Can you learn how to drive manual with Challenger? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 18 (permalink) Old 06-14-2019, 10:23 PM Thread Starter
I never owned a manual car. I have read how to drive one but don't have any hands on experience. Can someone like me become proficient with stick in a challenger?
Challenger Man is offline
post #2 of 18 (permalink) Old 06-14-2019, 10:36 PM
BlackHemi41's Avatar
Yep. Just be patient, find an empty parking lot or back road somewhere, start out slow and practice stopping and taking off. It's as good to learn on as anything, especially if it's what you're gonna be driving.
BlackHemi41 is online now
post #3 of 18 (permalink) Old 06-14-2019, 11:49 PM
DOM71's Avatar
I drove my Kawasaki 1st ZX-10R back in 04 then a Ford single cab if you can learn you should be good. I learned to drive my bike the first night I got it, but it was a learning experience
DOM71 is offline
post #4 of 18 (permalink) Old 06-15-2019, 02:34 AM
I'd think so, as mentioned, a flat empty parking lot. Light on the throttle until you get a handle on it. You WILL kill the car releasing the clutch But you'd do that in a 4 banger as well. It's part of learning to drive a clutch. You'd be surprised how much easier it is to learn on flat ground. You can graduate to hills after.
https://www.stickshiftdrivingacademy.com/
A Guy is offline
post #5 of 18 (permalink) Old 06-15-2019, 05:28 AM
trippytro's Avatar
I did.....actually on my first test drive lol.
The challenger has a heavy clutch but it talks back very well to the driver. It was the easiest stick shift car i had driven, just get rdy for ur left leg to turn into a cannon
trippytro is online now
post #6 of 18 (permalink) Old 06-15-2019, 06:52 AM
scott0's Avatar
yes, you'll be fine, today's manual transmission are so easy to drive. as said, have patience and expect to be rough at first
2017 granite pearl coat SRT Challenger, Barton shifter with Lou's short stick and Speed Dawg knob, UPR catch can, hellcat lower air box, Eibach Pro Kit springs, MRR M392 wheels w 275/40 and 315/35 Nitto G2's
scott0 is offline
post #7 of 18 (permalink) Old 06-15-2019, 07:37 AM
BigChallenge's Avatar
I was fine I thought. It was still early in my learn. Got to an uphill stopsign with a car behind me, I was driving an AMC Hornet with 3 on the tree. I'll never forget that stressful take off/ stall situation. Does the 6speed have a hill holder? I don't know myself I have the A8. I know the Challenger has lots more torque to make those situations easier though.
BigChallenge is offline
post #8 of 18 (permalink) Old 06-15-2019, 07:45 AM
Learning how to drive stick on a challenger has advantages. For one, the clutch pedal travel is very smooth and the engagement location is easy to find. I have driven cars where the clutch was cable driven and engagement would not start until you almost released the pedal (basically the cable was stretched and needed adjustment). Also, there is so much torque from the 5.7 and 6.4 that you can pretty much engage the clutch with no application of throttle and the car will begin to roll without stalling. And lastly, there is a hill start assist feature that can be activated that keeps the brakes applied while the car is at an angle. So don't have to worry about the car rolling back while you let off the off the brake when starting from a stop going uphill.
post #9 of 18 (permalink) Old 06-15-2019, 07:47 AM
Don't see why not. Generally large engine cars are easier to drive as they have loads of torque.
You might explore a driving school that offers participants the ability to learn to drive in a manual transmission equipped car.
You learn driving some car other than your own and you receive expert guidance/instruction while doing so. If you learn on your own you might develop bad habits that could be hard to unlearn.
And you reduce the risk that in your learning to drive a stick you make some kind of mistake that could end up damaging your new Challenger.
Rockster is offline
post #10 of 18 (permalink) Old 06-15-2019, 07:48 AM
Prostreetamx's Avatar
I learned the hard way. Personally I now buy all automatics but I can drive stick if needed. A friend at college wanted me to take her car to the frat house. She never mentioned it was parked on a steep hill and it was a manual. She also didn't tell me it would pop out of gear under a load. After bumping into the car down hill a few times, I just rested the car on the one below and held the shifter while I revved the engine and engaged the clutch enough to finally get out of the parking spot. I've never driven another car since with this situation, but newer manuals are much more forgiving to learn. I just don't like holding in the clutch while sitting at stop lights.
Prostreetamx is offline
