Forum Discussions about this Product
1 - 2 of 2 Posts
    1. · Super Moderator
      The Challenger's weight is not the issue. While it is relatively heavy, it only weighs about 4,300 lbs. In addition, a jack only supports about 25% of a car's weight (the other three tires are on the ground). See my previous post for an explanation for the absence of a spare and jack.
      Carmakers are skipping the spare because of regulatory pressure to squeeze more miles out of every gallon of fuel. Ditching the 40 or 50 pounds that a tire and jack usually add to a car’s weight, helps to increase fuel economy slightly. It also incidentally increases automakers’ profits because they don’t have to pay for those parts. Another factor is that it increases trunk storage space, especially with large diameter and wide tires.
      Instead, the factory gives you get a sealant kit. The problem with this is that it won't help you if a tire’s sidewall gets sliced or if the flat is caused by more extensive damage than a tread puncture. If you take long trips and want to be prepared for any type of flat tire, you might want to consider a spare-tire kit, which includes a tire, jack, and lug wrench. Expect to pay about $239.
      That being said, if you don't take long trips, you may want to gamble and not buy a spare kit. Modern-days radials rarely get flats or blow-outs. Some options are to join an automotive club, like AAA, or buy a $6 tire plug kit. Using this prevents the sealant from fouling your tire pressure monitor sensor.
    2. · Premium Member
      I had one of those plug kits and the T handle broke and almost put the shaft through my palm. Let me tell you that hurt and made a mark. Go to Amazon and buy a kit with an aluminum handle, it’s far better overall.
      A $495 option now when it used to be standard, back then when deleted for credit they'd give you back $150.
      With different sized tires and Brembo brakes it creates issues like you can ruin your limited slip rear so if you can’t plug it it’s best to get towed. I will not go far from home with the car, if I’m within an hour to 90 minutes I can either get my son with the trailer or call a flat bed.
      Having staggered sized tires it’s even worse.
1 - 2 of 2 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
