Frustrated with delays after new car built - Page 9 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #81 of 101 (permalink) Old 04-14-2019, 09:21 AM
Scatpacksam's Avatar
Originally Posted by Jimmy N. View Post
I hope, for your car's sake, that your patience level has improved by the time it arrives.
You may want to print out the break-in procedure and tape it to the dash, just in case.
I didn’t know that there’s a break-in procedure for this car. What is it?
Scatpacksam is offline
post #82 of 101 (permalink) Old 04-14-2019, 09:31 AM
Jimmy N.'s Avatar
Sorry, I don't know what it is for your model Challenger.
You can download the manual, which probably doesn't have much info about the procedure, or Google it.
I printed it out for my '18, and it turned out to be the same procedure for the '19 even though the '19 has more power.
In my case it's a 500-mile, three segment, list of allowable speeds and engine rpm.
It may also be worth to use standard diff gear break-in procedures for the first 100 miles, or so, getting the gear teeth properly work hardened.
2018 Challenger
2019 Challenger
Jimmy N. is online now
post #83 of 101 (permalink) Old 04-14-2019, 11:42 AM
you can download the owner's manual from the dodge website.
Its also pre-loaded on the uConnect radio from 2016 onwards
the 392 equipped models have a multi-tier break in
mentions both max engine rpm and mph recommendations (for differential break in as well)
launch control isn't enabled until 500mi cumulative use is reached
the 5.7 engines have a less stringent break in recommendation
For vehicles equipped with the 3.6L or 5.7L use the following engine break-in recommendations:
A long break-in period is not required for the drivetrain (engine, transmission, clutch, and rear axle) in your new vehicle. Drive moderately during the first 300 mi (500 km). After the initial 60 mi (100 km), speeds up to 50 or 55 mph (80 or 90 km/h) are desirable.
While cruising, brief full-throttle acceleration within the limits of local traffic laws contributes to a good break-in. However,wide-open throttle acceleration in low gear can be detrimental and should be avoided.
For vehicles equipped with the 6.4L use the following engine break-in recommendations:
Despite modern technology and World Class manufacturing methods,the moving parts of the vehicle must still wear in with each other. This wearing in occurs mainly during the first 500miles (805km) and continues through the first oil change interval.
It is recommended for the operator to observe the following driving behaviors during the new vehicle break-in period:
0 to 100 miles (0 to 161 km): • Do not allow the engine to operate at idle for an extended period of time. • Push the accelerator pedal slowly and not more than halfway to avoid rapid acceleration. • Avoid aggressive braking. • Drive with the engine speed less than 3,500 RPM. • Maintain vehicle speed below 55 mph (88 km/h) and observe local speed limits.
100 to 300 miles (161 to 483 km): • Push the accelerator pedal slowly and not more than halfway to avoid rapid acceleration in lower gears (1st to 3rd gears).
• Avoid aggressive braking. • Drive with the engine speed less than 5,000 RPM. • Maintain vehicle speed below 70 mph (112 km/h) and observe local speed limits.
300 to 500 miles (483 to 805 km):
• Exercise the full engine rpm range, shifting manually (paddles or gear shift) at higher rpms when possible. • Do not perform sustained operation with the accelerator pedal at wide open throttle. • Maintain vehicle speed below 85 mph (136 km/h) and observe local speed limits.
For the first 1500 mi (2414 km):
• Do not participate in track events, sport driving schools, or similar activities during the first 1500 mi (2414 km).
Hal H is offline
post #84 of 101 (permalink) Old 04-14-2019, 12:15 PM
Jimmy N.'s Avatar
That part always cracks me up. How would you stay under 85 mph with sustained wide open throttle?
Under 185 mph, maybe, if it's uphill.
post #85 of 101 (permalink) Old 04-15-2019, 06:07 AM
2nd gear? You'd get high rpm, but the gearing is so low that you'd reach redline before getting above that speed.
Anyway the wording is to not run sustained WOT. The part of staying below 85mph is during the 301 - 500mi of accumulated use.
The diff break-in is the main part of the speed limits to allow heat cycles w/o excessive wear on the new assembly
Hal H is offline
post #86 of 101 (permalink) Old 04-15-2019, 07:55 AM
Jimmy N.'s Avatar
Yeah, you could sit there in Second and bounce off the rev limiter for a few minutes, I suppose.
Either way, I don't even know where one could run WOT for sustained periods, other than on the Autobahn.
Diff break-in seems to be a forgotten art. I'm anal about it, and still have my fair share of issues. Thankfully not on a Challenger, yet.
post #87 of 101 (permalink) Old 04-15-2019, 08:07 AM
Brampton Ontario plant opened for full production at 6:30am today. Yay!
post #88 of 101 (permalink) Old 04-19-2019, 07:57 AM
I posted this same post in another thread, but I will also post it here too because it's related more to this thread.
I just found out that the Dodge Brampton Assembly Plant is closed today (Friday), tomorrow (Saturday), Sunday and Monday for the Easter holiday. There will be no production happening at the plant for the next 4 days. The plant will reopen for normal production again on Tuesday, April 23rd.
This really sucks. My Challenger Scat pack Wide Body is currently stuck in the F Status in the Paint Status. I wish that the Brampton plant didn't have to shut down for 2 weeks in the beginning of April. My car would've been built and shipped out and on its way to the dealer by now if the suits who run Dodge didn't temporarily shut down the plant for 2 weeks.
My car has been sitting in the F Status in the Paint Status for the last 4 days since April 16th of this week. I'm wondering whether or not my car being stuck and sitting in the Paint Status like it is for the last 4 days will pose any paint quality control issues if they already painted the car if it's sitting idle there on the assembly line picking up dust particles on the paint? These temporary plant closures and the Easter holiday are screwing up production and might cause problems with quality control in the paint process. They could've at least either waited until Tuesday until they reopened the plant to place my car into the F Status Paint Status or at least "finished up and completed" the Paint Status and put the car into G Trim Status before they shut down the plant for the long Easter holiday. I'm not happy with these ongoing shutdowns and delays. I special ordered my Charger R/T Road and Track back in February of 2008 and I never had to go through with this bullshit of the Brampton assembly plant closing, reopening then closing again like this. My 2008 Charger was built in 3 days without any delays. And back then, Chrysler was going bankrupt. The Germans who used to own Chrysler had more efficient production than the Italians who own the company today. These bullshit delays and temporary plant closures aren't doing any good for anyone of us here who are waiting for our Challengers to be built.
post #89 of 101 (permalink) Old 04-19-2019, 08:52 AM
Jimmy N.'s Avatar
Gathering dust particles while sitting inside on the assembly line may indeed be a reality.
But it's nothing compared to when it makes it out of the building and sits in a yard, with sun and/or acid rain.
After that it'll get subjected to the infamous rail dust, spreading metal particles all over it, and then it's anybody's guess what it'll be exposed to when transported by car carrier.
I would've been delighted if our car was stuck in F for four months instead of being outside, shuttled between different yards.
post #90 of 101 (permalink) Old 04-19-2019, 09:09 AM
So you think that I'm worrying for nothing about this? Do you think that my car and its paint (if it's already been painted or half painted) is safe in F Status as it is right now as it's sitting in the paint section of the assembly plant with the plant being closed for the next 4 days?
Letter to dodge and issues with my brand new scat pack status Taktics305 Challenger Issues & Problems 22 06-29-2017 07:43 PM
2014 Core 6 spd, loud clunk at low speeds Toxic 6.4L / 392ci (2011 - ?) 53 12-27-2015 11:46 AM
Dodge Unleashes Most Powerful Challenger Ever 2doorrocket SRT Hellcat 6.2L Supercharged (2015 - ) 242 11-11-2014 02:33 PM
More 2015 Pricing Info Released MCO_Carter General Challenger Discussion 30 07-20-2014 06:49 PM
Before you accept delivery of your new car check the paint - 2015 Subaru STI DetailersDomain Detailing / Car Care 11 05-12-2014 03:41 AM
