Squealing/Chirp noise while in gear manual scat pack - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 10 (permalink) Old 04-24-2019, 09:54 PM Thread Starter
WA392Bee's Avatar
First off sorry if this has been addressed, couldn't find it. So I have a '19 manual scat pack that I've only had for two months, now 1580 miles on the clock. Tonight I took it out for a 20 min drive and I noticed a squealing chrip noise coming from the front end while I'm in 2nd or 3rd gear and I take my foot of the gas and coast. It goes away if I step on the brakes, or if I accelerate. It also seems to go away if I turn left but amplify if I turn right. Ive only noticed it in 2nd and 3rd gear while coasting. At first I thought it was brake dust/dirt build up on the rotors because that's what it sounds like, but I'm not hearing it in first gear... For reference I have the 6 piston brembos up front.
Anyone else have this problem before? I'm going to give it a wash tomorrow to for sure eliminate the brake dust theory but other than that I'm at a loss of what it could be. Any advice is appreciated!
WA392Bee is offline
post #2 of 10 (permalink) Old 04-25-2019, 12:05 AM
Janson's Avatar
Random thought.. Check that your lug nuts are tight. Also try bedding your pads to ensure they are not causing the issue.
2015 Scat Pack
8-speed auto, Mopar stage 1 performance springs, DFS wickerbill, StopTech stainless brake lines, PowerStop high-carbon rotors, Petty's Garage front/rear adjustable sway bars and front/rear four point strut braces
Janson is offline
post #3 of 10 (permalink) Old 04-25-2019, 12:36 AM
Normally I am all for DIY but it is a 2019 and still under manufacturer's warranty...let the dealership diagnose and fix.
Pauljw (04-28-2019), trippytro (05-24-2019)
post #4 of 10 (permalink) Old 04-27-2019, 03:14 PM Thread Starter
WA392Bee's Avatar
Update: I took it out and gave all 4 rotors a high pressure wash, got a lot of gunk out but the noise has become louder. Before I couldn't notice it while having my window open, now it's very noticable from outside. I checked my lugs, not the issue. Again it's only in 2nd and 3rd gear while coasting and turning right or left. The noise immediately disappears under any brake or throttle application. I gave it a good visual inspection and didn't see anything. I'm at a loss, going to take it in to the dealership this next week asap and see if they can figure it out.
WA392Bee is offline
post #5 of 10 (permalink) Old 04-28-2019, 04:15 PM
I have mentioned this before to another member complaining of squealing brakes...do you happen to have hill start assist activated, if so if you turn it off do you notice a difference?
post #6 of 10 (permalink) Old 05-23-2019, 10:59 PM Thread Starter
WA392Bee's Avatar
Didn't notice a difference. The majority of the squealing goes away if I high pressure wash the rotors from the outside and underneath the car so I'm assuming it's just brake dust.
WA392Bee is offline
post #7 of 10 (permalink) Old 05-24-2019, 08:51 AM
Do any rotor surfaces show any signs of abnormal wear? Like a groove or a streak?
Absent any signs of problems at the rotors, the problem reads like a brake piston is hanging up and a pad or part of a pad is in light contact with the rotor.
While washing the brake hardware can eliminate the noise a build up of brake dust on the piston boots causes it can't help a sticky/binding brake piston.
You probably need the car checked out by a tech. Be sure you can describe to him how to reproduce the noise or arrange to drive the car and demo the noise to the tech.
Rockster is offline
post #8 of 10 (permalink) Old 05-24-2019, 09:23 AM
trippytro's Avatar
6 piston brembos are serious brakes. My buddy who works as a BMW lead tech always tells me how drivers of M cars always come in complaining about brake squeal even though some of these cars are fresh off the lot!
His fix? 3 hard stops from 60mph until you can see the brakes smoking or you can smell them, park the car and let then air out or take a cool down lap, and by re-bedding the surface the noise usually goes away.
Not saying this is 100% your issue but its something easy to try
trippytro is offline
post #9 of 10 (permalink) Old 05-24-2019, 09:54 AM Thread Starter
WA392Bee's Avatar
I'll have to try that. I just took a 1400 Mile road trip and didn't hear it much at all. I've only been noticing it now around town. If the braking from 60 doesn't work I'll get it checked by a tech.
WA392Bee is offline
post #10 of 10 (permalink) Old 05-25-2019, 01:17 AM
Make sure to drive for a while without using the brakes when they are hot
https://brakeperformance.com/bedding-in-rotors.php
A Guy is offline
Pauljw (05-27-2019)
My Opinion: Updating exisiting RT vs. Buying Scat Pack (also manual vs. 8 speed) 13rtchallenger Dodge Challenger R/T Specific 33 02-12-2017 03:39 PM
IL: Test Drive R/T Scat Pack Manual Berzerk Mid-West 9 02-03-2017 12:33 PM
When will the Scat Pack 2 & 3 Kits be available? WinstonVT Bolt On's 111 03-10-2016 06:32 PM
New Shaker hood / Stage Kits ResumeSpeed General Challenger Discussion 258 05-02-2014 10:49 PM
