2009 5.7 and 6.1 Air filter box - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 8 (permalink) Old 06-11-2019, 07:08 PM Thread Starter
AirborneSilva's Avatar
Is there any difference between the 09 5.7 and 6.1 air filter box? I'm trying to find me an in closed CAI for my 09 6.1 and was looking at the Corsa but they say it's for a 5.7 not a 6.1. Thanks for the assist!
Tony
2009 Challenger SRT8 TorRed (AKA Tori)
SRT Max Plus cam, Ported n Polished intake manifold/Heads w/Long Tube Headers by Rich Mack, Edelbrock E-force supercharger, tune by Dave Katz, Cat delete, 3" exhaust w/Magnaflow mufflers 180* T-stat, catch can, Hurst short throw w/pistol grip shifter, Amsoil fluids
AirborneSilva is offline
post #2 of 8 (permalink) Old 06-14-2019, 05:27 PM
McCloud's Avatar
Typically those are interchangeable, I can't think of a reason why it wouldn't fit.
Sent from my SM-T350 using Tapatalk
McCloud is offline
post #3 of 8 (permalink) Old 06-15-2019, 07:26 AM Thread Starter
Thanks for the reply, looking at pictures of the two it seems as though they are the same but I did lookup part numbers and they are different. If I could find a stock 5.7 air box I'd like to try it before spending the money. Thanks again for the reply!
post #4 of 8 (permalink) Old 06-15-2019, 08:48 AM
McCloud's Avatar
Try the parts wanted section of the forum. I personally stuck with the stock air intake and just added a high flow air filter. The performance of the stock airbox/intake is hard to beat. You may want to save some money and just go that route. I do like the look of the Corsa/Volant CAI though. They did a nice job with that one.
McCloud is offline
post #5 of 8 (permalink) Old 06-15-2019, 12:47 PM
19johned53's Avatar
The 6.1 air box bottom has a larger opening at the bottom/side than the 5.7. It will flow more and they will interchange with no problem.
The tops will not interchange.
19johned53 is online now
post #6 of 8 (permalink) Old 06-15-2019, 05:54 PM Thread Starter
If it wasn't for my supercharger I'd look into finding a stock setup and modify it for more airflow and line it with heat shielding, I agree they Corsa/Volant's look like a nice setup and they've already modified it like I would for more airflow coming from the grill area. If I go with one of them I'll line the inside with some heat shielding to keep as much of the engine bay heat out as is possible.
Thank you, looking at the two I couldn't see any difference but it does make sense that that he openings would be smaller.
post #7 of 8 (permalink) Old 06-18-2019, 08:15 PM
Hawkeye75's Avatar
I recently installed the Hellcat lower air box, AFE Headlight tube, and AFE filter. Not sure if it will fit older models. http://www.speedlogixstore.com/produ...x-hc-abita.htm
Hawkeye75 is offline
post #8 of 8 (permalink) Old 06-18-2019, 08:35 PM
19johned53's Avatar
Nope, '15+ models only.
