Does my '16 R/T A8 have MDS exhaust valves? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 19 (permalink) Old 04-16-2019, 07:30 PM Thread Starter
Hello,
I'm ordering a Borla S exhaust system for my 2016 R/T Challenger with the automatic tranny. The Borla website has 3 different S-type models to choose from. It was always my understanding that an automatic transmission Challenger with 5.7L V8 had MDS. Is this assumption correct? If it is, do all MDS cars come with MDS valves? If not, how do I tell whether I have MDS valves? My car is in winter storage right now so it's not easy for me to just go and look. Does anyone have a picture of what the stock exhaust system MDS valve looks like? Also, where are the MDS valves located under the car? When I called Borla to ask the questions above they said, "No, you cannot actually assume anything on this vehicle. We cannot understand the metrics on how Mopar decides to equip these vehicles." Why is this so complicated?
2016-2018 Challenger 5.7L with Cylinder Deactivation (MDS) valves, Automatic/ Manual Trans., Rear Wheel Drive, 2 door.
This system is designed for vehicles equipped with MDS (Multi-Displacement System) valves. It includes replacement valves.
https://www.borla.com/products/chall...t__140713.html
This system is designed for vehicles equipped with MDS (Multi-Displacement System) valves. It features valve simulators rather than valves.
https://www.borla.com/products/chall...t__140715.html
2015-2018 Challenger R/T 5.7L W/O MDS (Cyl. Deactivation) Valves Automatic/Manual Trans. Rear Wheel Drive 2 Door.
https://www.borla.com/products/chall...t__140627.html
Lbftpsec is offline
post #2 of 19 (permalink) Old 04-17-2019, 12:59 AM
Still very surprised Borla has never corrected this. MDS is part of the engine, cylinder deactivation, there are no MDS valves on the exhaust. They are talking about Active Exhaust Valves (AEV). The 2016 RT did not have AEV (RTs do now though, starting with 2017). Their 3 choices are system for cars without AEV (yours), system that has valves from Borla, for cars that had valves stock, and system that has valve simulators (tells the engine that your valves are working, even though they are not, eliminates valves), for cars that had valves stock.
A Guy is offline
post #3 of 19 (permalink) Old 04-17-2019, 05:48 AM Thread Starter
Thank you for your reply. So you're saying the only choice for my order is 140627 because I do NOT have these valves in my exhaust system?
Just to ensure that we're on the same page here, are you sure there isn't a difference between an MDS valve and an AEV valve? I have a 2017 Silverado that has valves which open and close so that you don't notice the sound change over from V8 to V4 mode. I would have assume that in my case, this is an "MDS" valve.
Lbftpsec is offline
post #4 of 19 (permalink) Old 04-17-2019, 02:31 PM
Jazz Blue Scat's Avatar
You do not have the active exhaust but your car does come with MDS. You are talking about two different things.
2017 Challenger T/A 392 Redline Tri-Coat
Leather Interior Group
Driver Convenience Group
Sound Group II
TorqueFlite Eight-Speed Automatic Transmission
Power Sunroof
Black Hood Pins
Uconnect 8.4 Navigation
Jazz Blue Scat is offline
post #5 of 19 (permalink) Old 04-17-2019, 02:37 PM
Active exhaust for the RT 5.7 was only added to the +2017 models and that was the year they started using 2.75" exhaust. If you zoom in on the others you can see the active exhaust valves and active exhaust valve simulator. 140627 does not have this which is what you want. Although, you might able to get away with 140715 (not sure if the mid pipes will bolt up to 2.75" pipe) as they just have the AE simulators (bracket that allows AE solenoids to be mounted but does not control an actual valve).
Name:	no active exhaust.JPG
post #6 of 19 (permalink) Old 04-17-2019, 02:59 PM Thread Starter
I just heard back from borla tech support. They said, “AEV and MDS are the same thing. If you want to be sure, just go look at your exhaust system.”
At this point I’m a little confused. Why does Borla themselves say that these are the same thing!? I know for a fact that MDS valves and AEV valves are different and that their terms cannot be used interchangeably. Am I missing something here? I’m going to go and check my car in storage to see what I have, but fundamentally I don’t really get why this purchasing process has been so difficult!?
Now, would the system with AEV valves sound different than the system without valves? I’m used to AEV exhaust on GM cars which gets louder above something like 3000 rpm. Is this the same thing? Could I wire the valve on the 140713 system into a simple switch in the cab to make the exhaust quieter or louder on demand?
Lbftpsec is offline
post #7 of 19 (permalink) Old 04-17-2019, 03:04 PM
It is not the same thing. MDS is Multi-Displacement System (it deactivates cylinders by collapsing the lifters on 4 of the 8 cylinders) which has been on the 5.7 since it came into production. AEV Active Exhaust Valve (controls a valve between the mid muffler and resonators) was only available on the Challenger 5.7 starting from +2017.
I think Borla is confused, my 2013 JGC 5.7 actually has valves (they are not controlled by the PCM, just has a torsion bi-metal spring) in the exhaust to help with MDS operation. The challenger 5.7 never had this.
As for adding AEV to a non-AEV challenger...not sure if it is possible. For starters you would need a new wiring harness and enable AEV in the tune. More of a headache than it is worth. Besides, everyone seems to go the opposite direction in that they want to disable AEV.
Funny that Borla did not mention anything about the difference in pipe size?
post #8 of 19 (permalink) Old 04-17-2019, 06:14 PM Thread Starter
Great response Chally Tatum. I agree with everything you’ve said. I have the MDS valves with the torsional springs in the exhaust system of my Silverado.
As for the AEV valves on the Borla exhaust, can you clarify what these are for? Are they for allowing a greater exhaust note when you’re heavy on the throttle, and for reducing the noise when you’re highway driving, or is it for something else. My suggestion earlier about wiring in a switch to these valves should be taken literally. I don’t want to tie these into my PCM as my 2016 had no provisions in the harness for it. What I would like to do is have manual control over the valves, similar to how you can control them on the OEM C7 Corvette exhaust system. You can open them up for the track, or you can leave them closed in “stealth mode” when you don’t want to wake everyone up in your neighbourhood at 5am or to reduce highway drone. If this is what the AEV valves are meant for I may buy them anyway and then just mount a simple toggle switch in the cab which opens and closes then like cutouts. Thoughts?
Lbftpsec is offline
post #9 of 19 (permalink) Old 04-17-2019, 06:36 PM
Tshane72's Avatar
There was another post somewhere here on the forum with a link to a website for a company that either makes the active exhaust valves you can install into a system like yours that came without active exhaust...or it was a complete cat-back system with active exhaust somehow...maybe someone else can chime in here about that. But I know there are a couple aftermarket systems out there supposedly that you can add active exhaust to older Challengers. Anyhow, hope you get it all figured out soon. I have a Borla s-type system on my car and love it...but I'm surprised Borla tech-Support is that confused about your question.
Tshane72 is offline
post #10 of 19 (permalink) Old 04-17-2019, 06:53 PM
The active exhaust is all about controlling sound. I for one am glad my 2015 does not have it...one less thing to fail. Like I said a lot of folks that have it try to delete it.
https://www.torquenews.com/106/all-2...l-mode-exhaust
Challenger SRT 392 Scat Pack Borla Exhaust Touring #140676 @ PFYC-PartsForYourCar PFYC Vendor Deals 6 03-28-2019 11:06 AM
Solo Performance 2015+ Challenger 5.7L R/T Mach XV-CH-RT Catback Exhaust GOINGSOLO2 Solo Performance 10 05-26-2017 08:13 PM
Recommendation needed for exhaust for '15 R/T with MDS! 6SpeedR/T Intake & Exhaust 26 01-18-2015 12:45 PM
'09 Challenger R/T Gathered Specs / Equipment & Info Related SIX-PAK Dodge Challenger R/T Specific 150 10-19-2014 02:38 AM
