Changing stock exhaust tips? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 26 (permalink) Old 04-03-2019, 10:41 AM Thread Starter
dsotm's Avatar
I want to replace the factory tips with quad tips. Do the stock tips remove easily or are they welded on?
I’m at work so I don’t have the car with me and want to order them today.
Car is a 2018 RT 392
dsotm is offline
post #2 of 26 (permalink) Old 04-03-2019, 10:43 AM
scott0's Avatar
there is a ball joint of sorts that keep them on.
these are NOT my pictures, these were found on google......
2017 granite pearl coat SRT Challenger, Barton shifter with Lou's short stick and Speed Dawg knob, UPR catch can, hellcat lower air box, Eibach Pro Kit springs, MRR M392 wheels w 275/40 and 315/35 Nitto G2's
scott0 is offline
post #3 of 26 (permalink) Old 04-03-2019, 10:44 AM Thread Starter
dsotm's Avatar
So they are easily removable?
dsotm is offline
post #4 of 26 (permalink) Old 04-03-2019, 01:25 PM
scott0's Avatar
yes, very easy to remove
scott0 is offline
post #5 of 26 (permalink) Old 04-03-2019, 02:33 PM
R/T-Randy's Avatar
I have a 2012 RT. Is that also true about changing the stock exhaust tips? Is it easily done?
Are the tips clamp on?
I am offshore and can't look at my vehicle.
2012 Tungsten R/T Classic, 6 speed w/STP, 730 RHR w/sound group II and heritage wheels.
Mods: none
MSgt, USAF Retired
R/T-Randy is offline
post #6 of 26 (permalink) Old 04-03-2019, 06:51 PM
jcruikshank's Avatar
After you loosen the band clamp, you will probably need to give the tip a whack from behind to break it free. Over the years of being heat cycled, the ball and socket tend to become mated together. Also, I am not aware of any aftermarket exhaust tip designed to directly bolt-on to the larger 392 resonator ball without modification.
2015 Scat Pack, A8, Ivory White Pearl, Black/Ruby Red Leather, Weld RT-S S71.
jcruikshank is online now
post #7 of 26 (permalink) Old 04-03-2019, 07:59 PM
On my 2015 the clamp was tack welded to the resonator which made removing the tips more difficult then I anticipated. Loosening the clamp completely and bending it so it hinged off the weld did the trick.
ChallyTatum is online now
post #8 of 26 (permalink) Old 04-03-2019, 08:23 PM
Same here, tack welded to the resonator only. Really a pretty good design, but with no aftermarket support.
post #9 of 26 (permalink) Old 04-03-2019, 08:51 PM Thread Starter
dsotm's Avatar
So what size is the pipe that the tips go on to?
I found these, I believe they are Flowmaster
dsotm is offline
post #10 of 26 (permalink) Old 04-03-2019, 09:45 PM
Those look like the earlier version of Mopar’s quad tips, or possibly Magnaflow. The socket is too small to clamp around the 2.75” ball outlet on the 392 resonator.
