Best Headers for 5.7 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 29 (permalink) Old 05-01-2019, 08:23 PM Thread Starter
Bluestreak5.7's Avatar
Hi guys - I have a 2014 RT and I want to add some headers to complement the corsa sport I added about a month back. Almost exclusively a street car but do like like to get on it when I find an open road. Also looking for a nice healthy rumble at idle. I suppose my first question is do I go with shorty’s or LT’s?
Bluestreak5.7 is offline
post #2 of 29 (permalink) Old 05-01-2019, 10:30 PM
Newoldchallenger's Avatar
If you can go with longtubes (state inspections and crap) go that way. Shorties don’t give a great gain for the price and effort involved.
Unless you plan on doing major work down the line, stick with 1 3/4 or 1 7/8” sizes.
Two good brands: American racing headers and kooks
If you need a budget brand: jba (what I have on my Challenger but they didn’t make as much hp as the others will), still great sound though.
2013 Challenger R/T Automatic
Newoldchallenger is online now
post #3 of 29 (permalink) Old 05-02-2019, 04:56 AM
Frank Julian's Avatar
What is your opinion on Stainless Works?
Frank Julian is offline
post #4 of 29 (permalink) Old 05-02-2019, 06:24 AM Thread Starter
Thanks Frank. Do you know anything about the Corsa LT Headers? Just wondering if it might be better to stick with same brand as my catback to optimize the fit.
post #5 of 29 (permalink) Old 05-02-2019, 07:06 AM
I really do not know too much, I only asked about Stainless Works because they sell complete systems, their redline set up sounds awesome, and they are located in Ohio (Same state as me). I like to support local people but I do hate paying sales tax on big ticket items.
post #6 of 29 (permalink) Old 05-02-2019, 08:42 AM
I run SW headers and have no complaints. Their setup uses adapters between the mid pipes and cat-back. The mid pipes are 3" but the adapters can fit 2.5", 2.75" and 3" cat-backs. Every connection is slip fit (just like the OEM mid to cat-back connection) so there is no flange between the header collector and mid pipe (or cats). If you want air/water tight connections you do need to smear a little high temp silicone in the connections. They don't give you gaskets...just bolts and a tube of high temp silicone (run OEM gaskets instead). The bolts are holding up for me. I have run several hundred miles and bolts are still torqued down.
If you are getting long tubes, make sure you have a shop well an extra bung so you can run a wide band.
https://www.challengertalk.com/forum...409-post5.html
https://www.challengertalk.com/forum...865-post7.html
ChallyTatum is online now
Frank Julian (05-02-2019)
post #7 of 29 (permalink) Old 05-02-2019, 08:51 AM
Supporting Vendor
stevewhiteparts's Avatar
Feedback Score: 6 reviews
best scenario for 5.7, take off 6.4 manifolds and mid pipes
Luke
PLEASE VISIT
828-324-4410
800-779-3634
stevewhiteparts is offline
The Following 2 Users Say Thank You to stevewhiteparts For This Useful Post:
sr71cbx (05-03-2019), trippytro (05-02-2019)
post #8 of 29 (permalink) Old 05-02-2019, 08:54 AM
The only experience I have with SW is on my buddy’s camaro. They looked like decent pieces and were slightly cheaper than the other big brands but they had some clearance issues.
We had to bang in one of the tubes a bit to clear the steering column and after both sides were on, they didn’t mate up great to the stock exhaust. Beyond that they were great on his application. He picked up about 15hp across the rpms when he had it dynoed.
post #9 of 29 (permalink) Old 05-02-2019, 08:55 AM
Luke
Yeah, but on the pre-2017 challengers the 5.7 have a smaller cat-back pipe diameter...so some modification of the 6.4 mid pipes is required.
post #10 of 29 (permalink) Old 05-02-2019, 08:59 AM
yeah JBA Cat4ward Headers might be a better choice, if you don't want long tubes.
Some thoughts on long tube headers. dreaded_hope Intake & Exhaust 12 09-19-2018 10:10 PM
BBK Performance 1 7/8 Shorty Headers Challenger/Charger/300/Magnum 6.1L/6.4L/392 Speedlogix-Sales Speedlogix 0 01-18-2018 09:12 AM
