Amsoil? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 5 (permalink) Old 04-09-2019, 11:43 AM Thread Starter
cubanogar's Avatar
Amsoil?
Is there any issues in adding 1qt Luke's oil stabilizer with amsoil 5w-20 because I order 1gal plus 2 qts online and to just order 1more qt is not cost effective.
cubanogar is offline
post #2 of 5 (permalink) Old 04-09-2019, 12:34 PM
I would not add oil stabilizer as VVT and MDS (assuming you have a manual) use oil flow/pressure to control cam timing and lifter deactivation. You don't want additives mucking up the oil viscosity. Besides, if you are planning on running Amsoil you are already running one of the top oils on the market.
BTW - the guys at at BITOG seem to not like LOS.
https://www.bobistheoilguy.com/forum...Number=2437209
post #3 of 5 (permalink) Old 04-09-2019, 12:38 PM
praiseV8's Avatar
You're over complicating a simple process.
Is the oil weight what the oil cap and manual says to use?
Yes: then it goes in the engine.
No: then it doesn't go in the engine.
There's no need to add anything else.
2016 Dodge Challenger R/T 392
Bright White, A8+V6
praiseV8 is offline
post #4 of 5 (permalink) Old 04-09-2019, 12:54 PM
I think the OP is trying to quiet his lifter tick.
https://www.challengertalk.com/forums/f5/tick-669261/
I have used MMO on my liberty which completely eliminated my lifter noise...took a couple of treatments. But on would not recommend additives on the HEMIs because the oil is actually used to control engine operations.
Besides, if he truly has "Hemi Tick" there are loads of threads where guys are struggling to find a solution. Some have had success with different additives and oil brands but there does not seem to be one additive or brand that fixes it.
post #5 of 5 (permalink) Old 04-09-2019, 01:08 PM
Gila Hemi's Avatar
I buy it by the case. It's not like it is going to spoil if not used right away...
Member:
Gila Hemi is offline
Anybody use Amsoil Antifreeze? R/T-Randy General Maintenance Discussion 4 04-10-2019 02:58 PM
Tremec Response on TR-6060 Problems 392 Envy Challenger Issues & Problems 101 03-10-2016 04:54 PM
Amsoil 0W-40 now Available! circleD212 6.4L / 392ci (2011 - ?) 25 05-22-2015 02:10 PM
BES Racing Engines Wins Amsoil 2014 Engine Masters with a VVT HEMI [email protected] High Horse Performance 0 10-16-2014 04:28 PM
Colorado Springs Dodge Providing AMSOIL saphelps West 4 01-02-2013 08:48 PM
