converting to E85 - Page 4 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #31 of 54 (permalink) Old 03-23-2019, 03:27 PM Thread Starter
chizzle1's Avatar
Here is the kit that one of the members either here or on HP tuners posted that does not require the tune to be changed.
https://tapped-performance.myshopify...-flex-fuel-kit
no replacement fuel pump? according to what I've read / been told the stock fuel pump in my 2010 is not E85 compatible.
Plus the increased flow needed would be a problem...if it was a bone stock 5.7 maybe...
chizzle1 is offline
post #32 of 54 (permalink) Old 03-30-2019, 06:05 AM
flow i could see being an issue...
E85 damaging a pump I would say no. I have had a Honda running e85 for about 8 years now it has 335k miles on it with the original pump. Just this year its not holding pressure after shut down and I will probably change it out. Car still run performs the same. Still could be an injector leak or my guage hook up leaking the check valve in the pump not holding.
I also run e85 alot on my old 440 with the regular cam driven fuel pump and its hangin on there as well not problems. I pulled the tank on this 6 months ago steel looked brand new inside. I just dont see all the bad thing we read about e85 corroding everything. I think that people that confuse it with other alcohols like methanol. one you can drink one you cant!
My GWE in the For Sale section!
GreeninTN is offline
post #33 of 54 (permalink) Old 04-01-2019, 09:12 AM Thread Starter
chizzle1's Avatar
finally caught up with customer cars and my day job...time to start on my project...
I'm going to mock up all the parts on the workbench prior to installation.
Hopefully it'll be burning E85 by Easter.
chizzle1 is offline
post #34 of 54 (permalink) Old 04-01-2019, 09:54 AM
LoL, I dig the saying on the cup holding the pens/pencils...too funny.
chizzle1 (04-01-2019)
post #35 of 54 (permalink) Old 04-01-2019, 10:11 AM Thread Starter
chizzle1's Avatar
thanks...sadly that cup was given to me over 10 years ago lol
chizzle1 is offline
post #36 of 54 (permalink) Old 04-01-2019, 12:09 PM
DOM71's Avatar
Sub, it's crazy in Texas there isn't much e85 it's like 1hr+ drive one way for me.
DOM71 is offline
post #37 of 54 (permalink) Old 04-02-2019, 07:21 AM Thread Starter
chizzle1's Avatar
really? I live in central Texas (Ft Hood) and the local HEB has quality E-85
I know a guy that was PCSd to Alaska (where E85 is hard to find I'm guessing??) and started ordering them in 50 gallon drums.
edit: one thing I am going to do (once I get the swap completed) is keep a laptop with me for trips. If I can't find E85 I'll drop a backup 93 tune in.
chizzle1 is offline
post #38 of 54 (permalink) Old 04-02-2019, 07:26 AM
DOM71's Avatar
Yeah I'm South but not deep South (Crystal City) the nearest one's are Laredo or San Antonio but there both over an hour away from me. Joy's of living in Texas lol
DOM71 is offline
post #39 of 54 (permalink) Old 04-10-2019, 01:13 PM Thread Starter
chizzle1's Avatar
need a little help: how do I get the fuel lines up to the driver side tank?
There is virtually no room between the tank and the surrounding sheet metal.
Will i need to drill holes and trim sheet metal?
I am probably going to install the pump with the stock lines first, then once I get the lines in place and cut to length swap over.
Any help is appreciated.
chizzle1 is offline
post #40 of 54 (permalink) Old 04-10-2019, 02:17 PM
Can't the existing lines be used? I thought most folks just ran different pumps for E85 conversion? I remember Speedies Garage had some images or vid showing an install of a dual fuel pump hat. Maybe some of the pics will help. Too bad the forum blocks out the site.
E85 stations near Rockingham Dragway Supercharged Scat South 1 11-07-2018 08:56 PM
E85 help. SCREAMN8 Forced Induction 7 04-27-2013 09:37 AM
Under the Hood: What is E85? AutoGuide.com Off-Topic Discussion 4 12-31-2012 08:00 PM
E85 supercharger setup theereverand Dodge Challenger SE/SXT Specific 11 09-06-2012 10:52 PM
So why the h*ll are we using E85 gas? sniper226 Off-Topic Discussion 7 05-03-2007 09:57 AM
