engine oil - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 9 (permalink) Old 04-07-2019, 11:40 PM Thread Starter
cubanogar's Avatar
engine oil
Can I use 5w-30 synthetic oil(Amsoil) instead of the recommended 5w-20?
cubanogar is offline
post #2 of 9 (permalink) Old 04-08-2019, 03:35 AM
capevettes's Avatar
It would probably work fine, but why not stick with the recommended viscosity? If your car is under warranty you risk voiding it if you have motor issues.
capevettes is online now
post #3 of 9 (permalink) Old 04-08-2019, 06:51 AM
Its best to stay with the 5W-20 weight as called out in the owner's manual.
The cam phaser (part of the VVT system) depends on oil pressure to do its job.
-if the operation is out of the range, it will throw error codes and could potentially put the vehicle into "limp home" mode
PS: any 3.6, 5.7, 6.4 engine has VVT - and each of these engines have their specific weights of oil recommended by FCA
3.6L V6 - 5W-20 [MS-6395 FCA spec]
5.7L V8 - 5W-20 [MS-6395 FCA spec]
6.4L V8 - 0W-40 [MS-12633 FCA spec]
6.2L V8 - 0W-40 [MS-12633 FCA spec]
Hal H is online now
post #4 of 9 (permalink) Old 04-08-2019, 07:31 AM Thread Starter
cubanogar's Avatar
The oil reason I ask is because, I been reading about the hemi tick and a few people say use 5w30 and the noise goes away. also Can I use 5w-20 and lukes oil stabilizer?
post #5 of 9 (permalink) Old 04-08-2019, 09:02 AM
Slidd's Avatar
If you have an automatic transmission you probably need to stay with the 5W-20 or it could set a code an affect the MDS lifters.
With the 6-speed you could run 0W-40 and FCA even recommended it to help quiet the tick but it normally doesn't help, even some 392s tick and they all run 0W-40.
Slidd is online now
post #6 of 9 (permalink) Old 04-08-2019, 09:29 AM
Jimmy N.'s Avatar
I had quite a tick in my 6.4 using 0W/40.
After switching to the correct type of 0W/40, the tick disappeared.
2018 Challenger
2019 Challenger
Jimmy N. is offline
post #7 of 9 (permalink) Old 04-08-2019, 01:31 PM
Gila Hemi's Avatar
If you go on Amsoil's web site and enter your vehicle's info, it will give your the correct fluid weights and pricing. Be sure to use their Signature oil as it's the absolute best.
Member:
Gila Hemi is offline
post #8 of 9 (permalink) Old 04-08-2019, 08:05 PM
hemi4us's Avatar
royal purple helped with my wifes R/T tick..dont know if it was the oil itself or the fact it was simply new oil..but it was noticable change. if you are due for an oil change, try a different brand but in the same recommended wieght, see if that makes a difference.
2015 Mods:
Axis Model II's.
Firestone Indy 275/40/20
Rolling Thunder Reso delete.
GPC Trunk Pull Handle.
Spare/Jack/Foam Delete.
GPC Phantoms.
Mopar O.E. Black Fuel Door.
Hellcat OE. ABS Cover.
Rear Seat Delete.
2014 Dodge Viper Seats.
hemi4us is offline
post #9 of 9 (permalink) Old 04-09-2019, 07:36 AM
Just did the 2nd oil change on my '17 R/T. I'm using Pennzoil Platinum 5W20, not the Ultra Platinum, which is a full synth and meets MS-6395 as Hal H mentions. 15k miles in 9 months and no tick so far!
NMRT is offline
Which oil to use?? WazzSXT Dodge Challenger SE/SXT Specific 9 01-06-2019 07:18 AM
Does a Catch Can Work? Check out this Pic Badbee Bolt On's 429 10-02-2017 07:40 PM
Oil Change From HELL!!! KDodge75 General Challenger Discussion 67 09-09-2017 09:36 PM
Which services are required at 30K miles? DJ Hemi Dodge Challenger R/T Specific 8 08-13-2017 09:44 AM
Mopar Oil FAST RS General Challenger Discussion 30 09-10-2013 07:43 AM
