is 85mm throttle worth it ? - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 19 (permalink) Old 05-08-2019, 09:38 AM
trippytro's Avatar
Originally Posted by The Perp View Post
You're guaranteed to see more gain than spending 1 or 2 grand on aftermarket wheels...😂😂😂. If you threw a cam in already then why not dress it up, just do it for the prospect of a better response and you won't be sorry.
I mean, slicks and lightweight wheels i feel would get you a lot further than a throttle body...lol
trippytro is offline
The Following User Says Thank You to trippytro For This Useful Post:
Ronan978 (05-08-2019)
post #12 of 19 (permalink) Old 05-08-2019, 11:05 AM
cdahl383's Avatar
Yes it is worth it. But you have to get the right one. The popular MM 87mm TB does nothing but give better throttle response. The Fastman 84mm TB will give you better throttle response AND a performance increase.
I noticed a small gain at the track with the Fastman over stock or MM. Less than a tenth, but on average my passes were faster, as well as with higher MPH.
The Fastman 84mm is actually a larger bore TB, whereas the MM is still 80mm like stock in the center. I bought a used TB off of a forum member here a while back, shipped it off to Dan at Fastman, had him work his magic, and he sent it back a couple weeks later.
If you've already got bolt ons and a cam, you would definitely pick up something. You may need to adjust your tune though after the install. Talk to your tuner about that.
Carl
Dragstrip videos:
cdahl383 is offline
post #13 of 19 (permalink) Old 05-08-2019, 11:08 AM
cdahl383's Avatar
Sticky tires and lightweight wheels are worth a drop of 80lbs of rotational weight and probably .15 or so off your ET. My car picked up nicely at the track after swapping the Racestars on over the stock heavy 20x9's. I have about $1600 into my wheels with tires and everything. If you buy the wheels when they're on sale you can get them pretty cheap. Or find a set of used ones.
cdahl383 is offline
post #14 of 19 (permalink) Old 05-08-2019, 11:16 AM Thread Starter
wkz
is it lightweight rims 20x9? Cause im thinking to remove back seats and even the passenger seat so im planning to get 20x9 rims is good ? To lightweight
wkz is offline
post #15 of 19 (permalink) Old 05-08-2019, 12:00 PM
us1champ's Avatar
Feedback Score: 10 reviews
Originally Posted by wkz View Post
Where can i find a tb 85mm with upgraded butterfly plate.? Can you link the direct page
https://www.a2speed.com/c-299-hemi-throttle-body.aspx
2009 SRT
CUSTOM HEAD RESTS
us1champ is offline
post #16 of 19 (permalink) Old 05-08-2019, 12:45 PM
Clevetown's Avatar
I have an Arrington 84mm throttle body in my car as well.
2015 Scatpack 392 M6
Black/black
Stainless Works LT Headers
High flow cats
Resonator delete
274 Comp Cam with vvt limiter
Arrington 84 mm throttle body
Barton short throw shifter
Unlocked PCM
Diablo Sport Tuner
HHP Tune
Mopar CAI
Mopar front/rear strut tower braces
Speedlogix SS eliminator
Black lug nuts with Hellcat center caps
Mopar Performance Lowering Springs
Hellcat ram air intake
Hellcat red start button
275 Nittos
Heated/Ventilated seats
Clevetown is offline
post #17 of 19 (permalink) Old 05-08-2019, 05:53 PM
Rob446's Avatar
you buy new throttle from him or you sent your tb to him ?
Sent my TB to him when I was going on vacation. By the time I got home the TB was on it's way back.
Rob446 is offline
post #18 of 19 (permalink) Old 05-08-2019, 06:01 PM
Rob446's Avatar
For sure a set of DR's and lighter wheels will give a bigger return than a TB but the investment is much larger also. I see a lot of cars struggling at test and tune without Drag tires, they would have a lot more fun and go much faster with DR's.
Rob446 is offline
post #19 of 19 (permalink) Old 05-09-2019, 09:52 AM
cdahl383's Avatar
Stock 20x9 wheels & tires - 60lbs each
Rear 17x9.5" Racestars and M/T drag radials - 48lbs each
Front 17x4.5" Racestars and M&H front runners - 32lbs each
Front passenger seat - 55lbs
Rear passenger seat - 45lbs
Trunk floor liner - 15lbs
Trunk tray & compressor - 10lbs
Floor mats - 7lbs
Just to give you some hard numbers.
I wouldn't go with 20" wheels if you're looking to shed some weight. I'd go down to 17-18".
cdahl383 is offline
Speedlogix Ported Throttle Bodies-V6, 5.7, 6.1, 392 SRT8U Speedlogix 45 01-06-2015 09:36 PM
Review: Intune Diablosport on a 392 Challenger rayzazoo General Challenger Discussion 25 05-22-2014 11:16 AM
Bbk 85mm throttle body pbwin Performance Modifications 0 07-03-2013 06:47 AM
