R1 Concepts Premium Series Rotors for your 5.7L R/T - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 58 (permalink) Old 10-04-2013, 02:52 PM Thread Starter
Supporting Vendor
Speedlogix-Sales's Avatar
Feedback Score: 2 reviews
If you are looking for Rotors for your 5.7L Hemi. R1 Concepts and Speedlogix have you covered!
Here is the R1 Concepts Premium line of rotors in which you have a selection of:
Cross Drilled and Slotted:
Front: R1 Concepts Cross Drilled and Slotted Front Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L R/T
Rear w/ 12.5" Vented Rotor: R1 Concepts Cross Drilled and Slotted Rear Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L W/ 12.5" Vented Rotor
Rear w/ 13.6" Vented Rotor: R1 Concepts Cross Drilled and Slotted Rear Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L W/ 13.6" Vented Rotor
Cross Drilled:
Front: R1 Concepts Cross Drilled Front Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L R/T
Rear w/ 13.6" Vented Rotor: R1 Concepts Cross Drilled Rear Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L R/T W/ 12.5" Vented Rotor
Rear w/ 13.6" Vented Rotor: R1 Concepts Cross Drilled Rear Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L W/ 13.6" Vented Rotor
Slotted:
Front: R1 Concepts Front Slotted Premium Brake Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L
Rear w/12.5" Vented Rotor: R1 Concepts Rear Slotted Premium Brake Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L
Rear w/ 13.6" Vented Rotor: R1 Concepts Cross Slotted Rear Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L W/ 13.6" Vented Rotor
OEM Replacement
Front: R1 Concepts Premium OEM Replacement Front Brake Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L
Rear w/ 12.5" Vented Rotor: R1 Concepts Premium OEM Replacement Rear Brake Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L W/ 12.5" Vented Rotor
Rear w/ 13.6" Vented Rotor: R1 Concepts OEM Replacement Rear Rotors 05-14 Challenger, Charger, 300, Magnum 5.7L W/ 13.6" Vented Rotor
About R1 Concepts Premium Series:
Features:- Chamfered holes for increased durability
- Double disc ground finish reduces rotor vibration
- Meets or exceeds OEM standards
- Same Vane count as OEM parts
- Mill balanced ensures long lasting durability
- High Carbon
- Black Electro-Coated for rust protection
- Fitment guarantee
Premium Series
The Premium Series are created with high carbon for better, stable performance that will meet or exceed OEM standards. Each rotor has the same vane counts as an OEM rotor and will fit your vehicle without any modifications. R1Concept's black electro coating process will help protect against rust and extend the life of the rotor. In addition, the brake rotor have center split core castings for increased strength and stability. Every brake rotor is double disc grounded and mill balanced to minimize any thickness variations and vibrations to provide quieter and smoother stops.
Premium Series vs. E-Line Series
The Premium series uses high carbon which results in a stronger rotor that can handle more demanding driving styles and conditions. In addition, the Premium Series rotors uses a black electro-coating process that gives the rotor a two-tone color finish which will also help protect against rust. The Premium Series also have center split castings while the E-lines series do not.
The E-Line Series uses an iron grade of G3000 which is great for those who do not need the additional stopping power. E-Line Series rotors come with a silver zinc plating through out the rotor and is not two-toned in color.
Speedlogix |
Speedlogix-Sales is offline
post #2 of 58 (permalink) Old 10-17-2013, 10:13 AM Thread Starter
Supporting Vendor
Upgrade your R/T rotors today!
post #3 of 58 (permalink) Old 10-22-2013, 10:34 AM Thread Starter
Supporting Vendor
Upgrade your R/T Rotors today!
post #4 of 58 (permalink) Old 12-10-2013, 09:46 AM Thread Starter
Supporting Vendor
post #5 of 58 (permalink) Old 12-13-2013, 11:50 AM Thread Starter
Supporting Vendor
post #6 of 58 (permalink) Old 12-17-2013, 01:11 PM Thread Starter
Supporting Vendor
Awesome upgrade for your R/T! Your choice of drilled, slotted, drilled and slotted or OEM!
post #7 of 58 (permalink) Old 12-21-2013, 09:04 AM Thread Starter
Supporting Vendor
Upgrade to R1 Concepts today!
post #8 of 58 (permalink) Old 12-23-2013, 02:31 PM Thread Starter
Supporting Vendor
post #9 of 58 (permalink) Old 01-07-2014, 09:52 PM
Galvatron's Avatar
If your R/T is due for rotors, we've got you covered with the highly popular selection from R1!
[CENTER]GALVATRON
2010 TorqStorm Supercharged plum crazy Challenger R/T on 22" VOSSEN CV3 wheels!!
Current 1/4 mile (before supercharger): [email protected] bangin' 'n clangin'!!!
Galvatron is offline
post #10 of 58 (permalink) Old 01-10-2014, 05:37 PM Thread Starter
Supporting Vendor
Best way to upgrade your R/T Rotors!
  Dodge Challenger Forum: Challenger & SRT8 Forums > Vendors > Speedlogix
'09 Challenger R/T Gathered Specs / Equipment & Info Related SIX-PAK Dodge Challenger R/T Specific 150 10-19-2014 02:38 AM
5.7L NON R/T available in September TurboAWD General Challenger Discussion 18 04-25-2008 12:57 PM
