Is it true that the shaker package option is non-functional? - Page 5 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #41 of 69 (permalink) Old 04-30-2019, 08:49 PM
chizzle1's Avatar
for what it's worth: my shaker setup flows a sufficient amount of air to enable the 7.0 liter to make ~490hp to the wheels (about 540 crank).
I'd take a look at MAP sensor readings before arbitrarily bashing NA induction systems.
chizzle1 is offline
The Following User Says Thank You to chizzle1 For This Useful Post:
mcm95403 (05-01-2019)
post #42 of 69 (permalink) Old 05-01-2019, 07:51 AM
Frank Julian's Avatar
Originally Posted by praiseV8 View Post
I'm aware, he was asking about the hoods though.
Of which I still don't understand why hoods aren't an option in the build sheet across most trims.
Wish they were, I hate the old, and new Hellcat hood. Only thing about the car I do not like is the hoods. I am old school though and like the "Power bulge" on the 2015-2018's I guess if I was getting a new 1320 Scat or Scat I could get used to the old SRT hood (the one that looks like an AAR Hood) or order a the older Power Bulge hood.
Frank Julian is online now
post #43 of 69 (permalink) Old 05-01-2019, 11:49 AM
Sublime69's Avatar
The misconception is that the shaker is somehow "force feeding" air into the engine. This is absolutely not true. And if you think FCA actually designed the shaker around wind tunnel testing to bring the functionality of the shaker up to that level, then I couldn't laugh more.
Just because the shaker is sipping on outside air doesn't mean it's the same as a ram air effect, which has been mentioned and argued on this forum throughout the years. The shaker isn't forcing any more air into the engine than a non-shaker car would. If you think that's worth the price from a performance perspective, good luck. The only thing that makes it worth the price in my opinion is the looks factor.
And efficient and functional go hand in hand. Efficiency is a performance measure of the functionality. The shaker may technically be "functional" since it's baby bottle feeding on air around the hood rather than in the engine bay, but it's not very efficient compared to other functional systems.
Sent from my Pixel using Tapatalk
'67 Belvedere II - 426 Hemi/727/3.55
'68 Road Runner - 383/727/3.23
'69 Charger R/T - 512/727/4.10 Dana 60
'77 Monaco A38 ex cop car - 440/727/2.71
'79 'Lil Red Express - 360/727/3.55
'89 Diplomat AHB ex cop car - 408/727/3.55
'12 Challenger SRT - 392/6 speed/3.92
'16 Chrysler 200C - 3.6/ auto
Sublime69 is offline
post #44 of 69 (permalink) Old 05-01-2019, 12:18 PM
praiseV8's Avatar
But it is technically functional none the less, and any arguing beyond this point becomes pointless semantics.
2016 Dodge Challenger R/T 392
Bright White, A8+V6
praiseV8 is offline
post #45 of 69 (permalink) Old 05-01-2019, 02:37 PM
mcm95403's Avatar
I'm amazed that no one has yet to mention the fact that the top of the Shaker airbox is wide open and does NOT seal to the hood, so it's drawing hot air in from the engine compartment. Also, the opening at the bottom is open to the fenderwell just like all the other cars.
On mine I'm looking at setting up a tube to feed the bottom of the airbox from the passenger side headlight and also looking at sealing off the top so that the only path for air to get into the airbox is from an outside source.
mcm95403 is offline
post #46 of 69 (permalink) Old 05-01-2019, 03:12 PM
Well they got the smoke...but I don't see the mirrors.
ChallyTatum is online now
chizzle1 (05-02-2019)
post #47 of 69 (permalink) Old 05-02-2019, 05:29 AM
It is completely functional and does exactly what it was designed to do: It was designed to separate people from more of their money and functions quite well at that.
post #48 of 69 (permalink) Old 05-02-2019, 06:03 AM
chizzle1's Avatar
chizzle1 is offline
post #49 of 69 (permalink) Old 05-02-2019, 07:59 AM
Air passes through the Shaker scoop and goes to the intake, so it's obviously functional.
OregonScat is offline
post #50 of 69 (permalink) Old 05-02-2019, 09:41 AM
keon718nyc's Avatar
Threw some LED's in the Shaker. Now its even more function-able hehe!!!
ID:	944783   Click image for larger version
2019 Challenger 392 Shaker
keon718nyc is online now
Shaker hood scoop functional or cosmetic? Dodgenovice 6.4L / 392ci (2011 - ?) 30 05-01-2016 08:25 AM
2015 R/T Shaker dodgeboy90501 General Challenger Discussion 3 02-08-2015 04:47 PM
AFR Functional Shaker Scoop vs LMI Bradley Manning wannabe Intake & Exhaust 7 02-22-2014 04:32 AM
Option Package Questions? movnviol Dodge Challenger R/T Specific 14 10-24-2013 10:28 AM
