Acronyms Used On Challengertalk - Page 3 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #21 of 31 (permalink) Old 05-17-2019, 12:58 PM
praiseV8's Avatar
WWNGOA?
When will the @Nuke go off again?
2016 Dodge Challenger R/T 392
Bright White, A8+V6
praiseV8 is offline
post #22 of 31 (permalink) Old 05-17-2019, 06:54 PM Thread Starter
Originally Posted by cuda7man1 View Post
Hi,A Guy axle is spelled wrong. (Axel Back = Exhaust system after the rear axel)
Thanks, I had figure skating on my mind then...
Here are a couple more.
Thanks, tried to keep the list more general, used some, but the tuning terms are less common, and some I have never seen used here. However, if you want to write a post with Acronyms used in Tuning, I can sticky that in the Tuning forum. You can add the long term knock, short term knock acronyms, etc. A list of terms would be very useful there. Here are ones I did not add.
DFCO - Decel Fuel Cut Off (used in HP tuners)
COT - Cat Over Temp
ETC - Electronic Throttle Control
EOT - Engine Oil Temp
GPEC2A - engine controller used on +2015 Dodge Challenger (all trims)
GPEC2 - engine controller used on 2011 - 2014 Dodge Challenger (all trims)
PE - Power Enrichment (fueling table used at WOT)
CL - Closed Loop
OL - Open Loop
STFT - Short Term Fuel Trim (temporary fueling changes made by PCM)
LTFT - Long Term Fuel Trim (learned/stored fueling changes made by PCM)
NN - Neural Network (the PCMs artificial intelligence)
PR - Pressure Ratio (MAP/BARO)
AF - Dodges term for fuel ratio (FA = 1/AFR)
EQ - Equivalence Ratio, often referred to by the Lambda symbol (see image below)
MAF - Manifold Air Flow (only used on 2015-2016 HC)
BARO - Barometric pressure
KOEO - Key On Engine Off
SD - Speed Density (a method of estimating airflow into an engine in order to supply an appropriate amount of fuel and adequate spark timing)
VE - Volumetric Efficiency (describes how effective the engine, intake, ports, and exhaust design are at flowing thru the engine)
MVPI - HP tuners interface
VCM - HP tuners scanning/editing software
ZF was already on the list as the A8 transmission. Do they indeed manufacture the differentials used on Challengers as well? I always see differentials listed as "differential for ZF 8 speed automatic", Not ZF differential. I know we refer to them as the ZF diff, as opposed to the GETRAG. If indeed ZF, it would be only the LSD differentials, correct? I can change it if it's agreed that ZF manufactures the LSD used in Challengers.
A Guy is offline
post #23 of 31 (permalink) Old 05-17-2019, 06:59 PM
raceheart77's Avatar
how did you guys forget the infamous
" Chally ".
raceheart77 is offline
post #24 of 31 (permalink) Old 05-17-2019, 07:19 PM
Tshane72's Avatar
" Chally ".
Oh lord let's not include that one!!
Tshane72 is offline
post #25 of 31 (permalink) Old 05-17-2019, 07:28 PM Thread Starter
My keyboard won't type ------
See?
A Guy is offline
post #26 of 31 (permalink) Old 05-17-2019, 09:51 PM
COT - Cat Over Temp
CL - Closed Loop
OL - Open Loop
I see your point about making a new list for acronyms specific to tuning...I'll make a separate thread. I saw the iDFSO in the original list which gave me the idea to post other tune/tuning related acronyms.
As for ZF manufacturing the rear diffs, I was under the impression that the pre-2015s used getreg and the +2015s used ZF manufactured units per these threads:
https://www.challengertalk.com/forum...-gears-647138/
https://www.challengertalk.com/forum...25/index2.html
but I can't find hard evidence that they indeed are manufactured by ZF.
post #27 of 31 (permalink) Old 05-18-2019, 12:23 AM Thread Starter
Yeah, I saw iDFSO in a post as part of a bigger discussion, so I added it. @Slidd @Hal H Does ZF actually manufacture the differentials? And if so, only the LSD with the fins?
A Guy is offline
post #28 of 31 (permalink) Old 05-18-2019, 08:07 AM
Nuke's Avatar
Originally Posted by praiseV8 View Post
WWNGOA?
Shoot, I never go off, I'm always ON!!
" Chally ".
I woke up this morning with a splitting head-ache and someone else's socks on. That always happens when this sort of thing is getting started...I'm going on record now to say it's a bad idea to get another Chally vs Challenger discussion fired up!
It will be safer if y'all switch subjects to something less divisive...politics, religion, etc.
-- The Bacon Hauler
Nuke is offline
post #29 of 31 (permalink) Old 05-18-2019, 11:20 AM
Or which gender pronouns are not offensive.
Now where the F)$*( are my socks?!
post #30 of 31 (permalink) Old 05-18-2019, 11:26 AM
@A Guy ZF manufactures both the open and limited slip diffs for the '15+ models. the V8 models use the 230mm by default
Hal H is offline
I didn't know that ... Challenger Tips and Tricks raVenX How-To, DIY and Tips & Tricks 183 09-20-2018 01:56 AM
Under Trunk Lid Mount Law Enforcement Style Weapons Rack vstarbb Exterior Discussion / Modifications 22 03-15-2017 11:52 PM
Are Old Tires Dangerous? Cuda340 Wheels, Tires, Brakes, and Suspension 7 09-14-2016 10:28 AM
Vibration when downshifting Renlo Challenger Issues & Problems 10 09-07-2014 06:22 PM
Obtained order for 2008 Chally on 4/10... it's now solely down to price... Venthos General Challenger Discussion 18 04-23-2008 11:35 AM
