have high mileage on my car as well 136,000 and going.the only issue I have is my rear side markers don't work I've found water inside of both of them replaced both bulbs nothing lights up gotta take it in to the dealership to see if I need new wiring
djpiezo is offline
post #53 of 60 (permalink) Old 04-03-2016, 08:10 PM
Bad daytona's Avatar
Good write up!Waiting for the 300k update.
2012 srt Challenger
2012 SRT Charger
07 SRT 300
2006 Tor Red Daytona Diablo tune,RSAs,,K&N CAI,headers,drilled slotted rotors
1970 RT Challenger 440
1970 Road Runner 440
94 Ram Cummins-44pds Boost,880 lbs tq,Big smoke car killer.
Bad daytona is offline
post #54 of 60 (permalink) Old 04-18-2018, 07:19 AM Thread Starter
Well boys, this is all she wrote. She’s crossed over and it’s time to pick up a new ride. I bought my SE Memorial Day weekend in 2010. Back in those days, Challenger owners would wave to each other because there just weren’t that many on the road then. A whole lot more now! Anyway, I’ve treated her well and she’s treated me well. Never failed to start or not get me to work (her primary mission). And she did it looking REAL good. Some thoughts on things I’ve done over the years.
  • Replaced rocker arms myself. Camshaft on passengers side was gauled and still is. Engine ticks because of that. No effect on performance.
  • On her third timing belt and water pump. First replacement by dealer at 100K miles. Second replacement by me at 200K. Due for another one. Won’t be me.
  • Cleaned throttle body at 220k
  • Replaced air filters every 30K miles.
  • Oil change every 3000 miles (or 21 to 28 days). Included free car wash.
  • Third windshield
  • Second radio
  • Fourth set of tires plus one set of winter treads on separate rims.
  • Third dipstick (they break easy)
  • Replaced headlight bulbs four times.
  • Replaced taillight bulbs four times.
  • Replaced drivers side tie rod.
  • Fifth set of front brake rotors and pads. Second set of rear brake rotors and pads.(All replaced by me)
  • Replaced coolant twice.
  • Replaced spark plugs at 200K.
  • Replaced transmission fluid AND filter twice (At 100K and 200K).
  • Had Diff refilled (was overfilled at shop and caused a leak on the passenger’s side rear axle seal. Still there, don’t care).
  • Replaced blower motor
  • Heater “mixer” not functioning properly. Heat and cooling only comes out of vents when car is on the move. Don’t care anymore.
  • Recharged A/C 230K miles.
  • “Clunk” sound from transmission tunnel when in Drive and stepping on the brake pedal. No effect.
  • After rocker arm replacement, throttle body light and traction control light would come on sporadically. Traced to possible air leak between EGR tube and intake manifold. I smeared silicone sealer around the port. Lights went out and stayed out but still come on once or twice a year. I just pullover, shut down car and restart. Problem goes away. Don’t care anymore.
  • Check Engine light came on last month. Tightened gas cap. Light went out.
  • Power window on drivers side is slower than passengers side.
  • Accessory belt changed with timing belt.
  • Small rust bubble on passengers side rear wheel well.
  • Adjustment knob broke off of drivers power seat
  • Headliner flops down when sunroof is open
  • Still has original battery, starter, alternator,struts, A/C compressor, power steering pump, throttle body, coil packs, steering rack, radiator, thermostat, brake calipers.
  • Needs driver’s side air bag replaced. Recall item. Don’t care anymore.
  • Rubber trim seal surrounding engine compartment and hood came loose. I pulled it off. Don’t care now.
  • Rubber trim seal around trunk is loose. Don’t care.
  • Inside door window trim is cracked on both sides.
  • Wiper blades replaced three times
  • Sunglass' compartment door sprung. Won't open or close properly. Don't care.
  • Wanders a bit going down the road. Requires more effort to keep her in a straight line.
  • Slight buzz coming from dash under the steering column.
  • "Thump" from front suspension when going over bumps and potholes
  • Replaced key fob battery five times in seven years.
I think that’ll flat get it. I’ve been driving since 1973 and I will say, this is the BEST car I have ever owned. Still, it’s time for her to go. I’m thinking about an AWD Charger. My kids aren’t small anymore so I think I need four doors.
Greg
ID:	906778   Click image for larger version
The Following 3 Users Say Thank You to Greg55_99 For This Useful Post:
Bad daytona (04-18-2018), mr.cheez (04-18-2018), Thatguy022 (04-23-2018)
post #55 of 60 (permalink) Old 04-18-2018, 03:55 PM
Slash 392's Avatar
Yeah, I fell for it too. I was expecting to see total chaos and destruction as you spun in at 140mph, did a triple gainer and landed on a Prius. Well, maybe next time. I have a 392 IE with 17k on it now, so I figure I'll roll it sometime in the spring of 2059 or so. I'll be sure to post a picture. Good going on your first successful rollover.
Slash 392 is offline
post #56 of 60 (permalink) Old 11-15-2018, 07:45 AM Thread Starter
Well boys, she ain't dead yet!
She's tired, real tired. I've been trying to pick up a new ride but finding the right Charger Pursuit Hemi AWD has been a challenge. Meanwhile, my baby just keeps on going but she's telling me the end may be near:
  • "PRND" indicators under the tach disappeared.
  • Window is chipped and was fixed
  • Failed inspection - had to replace right lower control arm
  • Left lower control arm is indicating it needs replacement
  • Key fob is acting up. Trunk pops open when putting keys in my pocket. Windows roll down by themselves. Cleaned inside of keyfob but problems have returned.
  • Check engine light comes on periodically. "P03050" code. Misfire on cylinder 5. Possible injector, coil pack or sparkplug problem.
  • All indicators (Lightning bolt, etc) no longer function. It's dark under there.
  • Traction control light came on at low speed in a parking lot and the engine died. Restarted immediately.
  • Low pressure on some tire keeps giving a warning even after I've checked and put air in all tires.
  • Rust spot on rear wheel well is getting slightly larger.
325,000 miles. 2010 SE. Original battery keeps on kicking.
MEKrunner (11-15-2018), raceheart77 (12-15-2018)
post #57 of 60 (permalink) Old 11-17-2018, 02:28 AM
Mud Yapster's Avatar
Greg55_99,
That is awsome mileage and she's stick ticking on rule#1.
I have set a 2018 Challanger on the same path as your DD 100 plus miles round trip per day commute. In 50 miles maybe 5 stop signs to get thru town then 75mph the whole trip. 2 weeks and 1800 miles now. 25 to 35k miles per year we will see how it holds up.
Of course I'm not into rule #1 yet I'm still in the, this car is the nicest car I've ever owned stage. 3 coats of wax on it already. Can't stand it getting dirty phase. LOL
Congrats and keep us updated she's been good to you.
Here's a pic of mine hope she holds up as good as your has.
2017 Maverick XMR 1000R
2014 Palomino Columbia 43' TH
Mud Yapster is offline
The Following User Says Thank You to Mud Yapster For This Useful Post:
Debo (12-01-2018)
post #58 of 60 (permalink) Old 12-14-2018, 11:33 PM
Debo's Avatar
I've rolled her too, yesterday she has completed 1004 km...
2018 Dodge Challenger
SXT Plus
Pentastar 3.6L VVT
Tinted Windows
GoodYear 245/45 R20 99Y
Red Interior
Debo is offline
post #59 of 60 (permalink) Old 06-06-2019, 06:07 AM Thread Starter
Well boys, the end has come. After nine good years and over 347,500 miles I let her go to a new home. I'd had a hankering for an All Wheel Drive Hemi car and finally found a 2019 Dodge Charger Pursuit in Springfield Missouri. The new Charger was in so the Challenger had to go. She was getting tired. I'd replaced the lower control arm on the drivers side, the wheel hub on the passenger's side, got a new battery, wife accidentally backed into the left rear putting a "boop" on the bumper. Thought she'd hold out a little longer but the rocker arms went from a tick-tick-tick to a RAP-RAP-RAP. I knew the passengers side cam was giving up. Pulled the cover to check and yep, it was REAL ugly. With that in mind, I put her on Craigslist and got a hit after a couple of days. I gave the gent that showed up ALL of the info her and showed him pics of the good AND the bad. Didn't want him to be surprised about anything. $4500 changed hands and he drove her away. that's life isn't it? Endings and new beginnings. It's been good boys, but I had to move on. She was the best car I'd ever owned and that's me going back to my first in 1974.
ID:	946855   Click image for larger version
ID:	946857   Click image for larger version
ID:	946859   Click image for larger version
ID:	946861   Click image for larger version
post #60 of 60 (permalink) Old 06-06-2019, 06:11 AM Thread Starter
It's been good boys, but so long for now.
Greg
ID:	946865   Click image for larger version
ID:	946867   Click image for larger version
If any of you fellow 392 boys are curious About the New Pennzoil Ultra 0w40 SRT Oil.. RobF Performance Modifications 1 01-16-2013 05:47 AM
1 Dec 2012 - The Boys & Girls Club Beltway Cruise GreatAmerican Mid-Atlantic 1 11-25-2012 04:05 PM
car is going back to stock and im out, boys and girls. skulls_and_sparrows Dodge Challenger SE/SXT Specific 224 11-13-2012 05:23 PM
Trimmed or rolled fenders anybody? Lv6spd Wheels, Tires, Brakes, and Suspension 0 10-04-2012 07:01 AM
Boys and their toys... Apro4x4 Off-Topic Discussion 13 07-29-2006 02:04 PM
