How to make car track-ready? - Dodge Challenger Forum: Challenger & SRT8 Forums
Road Course / Autocross This is the place to post road course and autocross stories and event info
post #1 of 8 (permalink) Old 05-05-2019, 10:37 PM Thread Starter
Chefalan23's Avatar
I’ve never tracked a car before, and I want to run my 14 srt 392 on a road circuit. Nothing competitive, just for fun. I have a friend that is really big into it. He builds e30 track cars, and he’s been giving me advice to get started. First things first, I want to make sure the car is properly set up for safety.
About the car :
Michelin pilot super sport - staggered 275/295
Barton shifter
K&N drop-in
Straight pipes
52k miles
Stock 4 piston brembos
The following are the mods that my buddy suggested
Stainless brake lines
High temp brake fluid
New OEM brembo pads
180* tstat w/ tune
Dual core radiator & fans
Sway bars
Please chime in with any other mods you think I need, or if you think any of the above are unnecessary.
Thanks
09 R/T
SRT stripes
Katzkin two tone leather/suede
K&N intake
Magnaflow competition catback
Eibach pro kit
Chefalan23 is offline
post #2 of 8 (permalink) Old 05-06-2019, 02:04 PM
Handling-wise, make sure you brace your towers front and rear. Front made a huge improvement in the road feel. Just put the BMR rear brace yesterday and it seems to help even a little more.
Quinn392 is offline
post #3 of 8 (permalink) Old 05-06-2019, 03:45 PM
Supporting Vendor
stevewhiteparts's Avatar
Feedback Score: 6 reviews
high quality brake fluid is a must, something like
and depends on your budget, the list of mods can be exhausting
PLEASE VISIT
828-324-4410
800-779-3634
stevewhiteparts is offline
post #4 of 8 (permalink) Old 05-06-2019, 03:58 PM
There is a member that has a nice set of rims for sale that he used when he tracked his car. Maybe check out the " for sale " section and see if they peak your interest? Other then that. Drive it as is and don't overdrive it and have fun. You will find out what you need , based upon your experience.
Wilsumbody is offline
The Following User Says Thank You to Wilsumbody For This Useful Post:
Pauljw (05-06-2019)
post #5 of 8 (permalink) Old 05-06-2019, 07:28 PM
John Matthews's Avatar
The one mod that would be worthwhile doing now would be the brake fluid. Brake fade will make you have to take a break sooner then you might want. The car is heavy. Everything else can wait to see how much you like it before throwing as much money as you want down a bottomless pit. You might need new tires if you have a hardcore weekend.
2012 SRT automatic, PB 12.0490 with MT drag radials and trinity 93 octane tune.
PB [email protected], Magnuson supercharger 5.5psi, forged piston/rods, Hellcat injectors, 10/1 compression, tuned for 90 octane.
John Matthews is offline
post #6 of 8 (permalink) Old 05-06-2019, 08:16 PM
The engine and car must be problem free. No "minor" coolant leak or oil leak.
You do *not* want to leak coolant or oil on the track, or on your rear tires, for obvious reasons.
The cooling system must be pressure tight even if the coolant temperature is very high. With other cars I've seen 226F coolant temperature even on the street (well, mountain road) with the car being pushed hard. If the system can't hold pressure the extra fans and low temp T-stat won't matter. The coolant will flash to steam and the steam blocks coolant flow over the hottest areas and localized engine overheating occurs and kiss the head gasket good bye.
The oil/filter should be very fresh and at the right level. (Be sure to carry extra bottles of oil in case at the track the level drops. Have a friend carry them in his vehicle.)
Other vital fluids should be good too.
The engine should be in good tune. Spark plugs should be in good condition. Better to err on the side of caution and show up with new plugs rather than old plugs. Do not use anti-seize on the plugs.
Air filter and fuel filter (if serviceable) should be fresh.
The brake hardware should have plenty of metal.
Be sure you check pads for uneven wear from every angle. The visible portion of the pads might show quite a bit of pad thickness, while the hidden portions may be nearly to the backing plate. The rotors should likewise not be too thin nor show signs of cracking or other abnormalities.
The brake fluid should be flushed and bled. Brake fluid is hygroscopic -- attracts moisture -- and if the fluid gets hot and it will to state the obvious the water lowers its boiling point. Ain't nothing like coming upon a sharp/slow turn and hitting the brakes and pedal sinks nearly to the floorboard.
Tires should have plenty of tread, be properly inflated and have no slow leaks. They should be properly balanced. Be sure the lug bolts are properly torqued down.
Alignment doesn't have to be anything special but it wants to be in spec.
The car should have nothing loose. No loose underbody panels, no loose exhaust. No leaking exhaust either.
Be sure you run unleaded race gas in a ratio with street gasoline to raise the octane level a few points above what the engine calls for. For instance if the owners manual says to use 91 shoot for 93 or higher. As time passes an engine's octane requirement can go up.
In some cases tests have found pure race gasoline delivers more than just a higher octane to combat detonation the racing gasoline is really blended to burn better at higher RPMs. So the advice is to when race gasoline is available to run this diluted as little as possible with street gasoline. However, some report the high octane "race" gas really appears to offer nothing beyond higher octane. Guess you have to try it diluted and then maybe a lot less diluted and see what it does for your car's engine.
Be sure the car -- cabin, glove box, storage compartments, the back seat, and under the front seats, trunk, everywhere -- is free of any loose items. You don't want something rattling/banging around to distract you. Nor do you want an old stuffed toy to come out from under your seat and get under a pedal or cause you to get your feet tangled up going for a downshift and braking for a hard/sharp turn.
Mirror inside and out should be clean and streak free.
Likewise, glass inside and out should be clean. No streaks which hit by the sun possibly blinding you or distracting you.
Be sure you dress appropriately. The cabin can get quite hot. Drink plenty of water. Stay hydrated.
Bring appropriate snacks to keep your energy level up. Don't OD on coffee or energy drinks. No alcohol.
If you can arrange for a wife, GF, buddy to video your laps for later enjoyment, that's always a good thing. And she/he can drive in a 2nd car so you have a place to stash extra oil, water bottles, your jacket, billfold, phone, etc. (out of sight and the car locked!) while you are on the track.
Be careful in the "pits". You don't want to get run over by another driver not paying attention or still racing even though he's off the course. Keep your eyes wide open and your head on a swivel.
Take a cool down lap and in the pits let the engine idle to shed the considerable heat load the engine develops on the track.
Last but not least be sure you have adequate track insurance just in case.
Rockster is offline
post #7 of 8 (permalink) Old 05-07-2019, 07:06 AM
Supporting Vendor
highly recommend you tag along with an experience buddy, first day at school can be very intimidating.....also if your at a track that offers driving assistance, well worth the money, whatever you thought you knew about driving, can be thrown out the window
a really good place to start is with NASA Pro Racing and HPDE events
they will force you into novice class and you will have a on board instructor to help you get started
https://www.nasaproracing.com/hpde/
at the very beginning worry about your driving, not so much about improving the car.....as your abilities improve, then modify the car, much too often people forget the most important mod, the driver
ps, make sure the car is sound as previously stated, torque wrench on hand, check lug nuts before every track on track session, good quality air gauge, carry extra fluids,
post #8 of 8 (permalink) Old 05-09-2019, 11:11 PM
wasp392's Avatar
It’s a good list except the radiator/fans. The SRT has good cooling system. Your buddy might not be familiar with our cars. Tune along with 180* helps with cooling as well. I’d say SS brake lines are not necessary yet but if you’re doing DOT 4 brake fluid you might as well.
Must bed the brakes in before you hit the track. Very important.
I’d concentrate more on driver mod than spending money unnecessarily.
The SRT trim is already “occasional” track ready.
Also very important to have the right tire temperatures.
Torque your wheels at proper specs and check them a couple of times during the event.
Traction is one of the most crucial mods too.
Just go out there and have fun.
wasp392 is offline
The Following User Says Thank You to wasp392 For This Useful Post:
stevewhiteparts (05-10-2019)
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Road Course / Autocross
Buying a used Challenger - what to know? Spartan040 General Challenger Discussion 27 02-11-2019 10:55 AM
HC Diminished value? AZpueblo General Challenger Discussion 46 12-12-2016 05:10 PM
2014 Core 6 spd, loud clunk at low speeds Toxic 6.4L / 392ci (2011 - ?) 53 12-27-2015 11:46 AM
Getting Road Course Track Ready (HPDE at least...) O_Racing Wheels, Tires, Brakes, and Suspension 14 01-18-2015 05:58 PM
