Cooling fan operation - Dodge Challenger Forum: Challenger & SRT8 Forums
Engine Bay / Under Hood Modifications This area is for the discussion of and to show off your engine bay/under hood modifications.
post #1 of 14 (permalink) Old 01-02-2019, 11:35 AM Thread Starter
Nuke's Avatar
The cooling fans that bolt to the back of the radiator and pull air through it are NOT variable speed. They are either on and turning full speed or off and not turning at all (under their own power.
Can anyone confirm my assertion there?
That is what I believe to be the case, but recent observations would seem to invalidate it, so trying to clear things up.
-- The Bacon Hauler
Nuke is offline
post #2 of 14 (permalink) Old 01-02-2019, 12:00 PM
yes - single speed fans.
I don't know if the ones that have dual fans (does Pursuit Package have dual fans? @Nuke )
On my last GM vehicle - it had dual fans.
The primary one ran with A/C and 'regular' cooling needs. If the coolant temp got higher yet, it would kick on the 2nd fan as well for additional cooling.
the Challengers with 6.1 / 6.2 SC / 392/6.4 engines have dual cooling fans - part of the Severe Duty II cooling system these are equipped with
Hal H is online now
post #3 of 14 (permalink) Old 01-02-2019, 12:10 PM Thread Starter
Nuke's Avatar
Yep, dual fans in the shroud that bolts to the radiator.
At the moment the coolant temp won’t get over 192F, and when I directly observe the fans, they are both spinning, albeit at a very slow speed. I cannot hear them spinning anyway, which is the opposite of what I am used to.
Normally when they kick on, there is no doubt they are energized and spinning, as the noise is unmistakable.
Starting to wonder if removing and reinstalling that unit 8 times was one time too many, and now it needs to be replaced...
Oh well, if it does, I bet I can do the job in no time flat, as I am well versed in extracting that puppy with everything still in place on the engine!
Nuke is offline
post #4 of 14 (permalink) Old 01-02-2019, 12:22 PM
you could block the front of the radiator with cardboard (vehicle stationary) to reduce airflow to get temperature up higher to see what happens
Hal H is online now
post #5 of 14 (permalink) Old 01-02-2019, 12:27 PM Thread Starter
Nuke's Avatar
I’m thinking I will use my tuner to lower the temp at which the fans should engage to see if any change. If not, I can unplug the assembly and test the wiring harness plug voltages just to be sure.
The ambient temps here are currently hovering around 32F thankfully, so the fans aren’t really needed to keep it cool. But this weekend will bring 70F, so I gotta get this figured before then.
Nuke is offline
post #6 of 14 (permalink) Old 01-02-2019, 12:38 PM
Gila Hemi's Avatar
What exactly is the problem you're having anyhow? With the pursuit package your Charger should have much more cooling capability than stock as far as I know.
Member:
Gila Hemi is offline
post #7 of 14 (permalink) Old 01-02-2019, 12:50 PM Thread Starter
Nuke's Avatar
I have not heard the fans kick on since I reinstalled the fans last night, despite reaching normal operating temp several different times since. I can see them moving, but not so fast as to make a loud whirring noise like I am used to.
No overheating, temps are fine, but I am concerned the assembly is not working as it’s supposed to now, for whatever reason.
Nuke is offline
post #8 of 14 (permalink) Old 01-02-2019, 01:23 PM
Gila Hemi's Avatar
I do not know if our fans have an external controller like after-market e-fans do, but I doubt it. It sounds to me like the problem is in the PCM, but I don't have any wiring diagrams to really make an educated stab at a solution. I have an after-market fan on my Ram that only runs at one speed, and the controller for it has a dial to adjust the temperature to activate the fan. I have the controller mounted on the frame above the radiator, and switched power going to the fan that is cut off with the ignition switch to keep the fan from draining my battery with the engine off. It gets hot enough here for the fan to come on by itself when my Moose is parked.
post #9 of 14 (permalink) Old 01-02-2019, 01:34 PM Thread Starter
Nuke's Avatar
I’m leaning toward the fans’ controller in the assembly being hosed. When draining the previous radiator yesterday, the drain valve got stuck in such a position so as to cause the coolant to spray out several inches, and as I turned the valve with my screw driver, it was hiding down everything within 8 inches in the engine bay like some kind of hot coolant sprinkler.
I am wondering if that caused a problem in the controller when it next energized.
Ugh, I feel like I could get this figured out in 30 minutes if I could just go home and get started. But instead of doing something useful like that, I am stuck on a conference call that is headed into it’s 3rd hour now with no signs of ending before 4pm.
I HATE CONFERENCE CALLS!!
They are evil, boring, and the unholy spawn of the Devil and something else that is bad...
Calgon, take me away!!
Nuke is offline
post #10 of 14 (permalink) Old 01-02-2019, 01:53 PM
Gila Hemi's Avatar
The controller should be a completely sealed unit, but if there are exposed wires anywhere in the system, a short would fry it for sure.
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Engine Bay / Under Hood Modifications
