Long crank at cold start... - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 16 (permalink) Old 03-28-2019, 10:10 PM Thread Starter
Veracious Beast's Avatar
Hi everyone,
Got a long crank only at cold start. My spark plugs are new. My battery is good to go. So suspecting my fuel pump might not be priming her up for the cold start. I've done the off-to-on a few times and she started up. I'm hereto see if I'm wrong or if you guys have theories. I can check. Also, if you agree on the fuel pump, what is the best brand? Was thinking Spectra premium.
Veracious Beast is offline
post #2 of 16 (permalink) Old 03-29-2019, 03:33 AM
Dales 2016 Challenger's Avatar
What type engine do you have ie 3.6, 5.7 etc. I asked because just went through this same thing with wives car. 3.6L and dealership did some update with computer and problem fixed. Found a TSB's for this issue on Chrysler 200 forum.
Mopar or No Car
2016 Challenger SRT , Tor Red with Black Leather
Dales 2016 Challenger is offline
post #3 of 16 (permalink) Old 03-29-2019, 03:40 AM Thread Starter
I have a 2013 rt.
post #4 of 16 (permalink) Old 04-05-2019, 10:40 PM Thread Starter
Still happening guys. Brand new battery. New spark plugs. Fuel pump turning on. So not sure starter is good. Alternator is basically new thanks to that recall. Seems like everything is going well on my datalogging on my intune i2.
post #5 of 16 (permalink) Old 04-05-2019, 10:50 PM
us1champ's Avatar
Feedback Score: 10 reviews
Might be bleeding off at the aux pump passenger side. You can try a new one. They are around 300ish
2009 SRT
CUSTOM HEAD RESTS
us1champ is offline
post #6 of 16 (permalink) Old 04-06-2019, 05:31 AM Thread Starter
Yea i might get one after i check my injectors and verify my pressure isn't holding up.
Should i replace my pump too? Was thinking just the aux its like 130ish. Ill do the work myself fairly easy job it seems.
post #7 of 16 (permalink) Old 04-06-2019, 05:59 AM
Another easy thing to check are the intake manifold bolts.
You could also try resetting the PCM to clear the adaptives from any funky LTFT.
post #8 of 16 (permalink) Old 04-06-2019, 08:04 AM
us1champ's Avatar
Ya you can but do one at a time so Yiu know what if it fixes it
Pump is easier than the passenger
us1champ is offline
post #9 of 16 (permalink) Old 04-20-2019, 05:36 AM Thread Starter
Whats good everyone, an update still haven't fixed the long crank at cold start. I changed auxiliary fuel pump only to get a defected spectra pump that didn't have a properly working sending unit. Anyone on recommendations on brand? Or upgrades?
post #10 of 16 (permalink) Old 04-20-2019, 07:35 AM
Well if the AUX pump itself was working then it sounds like it is not your problem. Although the AUX pump only flows fuel to the other side of the saddle and does not supply the injectors directly. Have you checked your intake manifold bolts...or if their are fuel stains where the intake/heads meet?
us1champ (04-20-2019)
Benefits of Thinner Oil Cuda340 General Maintenance Discussion 37 01-10-2019 09:03 AM
Tapping noise every time I cold start...is this really normal? Rpaulg87 General Challenger Discussion 46 04-17-2015 03:28 PM
Scat Pack Cold Start Cam Lope kenandjenn4551 2015 to Current R/T Scat Pack 392 2 03-14-2015 09:06 PM
