Well, my trunk is leaking and my Tazer is ruined... - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 17 (permalink) Old 12-20-2018, 04:46 PM
hawkgfr's Avatar
Is the battery leaking?
My past fun cars..
3 1965 GTO's and an 05 GTO
1 00 GTP
3 TA's 76/85/01
2 Mustangs 96 GT and 04 Mach1
3 Hemi ram trucks 03/12/14 Bighorn
5 Corvettes /07/11/ 12/13/15
TRADED
2012 Challenger SRT 6sp manual.
Traded
2013 arctic white corvette 6 speed manual.
2015 Corvette Stingray Sold 8 15 2015
Traded
2015 RT 392 Scat Pack M6 Torred. stripper.
Current
2016 R/T Scat pack 392 Shaker. Bright White SPAG M6 (1 of 306)
hawkgfr is offline
post #12 of 17 (permalink) Old 12-21-2018, 03:22 AM
hemi4us's Avatar
Originally Posted by Tshane72 View Post
I hope you don't have emissions testing in the state where you live, I know with my Diablosport Tuner I have to return the car to the stock tune so it will pass the emissions test here in NC.
Tazer is not a tuner. huge difference and would not affect emissions as far as I know, unless it simply has to be removed from the ODB port by testing persons so they can access the ODB
2015 Mods:
Axis Model II's.
Firestone Indy 275/40/20
Rolling Thunder Reso delete.
GPC Trunk Pull Handle.
Spare/Jack/Foam Delete.
GPC Phantoms.
Mopar O.E. Black Fuel Door.
Hellcat OE. ABS Cover.
Rear Seat Delete.
2014 Dodge Viper Seats.
hemi4us is offline
post #13 of 17 (permalink) Old 12-21-2018, 04:48 AM
Cuda340's Avatar
Here's a good way to find the leak yourself. Get in the trunk with a flashlight and close the lid. Have someone, with a hose, slowly run water around the edges of the trunk lid and the tail lights. You'll be able to see where it is coming in. This is what dealers do. (Note- Afterward, if your friend tries to be funny and won't let you out, pull the emergency release).
If you don't want to crawl into the trunk, another way, is to rent one of these guys. They work cheap- usually for a bunch of bananas.
Cuda340 is offline
The Following 2 Users Say Thank You to Cuda340 For This Useful Post:
metalhead (12-21-2018), Rob446 (12-21-2018)
post #14 of 17 (permalink) Old 12-21-2018, 05:38 AM
Rob446's Avatar
I would contact zAutomotive to see if they can help with repair or replacement as well as help to unmarry. Tazer does not make changes to the ECU so you should not have any issues with emission testing.
It appears there was a significant amount of water in the trunk for an extended amount of time. Hope you will let us know when you determine how the water got there.
Rob446 is offline
post #15 of 17 (permalink) Old 12-21-2018, 11:46 AM
Yellow Jacket 2012's Avatar
Is the battery failing and is it battery fluid and not water?
If it’s a vehicle failure I’d try and get them to replace the unit as they created the situation, you may also see if the tazer company would be kind enough to replace it under unique circumstances. The worst they can say is no.
Yellow Jacket 2012 is offline
post #16 of 17 (permalink) Old 12-21-2018, 03:54 PM
Frank Julian's Avatar
I would see if there is a way to set the car back to stock if the Tazer is married to it.
Frank Julian is offline
post #17 of 17 (permalink) Old 05-13-2019, 05:16 AM
Whatever happened with this? What was causing the leak? The Tazer part would be an easy fix, buy a new one, install the firmware version that came out before they started marrying it to your car, change the settings back to stock, update the Tazer firmware, marry it to the car and make all the changes.
