Top Speed - Page 5 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #41 of 70 (permalink) Old 06-12-2019, 08:31 AM
skypilot's Avatar
Aero limits them to about 200mph, just too much drag.
skypilot is offline
post #42 of 70 (permalink) Old 06-12-2019, 08:40 AM
Jimmy N.'s Avatar
Originally Posted by Cominfromcamaro View Post
650hp cars barely go 205 so I can’t imagine it’s got much left at that point.
If memory serves me, the Hellcat is supposedly good for 199 mph, and the Redeye for 203.
That's impressive, considering the aerodynamics of a Challenger.
2018 Challenger
2019 Challenger
Jimmy N. is offline
The Following User Says Thank You to Jimmy N. For This Useful Post:
Cominfromcamaro (06-12-2019)
post #43 of 70 (permalink) Old 06-12-2019, 08:48 AM
Cominfromcamaro's Avatar
Yeah that’s the truth. I was thinking more ZL1/Mclaren etc cats made for top end speed. That’s still insanely fast.
Cominfromcamaro is offline
post #44 of 70 (permalink) Old 06-12-2019, 09:28 AM
Originally Posted by silver scat View Post
126, I'm a sissy. I'll try harder...
Same here. 126 out in a desert canyon on a two lane road. Also slowed down when I saw headlights coming.
2010 PCP Dodge Challenger RT Classic -TRADED
2014 Torred Dodge Challenger RT Shaker #1253 -GONE
2018 Torred SRT Challenger Hellcat
this should be it for a while...
"Beyond the Palace, Hemi powered drones scream down the boulevard......"
PurpleHaze is offline
post #45 of 70 (permalink) Old 06-12-2019, 09:33 AM
Slidd's Avatar
And those limits are probably based on what the OE tires are rated at, right?
Sort of. The SXT had V rated tires (149 mph) so the 135 might be for the base touring (soft) suspension but you could order Super Track Pack which gave you Y rated 186 mph tires yet no adjustment was made.
Same thing with R/T although not sure why it has a 155 mph governed speed when the standard tires are V rated, but again STP was available with the Y rating.
The 186 mph Scat Pack limit makes sense as the same STP Y rated tires were standard.
The SRT and Hellcat cars came with (Y) rated tires which is 186+ mph so they are fine.
Demon and Scat Pack 1320 cars have W rated drag radials so they are limited to 168 mph.
Slidd is offline
The Following User Says Thank You to Slidd For This Useful Post:
Jimmy N. (06-12-2019)
post #46 of 70 (permalink) Old 06-12-2019, 10:10 AM
I took it off wikipedia but yeah it usually is what the tires are rated at. But I think the scat pack is probably done at the 180’s. 650hp cars barely go 205 so I can’t imagine it’s got much left at that point.
You took what off wiki? He was asking if the PCM speed limit is related to tire rating. I think my stock firestones had a "V" speed rating which is 149MPH...the limit on the PCM was 155MPH. Like I said, it's the brakes that will have you more worried than the tire speed rating...at least on the RT.
The HC limit is 254MPH which is higher than the tire speed rating.
post #47 of 70 (permalink) Old 06-12-2019, 10:37 AM
Slidd's Avatar
SRT and Hellcat tires are (Y) rated which is above 186 mph. They don't give it an exact number but a (Y) is good for higher speeds than a Y tire which has a 186 mph limit.
Slidd is offline
post #48 of 70 (permalink) Old 06-12-2019, 10:41 AM
DOM71's Avatar
Think hes talking about the governor set on the vehicles. Car will cut off at xxx speed
But it's also good to get a good speed rating tire especially if you like to drive fast
DOM71 is offline
post #49 of 70 (permalink) Old 06-12-2019, 10:53 AM
What each engine was good for. Just realized it was the charger not the Challenger but they should be pretty close to the same.
254 MPH? Is that the speed limiter? Because there’s no way in hell a hellcat is even close to that, it’s like barely 200. There’s like 4 cars in the world that can go 250 and they’re Bugatti’s and Hennessey’.
post #50 of 70 (permalink) Old 06-12-2019, 11:00 AM
Slidd's Avatar
I was just addressing the statement that Hellcat tires had a 186 mph rating, they don't. They are rated at above 186 mph.
Slidd is offline
