TPMS Out? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 8 (permalink) Old 04-18-2019, 05:27 PM Thread Starter
Jayturk's Avatar
TPMS Out?
I just recently updated my wheels without updating the sensors. Everything was fine until today, I get in and the system states 22psi driver rear, I get out to check, looks normal. I was able to check the pressure and it was not 22-24psi. I'm thinking the pressure monitor was damaged in the transfer to the new wheel, just curious about the delay. Now I'm questioning whether to replace the one or the set. Leaning toward replacing the set like I should have done in the first place. Has this happened to anyone? Thanks for the input.
Jayturk is offline
post #2 of 8 (permalink) Old 04-18-2019, 05:38 PM
DOM71's Avatar
Did you check all tire's?
DOM71 is offline
post #3 of 8 (permalink) Old 04-18-2019, 05:44 PM Thread Starter
Jayturk's Avatar
A visual check, but used the gauge on the tire with the alert.
Jayturk is offline
post #4 of 8 (permalink) Old 04-18-2019, 05:48 PM
DOM71's Avatar
Reason I ask mine read correctly front to rear, but left and right are switched have aftermarket rims
DOM71 is offline
post #5 of 8 (permalink) Old 04-18-2019, 06:00 PM
BlackHemi41's Avatar
A visual check won't tell you anything. If you're suspicious that the sensor is inaccurate or damaged, you should check all the tires with a reliable gauge and compare.
What are the readings?
BlackHemi41 is offline
post #6 of 8 (permalink) Old 04-18-2019, 06:05 PM
Newoldchallenger's Avatar
Check all around with gauge first. If okay, drive around for a but and see if it goes away. If still no, then definitely replace the set.
I get the same issue sometimes when I swap to my front skinnies then back (no sensors in the fronts). It’ll sometimes hold for a day or two after I swap back to my normal setup. It eventually goes away.
But my sensors are also sporadic front to rear.
2013 Challenger R/T Automatic
Newoldchallenger is offline
post #7 of 8 (permalink) Old 04-18-2019, 06:36 PM Thread Starter
Jayturk's Avatar
TP is 36 psi, except for the tire in question, bad gauge I'm driving with it read 25psi. Hopefully it's just a leak. I'll have it checked out tomorrow.
Jayturk is offline
post #8 of 8 (permalink) Old 04-20-2019, 10:40 AM Thread Starter
Jayturk's Avatar
Problem solved, I immediately thought my sensor was damaged when I changed out the wheels, it was a nail. Thanks everyone for the input, I'm usually not paranoid.
Jayturk is offline
Tpms signal issues !! movnviol Wheels, Tires, Brakes, and Suspension 13 08-16-2018 07:33 AM
Small problem with TPMS JoelB Tuning/Data 2 07-22-2017 05:54 PM
TPMS Rebuild Kits | What You Need to Know Discount Tire Discount Tire 0 12-15-2015 12:19 PM
Upgrading 2010 Challenger R/T rims with TPMS to 2015 WR2's with TPMS. Compatible? I could of had a Hemi V8 Wheels, Tires, Brakes, and Suspension 4 08-29-2015 11:14 AM
2009 TPMS work on 2012? escadan Wheels, Tires, Brakes, and Suspension 0 11-06-2013 10:04 AM
