Acronyms Used On Challengertalk - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 31 (permalink) Old 06-01-2018, 03:05 PM
praiseV8's Avatar
OSHCTMTC - Oh shit here comes the mustang, take cover!
2016 Dodge Challenger R/T 392
Bright White, A8+V6
praiseV8 is offline
post #12 of 31 (permalink) Old 06-01-2018, 11:58 PM Thread Starter
Originally Posted by MuscleCarProf View Post
An addition and (to be picky) two corrections:
NAG -NAG1 5 speed automatic transmission
STP - Super Track Pak
PCP - Plum Crazy Pearl
Not saying you aren't right, but I had always heard Plum Crazy Purple, @Hal H @Slidd , edumacate me please Meanwhile, I'll list both. Thank you for the additions
A Guy is offline
post #13 of 31 (permalink) Old 06-02-2018, 06:14 AM
MuscleCarProf's Avatar
I can help ya there. The vintage color FC7 is referred to as Plum Crazy Purple and the modern color for our cars (PHG or FHG code) is Plum Crazy Pearl. Per Dodge of course.
2018 Go Mango Scat Pack 6 speed with a Speedlogix catch can.
Other current car: 1966 Mustang GT coupe
MuscleCarProf is offline
post #14 of 31 (permalink) Old 06-02-2018, 08:12 AM
silver scat's Avatar
You're sure using that "broom experience". Thank you for all you do!
2016 Challenger Scat Pack, Billet Silver, A-8, Katzkin leather, Heated Vented seats W/ Heated Wheel, Convenience pkg., Harmon Kardon, WRT wheels, Nav. tinted windows, Modern R/T hood emblem, Tail band, Sunroof, UPR catch can.
silver scat is offline
post #15 of 31 (permalink) Old 06-02-2018, 01:19 PM
you lost me there. I'm guessing it's some inside joke for A Guy
post #16 of 31 (permalink) Old 06-02-2018, 05:08 PM Thread Starter
When he congratulated me for Super Moderator, I said they needed someone to sweep up at night
BTW, thanks Prof, I'll leave both but Pearl is current
A Guy is offline
post #17 of 31 (permalink) Old 06-11-2018, 05:18 AM
Nice Post.
assignmenthelp is offline
post #18 of 31 (permalink) Old 06-13-2018, 05:10 PM
You told me you had BROOM experience... lol.
post #19 of 31 (permalink) Old 05-17-2019, 10:19 AM
cuda7man1's Avatar
Hi,A Guy axle is spelled wrong. (Axel Back = Exhaust system after the rear axel)
cuda7man1 is offline
post #20 of 31 (permalink) Old 05-17-2019, 12:44 PM
Here are a couple more.
FM - Friction Modifier
DTC - Diagnostic Trouble Code
PCV - Positive Crankcase Valve
DFCO - Decel Fuel Cut Off (used in HP tuners)
COT - Cat Over Temp
ECT - Engine Coolant Temp
ETC - Electronic Throttle Control
EOT - Engine Oil Temp
GPEC2A - engine controller used on +2015 Dodge Challenger (all trims)
GPEC2 - engine controller used on 2011 - 2014 Dodge Challenger (all trims)
ZF - Manufacturer of +2015 differential
PE - Power Enrichment (fueling table used at WOT)
CL - Closed Loop
OL - Open Loop
STFT - Short Term Fuel Trim (temporary fueling changes made by PCM)
LTFT - Long Term Fuel Trim (learned/stored fueling changes made by PCM)
NN - Neural Network (the PCMs artificial intelligence)
PR - Pressure Ratio (MAP/BARO)
AF - Dodges term for fuel ratio (FA = 1/AFR)
AFR - Air Fuel Ratio (AFR = 1/FA)
EQ - Equivalence Ratio, often referred to by the Lambda symbol (see image below)
MAP - Manifold Air Pressure
MAF - Manifold Air Flow (only used on 2015-2016 HC)
BARO - Barometric pressure
KOEO - Key On Engine Off
FCA - Fiat Chrysler Automobiles
SRT - Street & Racing Technology (high performance group of FCA)
SD - Speed Density (a method of estimating airflow into an engine in order to supply an appropriate amount of fuel and adequate spark timing)
VE - Volumetric Efficiency (describes how effective the engine, intake, ports, and exhaust design are at flowing thru the engine)
MVPI - HP tuners interface
VCM - HP tuners scanning/editing software
I didn't know that ... Challenger Tips and Tricks raVenX How-To, DIY and Tips & Tricks 183 09-20-2018 01:56 AM
Under Trunk Lid Mount Law Enforcement Style Weapons Rack vstarbb Exterior Discussion / Modifications 22 03-15-2017 11:52 PM
Are Old Tires Dangerous? Cuda340 Wheels, Tires, Brakes, and Suspension 7 09-14-2016 10:28 AM
Vibration when downshifting Renlo Challenger Issues & Problems 10 09-07-2014 06:22 PM
Obtained order for 2008 Chally on 4/10... it's now solely down to price... Venthos General Challenger Discussion 18 04-23-2008 11:35 AM
