Regular gas vs. Premium - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 20 (permalink) Old 05-10-2019, 07:46 PM Thread Starter
wjv007's Avatar
I have a 2017 scat pack which recommends using 91 octane just wondering if there's really any difference between using regular and premium?
wjv007 is offline
post #2 of 20 (permalink) Old 05-10-2019, 08:05 PM
oldhp's Avatar
If you put 87 in it you get to putt around because it won't run like it's supposed too. Might as well bought a SXT 3.6. Put the 91-93 premium juice in it and have fun.
oldhp is offline
The Following 2 Users Say Thank You to oldhp For This Useful Post:
Pauljw (05-10-2019), Stitches1974 (05-10-2019)
post #3 of 20 (permalink) Old 05-10-2019, 09:54 PM
MiHiHemi's Avatar
Low octane can cause preignition and damage your engine. Works fine for lower compression engines but not for higher compression (assuming you have a 392).
MiHiHemi is offline
post #4 of 20 (permalink) Old 05-11-2019, 03:48 AM
Cuda340's Avatar
If you use 87 octane, your car's PCM will retard the timing to prevent pre-ignition and possible engine damage. You will lose power and your car will run like crap. If gas prices are an issue, you should have bought an SXT.
Cuda340 is offline
BilletTA392 (05-11-2019)
post #5 of 20 (permalink) Old 05-11-2019, 09:38 AM
With 91 octane gasoline the engine controller can run more ignition advance which starts the combustion process at the more optimum time and thus obtain more mechanical energy from the chemical energy of the burning gasoline/air mixture.
This is important. Emissions are lower and fuel economy is better. If you switch to 87 while the initial cost is lower you will find the engine burns more 87 than it would under the same operating conditions as with 91. The difference will have you buying more 87 and often enough to wipe out the initial lower price of the 87 octane gasoline.
There's more bad news. With a lower grade of octane the engine controller will have to dial back the timing to avoid detonation. This lowers the pressure in the combustion chamber which eliminates detonation but raises exhaust gas temperature. The mixture starts burning later in the power stroke and stops burning later. Thus subjects all components exposed to the exhaust gas to higher operating temperatures. This includes the exhaust valves, O2 sensors, converters. All very expensive items to replace if they go bad.
You think because if you drive the car "easy" you can avoid detonation and the ignition timing retard? Nope.
Detonation is not a WOT only problem entirely. At part throttle at relatively low RPMs and in a higher gear -- which is with the automatic transmission equipped cars is how the transmission shift map works -- cylinder filling is quite good. As a result combustion pressure can be quite high. So driving around town easy with 87 octane gasoline and thinking one is doing no harm is just the opposite of what is going on.
High compression is a very good thing. The power it takes to compress the air/fuel mixture is almost all regained by the initial push back of this against the piston. If the spark can be triggered at the right time the mixture burns and develops pressure earlier in the power stroke which pushes down on the piston at the most optimum time. Running the correct octane grade allows the engine controller derive maximum benefit from the high compression.
Best I can in some way detail how this works is if you ride a bicycle you just know when is the best time to apply pressure on the pedal to get the most out of your leg muscles. If you delay applying pressure -- which is what happens with low octane gas and the engine controller retarding ignition -- you get a very good idea of how inefficient this delay in applying pressure really is.
Rockster is offline
The Following 5 Users Say Thank You to Rockster For This Useful Post:
BilletTA392 (05-12-2019), burnzie (05-12-2019), Finface (05-12-2019), MiHiHemi (05-11-2019), pentacro (05-11-2019)
post #6 of 20 (permalink) Old 05-11-2019, 04:15 PM
Cuda340's Avatar
Very thorough explanation.
Cuda340 is offline
The Following 2 Users Say Thank You to Cuda340 For This Useful Post:
jgraham70 (05-11-2019), olscool (05-12-2019)
post #7 of 20 (permalink) Old 05-11-2019, 04:48 PM Thread Starter
wjv007's Avatar
Thanks for the advice I'm sticking to premium.
wjv007 is offline
post #8 of 20 (permalink) Old 05-11-2019, 04:52 PM Thread Starter
wjv007's Avatar
Thanks for the advice I am going to continue using premium.
wjv007 is offline
post #9 of 20 (permalink) Old 05-11-2019, 05:03 PM
Mud Yapster's Avatar
My Canam 1000 takes 93 and the single hose gas pumps ripping me off with the 1st gallon or so of 93 being mixed with 87, it pisses me off. My tank holds 10 gallons but I seldom put more than 6 to 7 gallons in it so I'm being ripped off with a mixture of 87 when I'm paying for 93 octane.
Just something to keep in mind so don't just top off your tank with 5 gallons of fuel.
My Canam is an off road vehicle so i have to fill it before heading into the woods so i have no choice of running my tank empty.
2017 Maverick XMR 1000R
2014 Palomino Columbia 43' TH
Mud Yapster is offline
post #10 of 20 (permalink) Old 05-11-2019, 07:24 PM
Many stations have a nozzle for each grade of gasoline. Maybe you need to find one and buy your gas from one?
Rockster is offline
Just moved to an area where 91 oct gas is premium, but I have a 93 oct tune... plissken99 Performance Modifications 10 10-17-2013 05:20 AM
High-Octane Hijinks: Is Premium Fuel Better Than Regular? AutoGuide.com Off-Topic Discussion 3 11-22-2012 01:10 AM
Gas Guzzler Tax Cuda340 General Challenger Discussion 38 06-12-2008 05:31 PM
THE BS about rice having better gas mileage and better quality exposed SO READ IT THE STUD General Challenger Discussion 12 12-12-2006 12:37 PM
