How to get my rt to do a burn out !! - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 30 (permalink) Old 06-27-2019, 09:39 AM Thread Starter
burdsvet69@gmail.com's Avatar
Hello everyone. Cant figure out how to turn whatever it ia i need to turn off to do a burn out?? After i hit the traction control button i can only spin the tiresfor afewseconds before it grabs. I do have two pictures il post. Thanks for any help!!
post #2 of 30 (permalink) Old 06-27-2019, 09:47 AM Thread Starter
I get the top light to come on that says off, by hitting the the off button..bu this just gives me a few seconds to churp the tires before thw traction control takes back over
post #3 of 30 (permalink) Old 06-27-2019, 09:48 AM Thread Starter
Another picture
post #4 of 30 (permalink) Old 06-27-2019, 09:50 AM Thread Starter
No idea what else to do. But a a nice burn out is needed...but no luck!!!
post #5 of 30 (permalink) Old 06-27-2019, 09:53 AM
Here you go.
BTW seeing that you like to smoke the tires, if you get a tazer from zautomotive it will give you line-lock.
https://zautomotive.com/product-category/tazer/
post #6 of 30 (permalink) Old 06-27-2019, 06:05 PM Thread Starter
Chally tatum
Thanks for the video. I pushed it in once quick. And it did chime...and showed the car with the word off lit up...then i held the button in for 5 to 10 seconds longer and the only thing that changed was the car with the off....went back off....nothing showed up at the bottom of my speedo....i dont have the 6 speed or the track pack??? Would that male a difference???? Its like i was gonna do a burn out for a few friends is all.
post #7 of 30 (permalink) Old 06-27-2019, 06:07 PM Thread Starter
Chally tatum
Would it by chance help if i posted a video of what im doing??? But i did follow along and try it when the guy in the video done it...thanks for any help!!!!
post #8 of 30 (permalink) Old 06-27-2019, 08:05 PM
Get a SRT8 !! LOL
Mine spins when I don't want it to !! LOL
These cars do hook up well with sticky tires, what's on yours ???
My next set is gonna be under 300 tread wear and change has needed...………………….
Unicorn is offline
post #9 of 30 (permalink) Old 06-27-2019, 08:22 PM
I am not terribly familiar with pre-2015 models but it looks like you might need the "no esp" or "tazer" from zautomotive. The links below give more background.
https://www.challengertalk.com/forum...urn-off-80459/
https://www.challengertalk.com/forum...riences-74039/
My 2015 RT M6 (no STP) can do burnouts if I deactivate TC but if I try to do donuts ESP fights me. Only solution was to get a tazer.
post #10 of 30 (permalink) Old 06-27-2019, 09:50 PM
Newoldchallenger's Avatar
RT cars can only turn it part way off. Traction control is still present even when you hit the off button.
Zautomotive makes a ESP kill switch that you can wire in that completely deletes esp, or you can make your own kill switch (Google “esp kill switch”). I have a zautomotive one in my 13’ Challenger RT and my 06’ Charger Daytona. Both with plumbed in line locks as well. Both work at the strip.
Here’s a link: https://zautomotive.com/product/noesp/
2013 Challenger R/T Automatic
Newoldchallenger is offline
The Following User Says Thank You to Newoldchallenger For This Useful Post:
silver scat (06-29-2019)
