Syncromesh and TR6060 1st-2nd Grind - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 6 (permalink) Old 05-10-2019, 03:15 PM Thread Starter
McCloud's Avatar
I was out researching the TR6060 and ran across the links below. You will probably want to skip most of the first Video, he drags things out just a little but he does give reference to a solid solution to the 1-2 grind. The second is going through how the synchromesh synchros work. You'll see why the Synchromesh Sycnchros in the TR6060 need fluids with the breakaway properties of ATF due to the materials used on the bulk ring of the synchros. Finally the third link is the damage that occurs from grinding the gears.
McCloud is offline
The Following User Says Thank You to McCloud For This Useful Post:
ChallyTatum (05-10-2019)
post #2 of 6 (permalink) Old 05-10-2019, 04:31 PM
This subject will be beaten to death by all owners of vehicles with Tremec transmission that are unfortunate enough to have transmissions that fall into the sloppy tolerance group. The reality is, Tremec just has a wider acceptable tolerance standard than other manufactures.
Most all issues are with the initial recommended fill of approved lubricant anyhow!
Tremec now offers a new improved GL4 spec lubricant. Think they are trying to cure the sloppy tolerance issue as well.
Desertdawg is online now
post #3 of 6 (permalink) Old 05-10-2019, 05:41 PM
oldhp's Avatar
My 2016 R/T did the 1-2 grind only when first shifted. Drive it around town and by the 3rd or 4th 1-2 shift it was almost gone, but you could still feel it somewhat. I put in Red Line C+ATF per Dave at Red Line. It took maybe 5 miles'ish and I thought I had a different transmission. Zero gear grinding, nibbling, zip...nothing. Within 20 miles the whole transmission shifted smoother, more confidently going into each gear. Even reverse at first start would go into gear easier. Best thing I ever did to a car as far as fixing something.
I called Tremec and a honest tech told me that these transmissions where developed with Dexron III. He said the different manufacture's used their own trans fluids to keep it simple, but that the Dexron III has the correct friction characteristics for the synchronizers to work properly.
oldhp is offline
post #4 of 6 (permalink) Old 05-11-2019, 04:42 AM Thread Starter
McCloud's Avatar
I agree with using the coreect fluid. I alxo checked with with Tremec on the fluid and got the same respose. I decided to switch to Amsoil Synchromesh and it corrected the grinding issue. I do think however replacing/upgrading the synchro will imrpove the shifting overall.
Sent from my SM-T350 using Tapatalk
McCloud is offline
post #5 of 6 (permalink) Old 05-11-2019, 07:39 AM
I agree, down the road when I replace the clutch I will do the syncro upgrade.
post #6 of 6 (permalink) Old 05-11-2019, 07:57 AM
my 18 1-2 has been nibbly since day 1. Never got any worse or better. I changed out the fluid with OEM at 30k miles and its only maybe half as bad as it was. Wondering if it came underfilled like the Jeep JKs
BilletTA392 is offline
