Where To Find Engine Break In Info - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 38 (permalink) Old 11-02-2018, 05:34 PM Thread Starter
Hi all. My new Scat was delivered to my dealer today and I will be picking it up Monday. My dealer gave me the info packet that was in the trunk with the what I thought included the owners manual but apparently it doesn't. What literature I have doesn't discuss proper engine break-in during the first 500 miles. So I have two questions:
1. Should the car come with a detailed owners manual and not just the vague "Essential Information Guide"?
2. Anyone no the proper procedure for a 2019 6.4 SRT engine?
2019 TorRed Scat Pack Wide Body M6
Ed1774 is offline
post #2 of 38 (permalink) Old 11-02-2018, 05:50 PM
You should get an owners manual with the car. The owners manual may have been held back to hand it over to you when the car is handed over to you.
In the meantime, here's the section on engine break in from the 2018 Challenger SRT/Hellcat Owner's Manual (5th edition):
ENGINE BREAK-IN RECOMMENDATIONS
The following tips will be helpful in obtaining optimum
performance and maximum durability for your new SRT
vehicle.
Despite modern technology and World Class manufacturing
methods, the moving parts of the vehicle must still
wear in with each other. This wearing in occurs mainly
during the first 500 miles (805 km) and continues through
the first oil change interval.
It is recommended for the operator to observe the following
driving behaviors during the new vehicle break-in
period:
0 to 100 miles (0 to 161 km):
• Do not allow the engine to operate at idle for an
extended period of time.
• Depress the accelerator pedal slowly and not more than
halfway to avoid rapid acceleration.
• Avoid aggressive braking.
• Drive with the engine speed less than 3,500 RPM.
• Maintain vehicle speed below 55 mph (88 km/h) and
observe local speed limits.
100 to 300 miles (161 to 483 km):
halfway to avoid rapid acceleration in lower gears (1st to
3rd gears).
• Drive with the engine speed less than 5,000 RPM.
• Maintain vehicle speed below 70 mph (112 km/h) and
300 to 500 miles (483 to 805 km):
• Exercise the full engine rpm range, shifting manually at
higher rpms when possible.
• Do not perform sustained operation with the accelerator
pedal at wide open throttle.
• Maintain vehicle speed below 85 mph (136 km/h) and
For the first 1500 miles (2414 km):
• Do not participate in track events, sport driving schools,
or similar activities during the first 1500 miles (2414 km).
NOTE: Check engine oil with every refueling and add if
necessary. Oil and fuel consumption may be higher
through the first oil change interval. Running the engine
with an oil level below the add mark can cause severe
engine damage.
My advice would be to unless your car's owner manual forbids it to have the oil changed early. I had my 2018 Hellcat's oil changed at around 500 miles, then again at 2K miles then at 5K miles. Car has just around 8K miles on it now and I'll have the oil changed again sometime between now and when it gets to 10K miles.
Rockster is offline
post #3 of 38 (permalink) Old 11-02-2018, 06:02 PM Thread Starter
Thanks Rockster. I will make sure I get a proper owners manual on delivery day. As for first oil changes I always changed a new vehicle at 500 miles then follow a 5,000 oci after that. With this car I'll follow what you advised. I already have several oil change worth's of Penzoil 0W40 in the garage. What filter you running, Mopar/SRT filter?
Ed1774 is offline
post #4 of 38 (permalink) Old 11-02-2018, 06:22 PM
Grnpwr2015's Avatar
Mine just received a brand new 6.4.I too did 500 mile change.next one at 3000 mark.I was verbally told nothing over 5000 rpms.so far so good.1500 on it.zero oil use thus far.
Grnpwr2015 is offline
post #5 of 38 (permalink) Old 11-02-2018, 06:24 PM
Grnpwr2015's Avatar
I believe the srt filter is the better of the two.I think it's larger.guys on here are,a great plethora of all around know how on these beautiful cars.
post #6 of 38 (permalink) Old 11-02-2018, 06:39 PM
Owners manual is online and is an app in Uconnect. Doesn't come with a paper manual. 300-500 mile break-in is fun. Basically it says to wring it out. My 18 SP hasn't used a drop of oil in 1200 miles. Suggest you download it on your smart phone so you have it in car. Can't access the Uconnect app while moving.
Jekyll is offline
The Following User Says Thank You to Jekyll For This Useful Post:
Ed1774 (11-02-2018)
post #7 of 38 (permalink) Old 11-02-2018, 07:13 PM
Slidd's Avatar
Call Dodge customer service at 1-800-423-6343 to request your Owners Manual, have your VIN handy and they will send them to you, think it will be three books.
On the oil, remember the 6.4L requires oil changes minimum every 6 months or 6,000 miles, the factory filter is the 899 which you can buy anywhere or the 041 SRT filter is available thru Amazon.
Slidd is offline
post #8 of 38 (permalink) Old 11-02-2018, 08:45 PM
SunnyS's Avatar
Never really got the month thing with Oil changes.Oil does not break down sitting in the bottom of a oil pan. I guess if you are a Taxi driver were your car sits for hours running you could apply the month schedule to the mix.They should put it in as hours like my John Deere.
SunnyS is offline
post #9 of 38 (permalink) Old 11-03-2018, 08:45 AM
Slidd's Avatar
Agree but if the worst happens, they will be looking for service records or twice yearly receipts otherwise they will blame the failure on your "neglect". Once per year with a good synthetic on a low mile car is totally fine but FCA won't buy it strictly because it's an SRT so every owner must be racing it.
Slidd is offline
post #10 of 38 (permalink) Old 11-03-2018, 05:29 PM
Cuda340's Avatar
If you have low mileage at the 6 month period, it is assumed that you take a lot of short trips. This can cause water to occur in your oil.
Even in perfectly sealed engines, water intrudes and forms condensation within the engine. For every gallon of gasoline burned, a little more than a gallon of water vapor forms as a byproduct. During the course of longer trips, the engine reaches its ideal operating temperature, and the heat causes any condensed water to evaporate. If the car travels only short trips, abnormal water accumulation can result because the engine does not reach a temperature that is sufficient to burn off the excess water.
Cuda340 is online now
The Following 3 Users Say Thank You to Cuda340 For This Useful Post:
BlackHemi41 (11-04-2018), Bob Ricewasser (11-05-2018), SRTDAD (11-04-2018)
