I'm about to order the Voxx Demon wheels from Discount Tire but I have a question on tire size. Do any of the 20x9 OEM wheels on Challengers come with 245 tires stock or 275 tires.
Thanks. If I still had an R/T I might go larger but I only have an SXT now and stock size is fine with me. Why Voxx and not FR?
1. It's 9". With the 20mm offset there's only 1/4" clearance between wheel and control arm. I don't want to squeeze in anything larger then factory specs.
2. I like the Voxx spoke design better. FR looks a little narrower.
Voxx is not oem spec. Oem demon wheels are 18”. These are 20”. Same for the factory reproduction wheels which I have and I think look better than the voxx
Sensors will fit but you will have to buy new lug nuts from gorilla lug nuts
