Water Pump Replacement 5.7 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 12 (permalink) Old 05-22-2019, 09:20 PM Thread Starter
RT_Kujo's Avatar
About 1/2 mile from home I smelled coolant. After some trouble shooting I confirmed that the water pump failed (45,000 miles). I am considering replacement pumps and would appreciate some input. The standard Mopar 68346915AA says that it is for "without oil cooler." I added an oil cooler 6,000 miles ago as part of my build. Could this have caused the pump to fail? Regardless, anyone know if the SRT water pump (for with an oil cooler) will fit my RT, and if it is the right water pump to get? what's the difference?
I could also go aftermarket at the local O'Reilly's. There are (2) Murray water pumps that will fit. One has a plastic impeller, and one has a metal impeller (but is "from 3/4/2013" - my car was manufactured in 2012). Not sure why there are different part for the same model year but with different build dates. Anyone have any thoughts on this?
2013 Challenger R/T "Stella"
20" Chrome wheels / 3.92 rear gears / STP Suspension / Solo Mach-X Cat Back Exhaust / Functional hood scoops / Challenger door sills / Moroso catch can / Speedlogix strut tower brace / Stop Tech Rotors / BBK Shorty Headers / Mopar Scat Pack Stage 3 Ported Heads / 392 Cam / Manley Push Rods / Mopar Oil Cooler / Custom Tune Sound: Audio Control LC7i LOC, Alpine 500MRXV60 Amp, Focal 165A1/CA1 speakers, 8" Kenwood Excelon + 10" Infinity Reference subs in custom cabs
RT_Kujo is online now
post #2 of 12 (permalink) Old 05-31-2019, 10:05 AM
wjv007's Avatar
I have a 2017 scatpack 15,000 miles just had to replace the water pump after it was replaced I notied shavings in my engine coolant reservoir did you see any in yours?
wjv007 is offline
post #3 of 12 (permalink) Old 05-31-2019, 10:43 AM
Frank Julian's Avatar
My 2015 R/T with less than 12k smells like coolant from time to time. I am hoping prices come down on electric water pumps for our motors. Right now they are about $640. I'll just have to figure out a new way to run the belt.
https://www.jegs.com/i/Meziere/680/WP314S/10002/-1
Frank Julian is online now
post #4 of 12 (permalink) Old 06-01-2019, 09:58 PM Thread Starter
RT_Kujo's Avatar
No I didn’t notice any metal in the tank. All in all I think I was lucky because I was only 1/2 mile from home when it gave out. In a couple days time I would have been on a road trip a couple hours south to look at a college with my son. That would have sucked.
When I pulled it off, the bearings were completely shot. The pulley wobbled around. It wasn’t too bad. I had the pump off in a couple hours.
post #5 of 12 (permalink) Old 06-02-2019, 07:38 AM
If you smell coolant there's a leak. A cooling system with a leak can't hold pressure which means hot coolant can flash to steam which form pockets which block coolant flow to the hot areas. Localized overheating can occur which can cause a head gasket failure or worse.
You should locate the source of the leak and address it. If it is a water pump replace it now rather than wait for an electric water pump solution. Electric water pumps will bring with them their own issues. The belt driven pump is the best solution and I would stick with the factory water pump.
Rockster is online now
Frank Julian (06-02-2019)
post #6 of 12 (permalink) Old 06-02-2019, 09:28 AM
I have a 2014 RT Shaker....5.7L...92,000 miles....Im on my 3rd Water Pump....can't remember exact mileage they went out...luckily, all covered uder the 100,000 mile drive train warranty...Obviously a bad Water Pump Design....I think many, many WP's on 5.7's have went out..common issue..
2014 RT Shaker #196 - Header Orange....Corsa Extreme, CQuartz Finest, Huper Optik Ceramic Window Tint
2010 RT Classic - Hemi Orange
daly double is offline
post #7 of 12 (permalink) Old 06-02-2019, 11:45 AM
the serpentine belt tensioners, IMO, run a very high rate - I wonder if that's contributing to the bearing wear / failures.
My '01 Benz (137K) has a similar tensioner setup, very high level - no issues with the original water pump.
-this car lived in the Bay Area for the first 50K of its life...so it spent a lot of time idling in traffic vs. steady state driving on the highway
Hal H is offline
post #8 of 12 (permalink) Old 06-02-2019, 03:54 PM
The first time the pump went out, local mechanic originally diagnosed as a bad tensioner pulley...so he replaced it...he then called and said the WP was also shot...got that replaced at dealer..15,000 -20,000 miles later...water pump went out again...and dealer once again replaced...never smelt coolant..just a real bad grinding noise...both times...now out of warranty..so hate to see how much they will charge me...
post #9 of 12 (permalink) Old 06-02-2019, 04:46 PM
Tshane72's Avatar
What route did you end up going? How much did it cost? My car is out of warranty now also but so far no problems with my water pump...5.7L here too...
Tshane72 is offline
post #10 of 12 (permalink) Old 06-04-2019, 10:45 AM
Water pump isn’t out...just talking about previous times..
392 water pump replacement - sealant required? CF392 General Challenger Discussion 1 05-31-2018 04:19 PM
Billet Water Neck 05+ HEMI 5.7, 6.1, 392 Speedlogix Speedlogix 41 01-30-2018 08:40 AM
Everything you need to know about Water/Methanol Injection! SRT8U Speedlogix 27 10-04-2016 11:29 PM
performance pullys or electric water pump hemi2010rt General Challenger Discussion 1 06-16-2014 04:41 PM
MOPAR CAI caused water pump to fail??? Mach2 Performance Modifications 14 06-02-2014 04:39 PM
