IAT sensor - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 19 (permalink) Old 05-06-2019, 10:07 PM Thread Starter
cubanogar's Avatar
IAT sensor
Is it normal that my Intake air temp is around 160-175 degrees when ambient temperature is 78 degrees? Reason for asking is because I have install a new aftermarket kenwood radio and I connected the datas vehicle to it using the obd port. The radio displays gauges and noticed IAT at 175 degrees.
cubanogar is offline
post #2 of 19 (permalink) Old 05-06-2019, 11:09 PM
Bob Brown's Avatar
With performance pages I see IAT's typically 3 to 4 degrees above ambient unless you're talking about stop and go driving. Heat soak can be brutal in these cars with out airflow over the engine. I dont ever think I've seen 175. If you're seeing that as the typical temp, something is wrong with how your Kenwood is reading data.
2015 SRT 392 A8, Granite, Sepia, Totaled 8/9/17
2016 SRT 392 A8, Go Mango w/Satin Black Hellcat Hood and Mopar TA CAI, Tech package, Napa, Sunroof, Scott Drake Black billet fuel door, KW Adjustable Springs, BWoody Sway Bar End Links, Scott Drake Front Shock Tower Brace, Billet Tech Catch Can, Downforce Solutions Front Splitter and Wickerbill, Akrapovic CF Exhaust Tips, Xpel 20% tint.
Bob Brown is offline
post #3 of 19 (permalink) Old 05-06-2019, 11:39 PM Thread Starter
cubanogar's Avatar
I have 2013 dodge challenger rt is there a performance page on the evic screen?
post #4 of 19 (permalink) Old 05-06-2019, 11:56 PM
Bob Brown's Avatar
No. That's 2015 and up.
post #5 of 19 (permalink) Old 05-07-2019, 12:03 AM
On a NA engine, only way IAT would get close to that hot is if the car sat for a short period (intake heat soaked) of time after running for a while, but the temperature would drop as fresh air charge was coming in. On my SC setup I usually see 30F above ambient...never seen it that hot though.
I thought the pre-2015 models had the EVIC screens.
Dodge Challenger Hidden EVIC Screens and Meanings | West Coast Challengers Car Club
On my 2015 RT, I needed zautomotive's Tazer to enable performance pages on my instrument cluster.
post #6 of 19 (permalink) Old 05-07-2019, 08:02 AM
Worst I ever saw was 135F intake air temperature -- in my Boxster -- this in 116F heat in AZ. The intake air temperature would have probably been higher at least for a bit had I let the car heat soak. The engine compartment fan was on all the time, even at highway speeds, at least at speeds below which I could hear the fan running.
The 135F intake air temperature was not quite 20F above ambient. The Boxster intake air temperature normally ran 12F or more degrees above ambient for a couple of reasons I won't cover here.
160F to 175F intake air temperature at 78F ambient after the engine has been running a bit and the car moving though sounds implausible.
Rockster is offline
post #7 of 19 (permalink) Old 05-07-2019, 08:25 AM
Just went through over 100 trips data logged with my Boxster.
Highest intake temperature was on 1/27/2015 at 12:54pm. 136F. (I can't recall where the heck I was on January 27, 2015 that the intake air temperature would get to 102F.)
Because it takes the data logger a few seconds to connect with the engine controller via OBD2 right after engine start this was a few seconds, at least 5 seconds, after engine start and after the engine had sat for 27 minutes. When shut off intake air temperature was 102F.
So heat soak raised the intake air temperature -- due to heating the intake system -- by a bit over 30F.
To repeat myself, 160F to 175F intake air temperature is almost certainly implausible.
Rockster is offline
post #8 of 19 (permalink) Old 05-07-2019, 08:32 AM Thread Starter
cubanogar's Avatar
Thanks Rockster, You could be right on the sun bake part. I have a long drive to Edwards airforce base in a week or so, will look at it
post #9 of 19 (permalink) Old 05-07-2019, 08:45 AM
Edwards Air Force base... reminds me...
One nice day having left Las Vegas earlier that morning I was on 58 headed west and passing north of the base.
I was in my '88 Tempo, which gives you an idea of how long ago this was.
Everything was fine and I was enjoying the drive in my just months old new car, then a noise made itself known to me. Car felt fine. Dash showed nothing amiss. But as I drove the noise got louder and louder and very quickly too. Then the noise was so loud even though the car felt fine and there were no signs of anything wrong I lifted off the gas and was preparing to pull over.
About that time then a shadow passed overhead and then a jet at a real low altitude followed the shadow.
Noise was nearly deafening then gone.
Got buzzed by I guess someone practicing his strafing run.
Kind of cool. Had it been real though I would have been toast before I heard the noise of the jet.
Since then have driven over that stretch of 58 highway a number of times, in among other cars my 2006 GTO and my 996 Turbo. Had a jet made another appearance I was going to giving him a really moving target to practice with. Probably just as well no jet made an appearance though.
Rockster is offline
post #10 of 19 (permalink) Old 05-07-2019, 08:56 AM
Also, there are different IAT sensors can read ~50F apart from each other but I doubt that is your problem.
https://www.challengertalk.com/forum...nprobe-271146/
Have you checked what the IAT reads at cold start to see if it matches ambient temp?
If it does not then it could be that the kenwood radio is using some generic SAE standard for the IAT PID which is not giving accurate readings.
On HP tuners there are some PIDs that are vehicle specific and using the generic SAE standard results inaccurate readings.
Again, only way you will see such high intake temps is at start up when engine is hot and the system sat for some time to heatsoak (see image for example).
No More Excuses for Not Datalogging Nuke Tuning/Data 27 04-06-2018 08:15 AM
Hemi long stem vs stock 3.6 IAT sensor bench testing ddeennis Dodge Challenger SE/SXT Specific 6 10-16-2017 06:27 PM
Help with IAT Sensor RockanRoll Dodge Challenger SE/SXT Specific 2 01-17-2017 03:57 PM
P0016, cruise control not working, stalling under wot, terrible fuel economy Hamtaro Challenger Issues & Problems 11 12-20-2014 12:54 AM
