Z23 Powerstop - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 21 (permalink) Old 02-15-2019, 10:54 AM Thread Starter
Jaybird's Avatar
Z23 Powerstop
So I installed the Z23 Powerstop front kit on my 2015 SXT w/ STP performance brakes etc. Now the pedal feels spongey and
I have alot of pedal travel. When doing the install I uncovered the brake fluid reservoir
After the rotors and pads were installed I pumped the brakes a bunch of times then recapped reservoir
no fluid lost. I have 350 miles on mew pads and rotors they dont seem like a huge improvement over stock pads amd rotors
But the pedal is so mushy? Any suggestions? Should I change brake fluid? The Car has 43k miles and I am sure it is still the original brake fluid.
Any help would be great
Thanks
Jason
2015 Dodge Challenger SXT w/ stp
Jaybird is offline
post #2 of 21 (permalink) Old 02-15-2019, 11:32 AM
probably have the fluid replaced, flush and bleed brakes - that may clear up that symptom.
Since you probably have original fluid, likely dark color (presence of moisture absorption) and fresh fluid would be a good idea
Hal H is offline
post #3 of 21 (permalink) Old 02-15-2019, 12:12 PM Thread Starter
Jaybird's Avatar
Is this hard to do? It Seems messy? And my question is do they have a machine that sucks it out of reservoir ? Maybe doing the install myself was a bad idea? Dealer quoted me $723 for new front brakes. $186 Amazon Prime drilled slotted powerstop Z23 front kit
I paid my mechanic friend $100 to R n R pads and rotors. The pedal is to mushy....
Jaybird is offline
post #4 of 21 (permalink) Old 02-15-2019, 12:22 PM
MiHiHemi's Avatar
Took my SRT Challenger to Brakes Plus and supplied my own DOT5.1 fluid. They did a complete flush and fill in a half hour and charged me $45. Don't waste your time doing it yourself. They have all the equipment and experience. I would replace your fluid with DOT4 while you're at it. OE is typically DOT3.
MiHiHemi is online now
post #5 of 21 (permalink) Old 02-15-2019, 12:28 PM
Have it done by a shop - the proper way is using the correct (electronic) tool to cycle the ABS pump (there's redundant brake lines) to push the old fluid out of that part of the system.
It ran me ~ $125 for a fluid flush / replace and bleed at the dealer. I do this every two years on all my vehicles
Hal H is offline
post #6 of 21 (permalink) Old 02-15-2019, 01:13 PM
72/340's Avatar
Thanks
Jason
Never pump the brakes with the cap off. Time to bleed the brakes as you now have air in the system. Start at the right rear, then left rear, then right front, then left front. Make sure to keep the reservoir full and the cap installed!!
'10 Challenger R/T Classic
Flowmaster Force II cat back, K&N branded CAI with Amsoil dry synthetic filter, Diablo Predator 91 CAI tune,
Mopar '11+ IAT sensor, Mopar hood struts, RPI stealth guards, R/T spoiler emblem
72/340 is offline
post #7 of 21 (permalink) Old 02-15-2019, 07:20 PM Thread Starter
Jaybird's Avatar
So this is when I say to myself maybe I should have had the dealer just charge me the $723 I was quoted then move on. During My last oil change @ Dealer they said you need front brakes $723 total. So I researched on here and alot of people like the Z23 powerstops relatively inexpensive $186.00 on Amazon prime free shipping had my mechanic friend install. When I read about the install it said uncap the brake reservoir during install but after I should have capped it then pumped the brakes? With thick New pads I should have less pedal travel? #$?!§¥£ !
Jaybird is offline
post #8 of 21 (permalink) Old 02-15-2019, 07:29 PM
hemi4us's Avatar
most likey you have air in the system. proper brake bleed is all thats needed here.. two person job, some spare new fluid, less than a hr. not hard.
after reading stopping distance reviews on another forum (which i guess we cant mention on here), Id never run powerstops pads..yes they cut down on brake dust but from all accounts they also increased stopping distance by some 30-40ft..60-0. which could be the difference between a scary near miss, or a very bad day.
2015 Mods:
Axis Model II's.
Firestone Indy 275/40/20
Rolling Thunder Reso delete.
GPC Trunk Pull Handle.
Spare/Jack/Foam Delete.
GPC Phantoms.
Mopar O.E. Black Fuel Door.
Hellcat OE. ABS Cover.
Rear Seat Delete.
2014 Dodge Viper Seats.
hemi4us is offline
The Following User Says Thank You to hemi4us For This Useful Post:
Wizard of Iz (06-09-2019)
post #9 of 21 (permalink) Old 02-17-2019, 07:07 PM Thread Starter
Jaybird's Avatar
Do I need to bleed the rears? If The front brakes are the ones I replaced and had the pistons compressed?
Jaybird is offline
post #10 of 21 (permalink) Old 02-17-2019, 09:52 PM
Fawls's Avatar
Definitely sounds like you have air in your system.
Your brake fluid should be replaced around every two years, just do (or get done) a full flush, once you are doing it there is not much more work to do them all and you should start with the rears anyway, furthest first and work your way back to the shortest line.
I have a bleeder that I use that sucks the fluid through so I don't need to touch the brake pedal, shops do it this way as well, new fluid, no air!
2016 SRT 392, A8, Granite Crystal.
Fawls is offline
New CARiD Video - Z23 Brake Kit by Power Stop CARiD CARiD.com 0 12-17-2018 07:18 AM
Powerstop Z23 Evolution Front & Rear Brake Pads 15 Challenger, Charger SRT 392, SRT Speedlogix-Sales Speedlogix 45 12-13-2018 02:42 PM
Low Dust Power Stop Z23 Evolution Front Brake Pads - Fits all Hemi Challengers Speedlogix-Sales Speedlogix 2 11-13-2018 09:52 AM
How do you clean your SRT rims? BlueDragoon Detailing / Car Care 12 06-25-2017 07:56 AM
Brake q, '12 SXT with Powerstop Z23 Vader's Executor Wheels, Tires, Brakes, and Suspension 2 03-30-2016 07:21 AM
