Let's talk 100k + - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 7 (permalink) Old 04-05-2019, 10:02 AM Thread Starter
72/340's Avatar
Let's talk 100k +
Challengers with over 100,000 miles. How are we holding up? I have plenty of early posts with numerous issues pre 100k. Knock on wood, I'm nearing 149k and have only replaced one ABS wheel speed sensor since my 8 year/120k warranty expired. Hoping to roll past 200k with nothing major since I've paid my dues early on haha.
'10 Challenger R/T Classic
Flowmaster Force II cat back, K&N branded CAI with Amsoil dry synthetic filter, Diablo Predator 91 CAI tune,
Mopar '11+ IAT sensor, Mopar hood struts, RPI stealth guards, R/T spoiler emblem
72/340 is offline
The Following User Says Thank You to 72/340 For This Useful Post:
rickytan (04-15-2019)
post #2 of 7 (permalink) Old 04-14-2019, 06:06 PM
swiftjr's Avatar
Send a message via Skype™ to swiftjr
I just rolled over a 110k miles on my 2009 RT. I got screwed by the Dodge star case issue on my tremec transmission at around 70k. Couldn't have been happier with the results after the transmission rebuild, Hurst linkage with g&k mods, and Hurst shifter.
Besides that, just brakes and a new battery after 9 years.
Cheers!
2009 R/T Deep Water Blue 6-Speed (Only 450 made in this trim in 2009)
20" Foose Legend Wheels and HD Brakes
Drilled and Slotted Rotors with Ceramic Pads
Hurst Linkage w/ G & K Mods and Hurst Pistol Grip Shifter
Lowered 1.7" with Eibach Springs and Sway Bars
Blue BT Catch Can-K&N Air Intake-Cabin Air Filter
Mopar Exhaust Tips,Caps,Front Badge,Steering Wheel,and Fuel Door Insert
Caliper Covers, Polished Stainless Steel Under the Hood
swiftjr is offline
post #3 of 7 (permalink) Old 04-14-2019, 06:52 PM
Tall Guy's Avatar
I have had my '10 RT for about 6 months now and its got 104k miles on it. So far in that time I've needed to replace 2 TPM sensors that died and another is on the way out and an alternator. I replaced 4 O2 sensors, all the plugs, replaced an overly loud catback with a stock system, an air filter and 2 tires as maintenance stuff. Noting too major yet although the alternator was sudden and unplanned lol.
Brian
2010 Plum Crazy Challenger RT A5
Tall Guy is offline
post #4 of 7 (permalink) Old 04-17-2019, 08:56 AM
My 2011 SRT8 A5 just getting ready to turn over 139K.
at 130 I had a lifter fail and wiped out the cam....that sucked, replaced with better parts and eliminated MDS
I have done one front and one rear ABS sensor
My factory remote start and heat seats stopped working in the 120K range.
water pump went at like 125, and I replaced it with a crap knockoff that failed a year and a half later, but that one is on me.
Consumes little or no oil, still gets decent mileage for no more MDS, puts down 472 at the wheels with the mods on it, whole bottom end is still stock, 6 speed cam, upgraded lifters, MDS delete, decked the heads and replaced the seals while the heads were off.
Figure if anything, trans will likely be next.....and I need to start on upgrading and replacing some suspension bits.
"If Brute force is not working for you, you are not using nearly enough"
Mark Bench
BenchMarkVII is offline
post #5 of 7 (permalink) Old 04-17-2019, 12:56 PM
In regards to your remote start not working, if you have any DTC it will not work but another common cause is the hood pin switch might be bad...just a thought.
post #6 of 7 (permalink) Old 04-17-2019, 01:26 PM
No DTCs and tried the hood switch, onlything on the canbus is lost connection with heated seat module
post #7 of 7 (permalink) Old 04-17-2019, 01:47 PM
The heated seat module is not listed as an inhibitor of remote start. Could very well be WIN or TIPM related.
The following table below is a list of possible causes for the inoperative Remote Start System. If any of the following conditions exist, the Remote Start System will not work. Use this information as a guide to the diagnosis of the Remote Start System.
ABORT
BATTERY VOLTAGE HIGH
BATTERY VOLTAGE LOW
BRAKE PRESSED
COOLANT TEMPERATURE HIGH
CRANK NO START
DRIVER DOOR AJAR
PASSENGER DOOR AJAR
LEFT REAR DOOR AJAR
RIGHT REAR DOOR AJAR
TRUNK/LIFTGATE AJAR
HOOD AJAR
NO HOOD SWITCH (INOPERATIVE)
FUEL LEVEL LOW
EXCESSIVE GLOW PLUG TIME (DIESEL ONLY)
FAILED COUNTER REACHED (START)
HAZARD LAMPS (SWITCH PRESSED)
IGNITION IN RUN/START
IGNITION NOT IN LOCK
IGNITION SNA (SIGNAL NOT AVAILABLE FROM OTHER MODULE)
INVALID KEY
KEY IN IGNITION
LOW RPM SHUTDOWN
MIL ON
NO AUTOMATIC TRANSMISSION
NORMAL TIME OUT CUSTOMER ACCESS
NORMAL TIME OUT RUN MODE (15 MINUTES)
NOT CONFIGURED
NOT ENABLED
NOT IN PARK OR NEUTRAL
NOT PROGRAMMED
OIL PRESSURE LOW
PANIC MODE (ACTIVATED)
POWER LOSS
RKE OFF MESSAGE
RPM TOO HIGH (EXCEEDS 2500)
START COUNTER REACHED
VEHICLE SPEED HIGH
VTA ALARMING
Hurst Performance Now Offers Challenger Talk Forum Member Discounts HurstPerformance Vendor Deals 0 02-28-2018 03:14 PM
Can we talk Throttle Bodies? Ed_r Intake & Exhaust 71 06-16-2014 08:29 PM
Talk about being meant to be!! Hydroid General Challenger Discussion 17 09-09-2012 08:51 PM
Any one here Drivers Talk this morning ?? ErikM3 General Challenger Discussion 4 06-14-2006 11:43 PM
