Driveshaft - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 20 (permalink) Old 05-28-2019, 08:53 PM Thread Starter
Driveshaft
I put a custom exhaust on my car and I plan on getting an aftermarket like a borla or something performance instead of noise. My muffler was slightly rubbing on my driveshaft so now I’m looking to get a new upgraded driveshaft and performance bolt on exhaust on my 2015 3.6 challenger SXT any suggestions???
Matt2010 is offline
post #2 of 20 (permalink) Old 05-28-2019, 10:51 PM
I have the Solo Mach XV-CH for almost 12,000 miles. No issues with clearance with stock driveshaft. Pictures taken during install
A Guy is offline
ChallyTatum (05-29-2019)
post #3 of 20 (permalink) Old 05-29-2019, 07:47 AM
If your OEM driveshaft is rubbing your exhaust I don't see how getting an "upgraded" (do you mean 1" piece...if so it will make it worse) driveshaft will help?
On my RT I run a 4" one piece drive shaft and corsa extreme exhaust...I barely have ~3/8"" clearance from the mid mufflers but I get absolutely no rubbing...and that was before installing the diff brace which helps limit driveshaft movement as the pinion side of the diff does not move as much. I had to mess around with the rubber hangers to get the exhaust to droop just right...otherwise I would have had to pound on the mufflers for clearance.
@A Guy ...woah that under carriage is uber clean...do you wax the bottom as well?!
ChallyTatum is online now
post #4 of 20 (permalink) Old 05-29-2019, 09:11 AM Thread Starter
It’s rubbing because when it was welded and put in my uncle didn’t leave enough clearance for the driveshaft so now it’s rubbing on the muffler and we fixed it temporarily but now it’s to the point where I’m sick of messing with it
Matt2010 is offline
post #5 of 20 (permalink) Old 05-29-2019, 10:04 AM
I would say your only option is to pound on the mufflers until you have enough clearance or heat the pipes so you can bend them away from the driveshaft. You most likely will need to disconnect the system at the mid-pipe connection to give you room...or use an air chisel with a blunt or "soft" tip.
Otherwise you could try to shim the diff but that is way more trouble than it is worth.
post #6 of 20 (permalink) Old 05-29-2019, 10:05 AM Thread Starter
I really want to just get a performance exhaust because theres some minor imperfections on the one me and my uncle fabricated and I’m looking HP wherever I can find it
Matt2010 is offline
post #7 of 20 (permalink) Old 05-29-2019, 10:08 AM
Frank Julian's Avatar
You won't find power from a cat back, you'll only find noise!!!
Frank Julian is offline
The Following User Says Thank You to Frank Julian For This Useful Post:
Cominfromcamaro (05-30-2019)
post #8 of 20 (permalink) Old 05-29-2019, 10:09 AM
^^^what he said. Now if you go long tube headers (or even shorties)...that is a different story.
post #9 of 20 (permalink) Old 05-29-2019, 12:16 PM
Lol, that was just under 600 miles when I had exhaust installed. Not had that view since. Shiny on top has been my focus, lol
A Guy is offline
post #10 of 20 (permalink) Old 05-29-2019, 04:15 PM
I had almost the same problem. I went to a custom muffler shop and they weld a elbow to both sides and solved my problem.
guardi is offline
