Carbon Build-up? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 10 (permalink) Old 04-17-2019, 08:27 PM Thread Starter
Carbon Build-up?
New Challenger owner here.
Bought a used 2014 Challenger in January with a little more than 40k miles on it. Beginning of March, got a Cylinder #2 misfire code, and took it in where they replaced the ignition coil. Three weeks later same message about cylinder #2. This time they took the engine apart and told me there was a ton of carbon build-up in cylinders 2, 4, and 6. They are cleaning it out.
What causes this, and how do I prevent it in the future?
Thanks,
Tim
timg is offline
post #2 of 10 (permalink) Old 04-17-2019, 09:10 PM
Welcome to the forum. A catch can would help capture oil mist that makes its way to the intake from the PCV valve. Also I think the pre-2015 engines ran copper spark plugs which had a replacement schedule of every 30k miles. The new models ran iridium plugs which had a much longer service interval.
Flat Top (04-17-2019)
post #3 of 10 (permalink) Old 04-17-2019, 09:40 PM
Flat Top's Avatar
The carbon could of been removed without taking the motor apart. Run sea foam through the intake slowly so you dont hydrolock the motor. Simple to do btw. It will smoke and stink for 20min of running and be just fine.
A catch can reduces 70% of the issue.
I ran 2 catch cans but I was under boost and juice with a large ring end gap. :}
FlatTop
Flat Top is offline
post #4 of 10 (permalink) Old 04-17-2019, 11:59 PM
Nuke's Avatar
Thanks,
Tim
What engine and who did the work?
If it is the 3.6L, there is a known problem with the cylinder heads which causes this, and Dodge will fix it for free (by replacing the cylinder head). That's why I asked where the work was done. If it was not done at a dealership service department, they may not know about the TSB on the cylinder heads (assuming it is a 3.6L).
If it is a Hemi engine, none of what I just said applies, so please disregard everything I said...in fact, please forget I was ever even here (especially if men in black suits come asking about me).
-- The Bacon Hauler
Nuke is offline
post #5 of 10 (permalink) Old 04-18-2019, 06:02 AM
Oh, could it be the valve stem seals? I have seen guys with hellcats complain about excessive blue smoke at start-up which some suspect the valve stem seals.
post #6 of 10 (permalink) Old 04-18-2019, 08:56 AM
Bad valve stems seals would not result in smoking at start up as the cold oil would not make it past the seals. The engine would smoke at other times, though, after it was warmed up.
Most likely cold start smoking is just a bit of residual oil in the intake that collected there due to the oil vapor recovery "system" in the engine being inefficient. Modern engines tend to generate much more oil vapor generation and this can overwhelm the mechanism which is intended to remove this.
Even so I would not fit a catch can to the engine. The occasional bit of cold start smoking is harmless and its tendency to appear can be addressed by other means some of which call for better engine maintenance which can only help extend engine service life.
Rockster is offline
post #7 of 10 (permalink) Old 04-18-2019, 09:19 AM
https://dannysengineportal.com/valve-stem-seal/
https://www.bobistheoilguy.com/forum...Number=1240175
https://www.freeasestudyguides.com/a...lve-seals.html
post #8 of 10 (permalink) Old 04-18-2019, 09:34 AM
Thanks,
Tim
Barring the possibility the engine has a known problem in this area, which Nuke mentioned in his reply, some combustion chamber deposits are "normal".
Even so some types of usage can reduce these. I came across a Porsche engine with a broken valve spring. The head was off. The combustion chambers were visible and I noted how clean they were. So clean I thought the tech might have cleaned the head. He said he had not cleaned the head the chambers were that way because of how the car was driven. It saw a good number of highway miles per day and this sustained running at some mid range RPMs helped keep the chambers very clean.
In some way over the years I have experienced this. It was my habit to take long road trips once in a while. I'd head out and drive my car and after 100 or more miles of highway driving stop for gasoline. Quite often I'd notice how much better then engine was running. The long drive really perked up the engine. My suspicion this was the result of deposits that had built up from the day to day usage I had subjected the car to being "burned" away, or removed via the gasoline's cleansing properties, from the prolonged running.
Now in some cases my day to day usage was not that bad. For instance my work commute is 30 miles and often 25+ miles of this consists of freeway driving. I had thought this was sufficient to keep engine deposit build up down.
But a few years back I had need to drive 50 miles to a hospital to visit a family member. I was rather surprised to note even this bit (100 miles) of extra highway usage had the engine running markedly better.
OTOH, a car driven around town, with the engine seldom if ever getting a prolonged run at highway speeds, and if the oil is not changed on schedule, or possibly more often (which could be justified due the usage the engine is subjected to) could have the chambers loaded with deposits. The selection of gasoline can play a role. More on this below.
Misfires due to deposit build up suggests severe build up. Normally to address less than severe build up I would have recommended a treatment or two (or 3) of Techron, which I know from experience can make a difference. For instance some few years ago I switched from Shell V-Power to Chevron Supreme and after not even a tank of Chevon Supreme gasoline one of my car engines was running noticeably better, as if I had taken it on a 100+ mile highway drive.
As for other methods of removing engine deposits, I do not like to put anything in the intake that is intended to remove engine deposits. This stuff can wash the oil from the cylinder walls and the risk is piston and ring and cylinder wall damage can happen.
If the deposits can be removed by some cleaning action then my advice is to use Techron, maybe resorting to several treatments in a row.
(There was a technique taught to me: With the engine up to temperature and with a helper holding the throttle so engine RPMs were elevated -- but not real high -- use a water spray bottle to spray water mist -- distilled water -- into the engine intake. This mist of water would flash to steam in the combustion chamber then revert to liquid and in doing so remove deposits. This is how Techron works. It has a liquid and vapor deposition phase and both work to loosen and remove deposits. As is the case with using Techron, using this water mist method of engine deposit removal an oil/filter change was strongly advised afterwards. The important point to note using this technique is the engine is hot and kept hot by the elevated engine RPMs. Thus the water enters the engine and almost all of it exits the engine. At no time is the engine stopped and water allowed to remain in the engine/combustion chambers. The bit of water that remains in the engine is in the oil and an oil/filter change after this removes this water.)
But if the build up is real bad physically removing the deposits is called for which requires the head or heads be removed.
Rockster is offline
post #9 of 10 (permalink) Old 04-18-2019, 09:49 AM
Removing heavy carbon build-up by spraying water into the intake is usually not a good idea as that carbon has to go somewhere which usually winds up clogging the cats. When I was a lad, I had an old 360 that had so much carbon build up that I tried with the old water method and as the carbon flaked off it damaged the spark plug insulator and pitted the piston heads. The only way to safely remove build-up is to remove the heads.
Flat Top (04-19-2019)
post #10 of 10 (permalink) Old 04-18-2019, 10:26 AM
creamsicle's Avatar
There was a study done some years ago by Chrysler about this situation. Carbon buildup happens about every 10K miles. Some things you can do to clean it out are running a cleaner in the gas; I believe Chevron has a product that can do this; fill up a few tankfuls of a premium gasoline that has cleaners in the gas, the companies will make note of this on their product. After a few tankfuls of a good quality gas, (optional)make a run, and occasionally hammer the gas pedal to blow out the carbon.
creamsicle is offline
APR Carbon Fiber Front Splitters Speedlogix-Sales Speedlogix 6 04-18-2019 09:16 AM
Full Line of LMI Carbon Fiber Intakes @ Speedlogix! SRT8U Speedlogix 81 10-16-2018 10:16 AM
LMI Frankentake IV Carbon Fiber CAI 08-15 Challenger 5.7L, 6.1L SRT8U Speedlogix 87 10-05-2017 10:09 AM
2013 RT Classic SQ Audio Build IMCHALLENGEN Car Electronics- Lights, Fuses, Audio & Video 49 09-09-2013 10:35 PM
