Acronyms Used On Challengertalk - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 31 (permalink) Old 05-29-2018, 10:23 PM Thread Starter
This is a compilation of commonly used acronyms here at Challengertalk contributed by the members. If you are new to the forum, or just wonder what the heck MDS is, or SPAG, you will hopefully find it here. This isn't meant to be a list of common acronyms on the internet, but rather acronyms that are more specific to Challengertalk. Feel free to suggest any that we have missed so far, and I will add them if they fit the criteria. Thanks to everyone who has contributed to the list
8.4 = Uconnect 8.4" Head Unit
A5 = 5 speed automatic
A8 = 8 speed automatic
ABS = Antilock Brake System
AEV = Active Exhaust Valves
AFR = Air Fuel Ratio
AT = Automatic Transmission
ATF = Automatic Transmission Fluid
AWD = All Wheel Drive
Axle Back = Exhaust system after the rear axle
B5 = B5 Blue Color
BCM = Body Control Module
Blower = Supercharger (See also SC)
BOV = Blow Off Valve
Brembo 4 = 4 Piston Brembo Brakes
Brembo 6 = 6 Piston Brembo Brakes
CAI= Cold Air Intake
Cats = Catalytic Converters
Cat Back = Exhaust system after the Catalytic Converter
Catted Mids = Midpipes with Catalytic Converters built in
CDV = Clutch Delay Valve
CEL = Check Engine Light
DCG = Drivers Convenience Group Package
DD = Daily Driver
DI = Direct Injection/Direct Fuel Injection
DR= Drag Radials
DRLs = Daytime Running Lights
DS = Drive Shaft
DTC = Diagnostic Trouble Code
ECT = Engine Coolant Temp
EGR = Exhaust Gas Recirculation
EGT = Exhaust Gas Temperature
EHPS = Electro-Hydraulic Power Steering
ESC = Electronic Stability Control
EVIC = Electronic Vehicle Information Center
F8 = F8 Green Color
FCA = Fiat Chrysler Automobiles
FI = Forced Induction or Fuel Injection
FM = Friction Modifier
Forged = Adding Forged internal engine parts to replace weaker cast parts. Most notably Forged Pistons
FWD = Front-Wheel Drive
Gen3 or GenIII = 3rd generation Hemi Engine
Getrag = Limited Slip Differential
HC= Hellcat
HEMI = Hemispherical combustion chambers
HID = High Intensity Discharge Headlights
HF Cats = High Flow Catalytic Converters
HLA = Hydraulic Lash Adjuster
HU = Head Unit
HUD = Heads-Up Display
HVAC = Heating, Ventilation, and Air Conditioning
IAT = Intake Air Temperature
IFS = Independent Front Suspension
iDFSO = Interactive Decel Fuel Shut-Off
IRS = Independent Rear Suspension
LA = 2015- Current Challenger Platform
LC = 2008-2014 Challenger Platform
LCA = Lower Control Arm
LHD = Left Hand Drive
LSD = Limited Slip Differential
LT = Long Tube Headers
M6 = 6 speed manual
MAP = Manifold Air Pressure (IE: MAP Sensor)
MF = Microfiber (C'mon now, get your head out of the gutter! )
Mids = Mid Mufflers or Mid Pipes
MDS = Multi Displacement System
MIL = Malfunction Indicator Light
MOPAR= Combination of the words MOtor and PARts. Parts, service and customer care organization within Fiat Chrysler Automobiles
MT = Manual Transmission
MY = Model Year
NA = Naturally Aspirated
NAG/NAG1 = 5 speed automatic transmission (New Automatic Gearbox 1 [1st Generation])
NOS = Nitrous Oxide or Nitrous Oxide System
NVH = Noise, Vibration, and Harshness
O2s = Oxygen Sensors
PCM = Powertrain Control Module
PCP = Plum Crazy Purple/Plum Crazy Pearl color
PCV = Positive Crankcase Ventilation (IE: PCV Valve)
PDC= Power Distribution Center
PDI = Pre-Delivery Inspection
POC = Priced Order Confirmation
PP = Performance Pages
PPF = Paint Protection Film
PSI = Pounds per Square Inch
Raisin Bran Hood = New "Two Scoop" Hellcat hood
Reps = Replica Wheels (IE: Hellcat Reps, Demon Reps)
Res Delete = Resonator Delete
RHD = Right Hand Drive
RWD = Rear Wheel Drive
RWHP = Rear Wheel Horsepower
SA = Spark Advance
SC = Supercharged, or Supercharger
SG or SGII = Sound Group, Audio System
Shaker = Shaker Hood Scoop
SI/DO = Single In, Dual Out muffler design
SI/SO = Single In, Single Out muffler design
Six Pack = Three two-barrel carburetors
SP = Scat Pack
SPAG = Scat Pack Appearance Group
SPS = Scat Pack Shaker
Squirters = Nozzles that squirt oil under the piston to keep them cooler
SRS = Supplemental Restraint System
SRT = Street & Racing Technology (High Performance Group Of FCA)
STP = Super Track Pak
ST or Shorties or Shortys = Shorty Headers
TCM = Transmission Control Module
TIPM = Totally Integrated Power Module
TB = Throttle Body
TPMS = Tire Pressure Monitoring System
TSB = Technical Service Bulletin
TW = Treadwear
UCA = Upper Control Arm
VIN = Vehicle Identification Number
VON = Vehicle Order Number
VVT = Variable Valve Timing
WB = Wide Body
WOT = Wide Open Throttle
ZF = Manufacturer of 8 Speed Automatic Transmission (2015+) (See also A8), and 2015+ Rear Differentials
A Guy is offline
The Following 9 Users Say Thank You to A Guy For This Useful Post:
Bob Ricewasser (05-30-2018), ChallengerBoston (05-17-2019), cuda7man1 (05-17-2019), fyrdude (05-17-2019), kbtoby (07-09-2018), KWflyer (05-30-2018), PSM450 (05-31-2018), silver scat (06-02-2018), speedbump (07-03-2018)
post #2 of 31 (permalink) Old 05-30-2018, 04:30 AM
Cuda340's Avatar
Great list. We should also add names to it.
Here are some:
Hemi- Denotes an engine with hemispherical combustion heads.
MOPAR- It is the parts, service and customer care organization within Fiat Chrysler Automobiles. The name is a combination of the words "MOtor" and "PARts."
Blower- Supercharger
Six Pack- Three two-barrel carburetors
Cuda340 is offline
A Guy (05-30-2018)
post #3 of 31 (permalink) Old 05-30-2018, 11:10 PM Thread Starter
Those fit here, added
A Guy is offline
post #4 of 31 (permalink) Old 05-31-2018, 06:44 AM
McMopar's Avatar
Great list! Thanks to A GUY!
McMopar is offline
The Following User Says Thank You to McMopar For This Useful Post:
post #5 of 31 (permalink) Old 05-31-2018, 07:12 AM
MiHiHemi's Avatar
Well done!!!
MiHiHemi is online now
post #6 of 31 (permalink) Old 05-31-2018, 08:42 AM
David Freye's Avatar
Great job of putting this together!!!
I know there have been a few times I've scratched my head as I learn the lingo as I get more acquainted with my car and the brotherhood.
Thanks for this!!!
"RT GASM" That feeling one gets when driving an RT.
David Freye is offline
post #7 of 31 (permalink) Old 05-31-2018, 11:20 AM
I see people use SX and I think SXT also. Not sure what those mean
enemy is offline
post #8 of 31 (permalink) Old 05-31-2018, 07:10 PM Thread Starter
Thanks guys, I can't take all the credit, others suggested ideas as well. It is an ongoing, community effort!
SXT is a trim level, currently there is
SXT
GT
RT
SRT
Hellcat
Demon
There are varying levels within trim level as well (Plus, Scat Pack, Shaker) to name a few
A Guy is offline
enemy (06-01-2018)
post #9 of 31 (permalink) Old 06-01-2018, 11:13 AM
MuscleCarProf's Avatar
An addition and (to be picky) two corrections:
NAG -NAG1 5 speed automatic transmission
STP - Super Track Pak
PCP - Plum Crazy Pearl
2018 Go Mango Scat Pack 6 speed with a Speedlogix catch can.
Other current car: 1966 Mustang GT coupe
MuscleCarProf is offline
post #10 of 31 (permalink) Old 06-01-2018, 02:33 PM
ddeennis's Avatar
WBYCEIYDBO
2013 Challenger SXT 3.6, new 1/31/13, Sprintex S/C 60mm pulley,15lbs boost,BT catch can,180*stat,ported lower intake and TB,custom head tubes,mid pipes/stock cats,Corsa 2 3/4"catback,Htuner TCM,3.90 gear,[email protected] 1.7860ft 2980ft DA
ddeennis is offline
I didn't know that ... Challenger Tips and Tricks raVenX How-To, DIY and Tips & Tricks 183 09-20-2018 01:56 AM
Under Trunk Lid Mount Law Enforcement Style Weapons Rack vstarbb Exterior Discussion / Modifications 22 03-15-2017 11:52 PM
Are Old Tires Dangerous? Cuda340 Wheels, Tires, Brakes, and Suspension 7 09-14-2016 10:28 AM
Vibration when downshifting Renlo Challenger Issues & Problems 10 09-07-2014 06:22 PM
Obtained order for 2008 Chally on 4/10... it's now solely down to price... Venthos General Challenger Discussion 18 04-23-2008 11:35 AM
