My challenger makes clunking noises when i drive it - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 7 (permalink) Old 04-09-2019, 11:24 AM Thread Starter
My 2013 Sxt Challenger is making weird clunking noises when only when i drive it , the noise gets more persistent the faster i go. It sounds like its coming from the rear passenger side. This started happening like 30 minutes after i did a burnout. Please help , thanks in advance.
Tookie is offline
post #2 of 7 (permalink) Old 04-09-2019, 11:46 AM
Welcome to the forum. Since you are hearing the noise in the back I suspect it could be:
- cradle bushing
- linkage (control arm, trail arm...etc) bushings
- half-shaft CV joint failing
Also check your brake pads (I assume you used your brakes instead of a line lock) and lug nuts. The 2013 also used a rubber coupler between the trans-propshaft and diff-propshaft which is known to fail/weaken over time.
Check out the online chilton manual link in this post to help you diagnose further.
https://www.challengertalk.com/forum...access-666787/
ChallyTatum is online now
Tookie (04-10-2019)
post #3 of 7 (permalink) Old 04-10-2019, 09:54 AM
DodgeCares's Avatar
Hello Tookie,
We're sorry to hear you're experiencing this noise. If you thinking you'd like to visit your Dodge dealer to get this inspected, let us know. We're available via direct message and would be happy to escalate it to a case specialist for handling.
Jasmine
Dodge Social Care Specialist
DodgeCares is online now
post #4 of 7 (permalink) Old 04-10-2019, 10:31 AM Thread Starter
Im pretty sure i found the problem , I think this is called the fender liner right ? Where could i go to get this replaced?
Tookie is offline
post #5 of 7 (permalink) Old 04-10-2019, 11:30 AM
DOM71's Avatar
https://www.stevewhiteparts.com/
You can put your Vin and get the OEM parts for your car should be under Body/Quarter Panel & Components
Also looks like you need new tires
DOM71 is offline
The Following User Says Thank You to DOM71 For This Useful Post:
Tookie (04-10-2019)
post #6 of 7 (permalink) Old 04-10-2019, 12:37 PM Thread Starter
Thanks man, and for sure getting new tires today lmao
Tookie is offline
post #7 of 7 (permalink) Old 04-10-2019, 02:33 PM
How did that happen with stock wheels? Or did something from the road just hit the liner and tear it?
2015 Dodge Challenger SRT Hellcat Review AG Jeff Dodge Challenger News 9 02-18-2016 06:08 AM
More 2015 Pricing Info Released MCO_Carter General Challenger Discussion 30 07-20-2014 06:49 PM
5th annual MOPAR MEET @ Mohegan Sun!! Pdean13 North-East 13 03-27-2013 12:50 AM
